02-07-2009, 12:41 PM | #1 |
Member#: 200124
SCIC
Vehicle:2015 Base WRX CBS |
Subaru FP 16G vs. Mitsubishi EVO III Big 16g Turbo
I hear people talk about using the EVOIII big 16g, but I dont understand how it would fit. Is the Subaru FP16g the same thing just moddifed to fit the suby? BTW just bought my 03 bugeye and im pretty new to the scooby world so sorry for the newbness
02-07-2009, 12:50 PM | #2 |
Vendor
Member#: 155450
Vehicle:2007 FXT WRB |
There is no "Subaru FP16G" The 16G is a mitsubishi turbo just like the EVOIII. FP is just "forced performance" which is a company who sells turbos. It has a 35lb/min compressor wheel. The EVOIII-16G is the same turbo, but with a 39lb/min wheel. And it makes a good bit more power. Many consider it the ultimate street turbo for a 2.0L wrx. All "EVOIII" means is that it has the 39lb/min compressor wheel from an EVO III in it. Its a normal 16G otherwise. Neither are a subaru turbo. Subaru doesnt make turbos, IN FACT, your TD04, is a mitsubishi turbo.
02-07-2009, 01:00 PM | #3 |
Member#: 200124
SCIC
Thanks
So this should bolt right on correct?http://store.forcedperformance.net/m...de=Turbo-Mitsu
02-07-2009, 01:02 PM | #4 |
Member#: 172080
you need a subaru application 16g.. that will not fit
02-07-2009, 01:02 PM | #5 | |
Member#: 179908
Vehicle:2005 WRX CGM |
02-07-2009, 01:10 PM | #6 |
Member#: 200124
SCIC
last one
OK I'ved narrowed em down. These will def. fit right? If so, which one is the recomended?
http://www.blouchturbo.com/turbos/WR..._Big_16G-7CM2/ or http://store.forcedperformance.net/m...Code=WRX-Turbo |
02-07-2009, 01:10 PM | #7 |
Member#: 168567
TXIC
Vehicle:2003 big 16g coming fixing my 03 wrx |
02-07-2009, 01:23 PM | #8 |
Member#: 158313
Vehicle:2003 WRX PSM |
Yes, those will fit. You're basically looking for housings that are designed to fit for a subaru, with some combination of mitsubishi wheels inside. The Blouch turbo you listed is exactly that- housings designed to fit a subaru, with a 16g compressor wheel originally designed for the EvoIII stuffed inside.
As to which is better, the Forced Performance turbo is a regular 16g, which won't flow quite as much air, and won't make quite as much power. Besides that, Blouch is absolutely top of the line in my opinion(and many others). Forced Performance has skimped on some things in the past, and I can't recommend them. If you wanted a regular 16g, the Blouch version is only $50 more than the FP, and you could rest easy that you had the best, assembled with the best parts. Here's a link: http://www.blouchturbo.com/turbos/WRX_TD05H-16G-7CM2/ |
02-07-2009, 01:28 PM | #9 |
Member#: 186149
Vehicle:2005 STi WFC #144 OBP |
I've got the blouch evo3 16g in a box in my room, just waiting to be installed!
Nice guys over there at blouch. |
02-07-2009, 01:43 PM | #10 |
Vendor
Member#: 155450
OK let me clarify.
ANY 16-18-20G is a mitsubishi turbo. FP is merely calling the subaru fitment MITSUBISHI turbos, "Subaru FP 16G/18/20G" Is that a bit more clear? I should have explained that in the first reply |
02-07-2009, 01:44 PM | #11 |
Vendor
Member#: 155450
BTW, skip the "Big" 16G Its a 16G with a 37lb/min wheel.
It makes very little as far as gains over a normal 16G, and spools later than a normal 16G The EVOIII-16G uses the 39lb/min wheel, makes a good bit more power than the normal 16G (or the "big" 16G) and spools pretty much the same. And although I dont sell Blouch, I will tell you that Blouch is a 50X better turbo. |
02-07-2009, 02:35 PM | #12 |
Member#: 200124
SCIC
Thanks
Thanks for all the help people. Just picked up the EVOIII-16g with the upgraded actuator.
Trying to get all the expensive parts out of the way. Engine management options next on the list . Thanks again guys! |
02-07-2009, 06:07 PM | #13 |
Vendor
Member#: 155450
Honestly, the EVOIII-16G is known as the "ultimate street turbo for a 2.0L" for a reason.
Because it kicks so much ass on the 2.0L |
02-14-2009, 07:39 PM | #14 |
Member#: 115199
South East
Vehicle:2003 WRX w/JDM 5 Spd Future 300+ WHP Club |
02-14-2009, 10:55 PM | #15 |
Member#: 170139
Vehicle:'06 STi Aspen White |
it's deffinately not necessary but doesn't hurt
02-15-2009, 08:03 AM | #16 |
Member#: 48199
Vehicle:06 WRX WRB |
If the turbo is built with an internal wastegate its not necessary, I believe all 16g with Subaru fitament have internal wastegates..... EWG is a good mod to do on any turbo if you have the funds, not necessary though...
