Welcome to the North American Subaru Impreza Owners Club Wednesday April 25, 2018
Go Back   NASIOC > NASIOC Technical > Normally Aspirated with bolt-on Forced Induction Powertrain
Old 08-05-2001, 12:10 PM   #1
d00f
Member#: 6000
2000 GC8 STi V4 swap
BRP
Default Powering Guages and Senders
As a step towards my turbo install I've added a guage pod. There was room under the stereo so I velcroed the autometer senders for the EGT and fuel pressure guages there. For the lights in the guages I took power from the ashtray light circuit (which wasn't being used). So now the lights on the guage turn on when the rest of the console lights do.
The senders themselves were powered from the radio circuit and this is a problem. As I'm sure everyone is aware your radio turns off when you crank the engine over. My guages go crazy when this happens. The boost guage is mechanical so it's fine but the others vibrate and jump wildly from having their power cut off abruptly.
Is there somewhere else I should tap this power so they get power only when the key is on? I'd like them to be powered in all positions but "off". The guages and senders draw about 150ma. Is there a way I could plug a capacitor in with some diodes so the guage pod stores about 2 seconds of juice while you're cranking the engine over? Any electronics wizards care to speculate on what size cap I'd need?
I don't want to power the radio (on the same circuit) at the same time so my 10 year old foggy electronics tells me to add a diode to stop the current from flowing through to the radio. This seem to be correct?
-Michael
d00f is offline   Reply With Quote
Old 08-05-2001, 06:55 PM   #2
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
I was just wondering if the gauges dimmed with the rest of the lights? Where exactly did you tap it into?
Impreza Rider is offline   Reply With Quote
Old 08-05-2001, 09:05 PM   #3
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Michael: to power the electrical gauges in all modes except for OFF, you can use two diodes connected like so:
Code:
IGN ____|\|____
               o-------- 12V FOR GAUGES ONLY
ACC ____|\|____|
Use 1N4001 or 1N4002 diodes. If you can find them, Schottky diodes rated for at least 1A and 50V will be even better, such as a 1N5817. You may need to dig under the steering wheel to find the IGN and ACC wires.
For the backlighting, tie one wire (e.g. WHITE) to the +12V wire at one of the panel lights (such as the hazard flasher button or other backlighting wire. Then find the other wire that is controlled by the dimming circuit, and