03-04-2009, 10:52 AM | #17 |
Member#: 202804
Vehicle:2002 PSM Sedan The 2.0L that could |
Just to clarify......
This is just a regular 16g correct? Not a "BIG" or "EVOIII"? Thanks |
03-04-2009, 01:48 PM | #18 |
Vendor
Member#: 155450
Yup
Any reason you dont want the EVOIII? It would rock the house on your 2.0L |
03-04-2009, 02:11 PM | #19 |
Member#: 202804
03-04-2009, 03:04 PM | #20 |
Vendor
Member#: 155450
With the right tune you SHOULD be ok. Any time you go to a larger than stock turbo, reliability becomes relative. Not saying it makes your motor a ticking bomb, but obviously it changes things.
Here is something to think about. Add up what you are spending here. Add up what you have spent before Then realize that getting pistons put into your motor will only run you about 1200 bucks and cost you a couple days downtime, and you should be able to rent a car for those days for under $100. Then you dont have to worry about it anymore. Its not so unreasonable. If you are that worried about it, just do pistons and move on. Its not nearly as big of a deal as most people think. Its not a multi thousand dollar job thing. |
03-05-2009, 04:08 AM | #21 |
Member#: 188773
South East
Vehicle:2007 Subaru iMpreza World Rally Blue |
2007 subaru iMpreza WRX
yeah, i need some help with my car too. dont know what kind of turbo i should get and do you have to take off the topmount intercooler when you put it down in the front? sorry you guys. just got a subie last year. PM me fellas. thanks
03-05-2009, 09:21 AM | #22 |
Vendor
Member#: 155450
You never HAVE to go front mount. Its just a better option for some setups.
You have a 2007 which has a 2.5L. The obvious and most common upgrade for these WRXs is a used VF39 or VF43 from an STI. Unfortunately while the EVOIII-16G is amazing on the 2.0L, its just not great on a 2.5L. The reason is the small compressor housing. This is the same reason why the $700-800 18Gs dont perform well on the 2.5L either. Whereas the 18Gs with the larger compressor housing (like the Blouch and older Greddy) work AMAZINGLY well. For street, day to day, incredible low end power and a powerband that doesnt fall on its face at 5000rpm, the Blouch TD05-18G 8cm is in my opinion the ultimate street turbo for a 2.5L Subbie. More low end than a VF39, and a far wider/smoother powerband. You dont HAVE to use Blouch, but just be sure whoever you get it from uses the large compressor housing. Anyone who tells you it doesnt make a difference, flat out, is lieing to you in an effort to sell you what they have in stock, or to sell you a higher profit margin turbo. Either way, find someone else to buy from in that case. Unfortunately, I dont sell them Buy direct from Blouch if you go with Blouch. |
03-05-2009, 03:25 PM | #23 |
Member#: 152618
I dont mean to hijack the thread but I've also been looking intensely at getting a evoIII16g. So for my application 03 wrx. I would need a 255 fuel pump, atleast a 550cc injectors and a front mount? Is that correct?
And about what kind of whp should I be expecting out of a evoIII16g? Can my transmission also hold these power levels without blowing on me? |
03-05-2009, 03:36 PM | #24 |
Member#: 48199
You can use either a FMIC or TMIC for that application. Results will vary obviously, and so will prices. IF you stay with a TMIC I would consider a high quality TMIC not ebay or STI (even tho the STI is nice there is better options available)....Your FP and Injector selection should be ok, when it comes to injectors I recommend talking to your tuner because injector tuning varies and they may prefer one brand over another... Horsepower will vary depending on dyno, I'd imagine 240-270 awhp....The power band will be much better then the stock turbo, something that must be experienced to appreciate.... As long as you drive with common sense and dont bang every gear it should be ok. |
03-05-2009, 04:20 PM | #25 |
Member#: 129459
here is a link to just about everything you may want to know about subarus and turbos... verry informatiove and a must read for anyone thinking of upgrading their set up.
http://forums.nasioc.com/forums/show...=turbo+listing |
FS: (VA-757) TD05H - EVO III Big 16G Turbo | madcatz | Engine/Power/Exhaust | 21 | 11-08-2009 10:53 PM |
FS: (HR-757) TD05H - EVO III Big 16G Turbo | madcatz | MAIC Private Classifieds | 22 | 06-18-2009 06:22 PM |
FS: Subaru WRX/STi TD05H-EVO III Big 16G Turbocharger | KillJoy25 | MAIC Private Classifieds | 16 | 04-15-2009 09:20 AM |
WTB:: EVO III Big 16G or 18G 7c Turbo For Good Price :-) | mator | MAIC Private Classifieds | 7 | 03-07-2008 01:02 PM |
WTB:: EVO III Big 16G or 18G 7c Turbo For Good Price :-) | mator | Private 'Wanted' Classifieds | 3 | 03-06-2008 08:35 AM |
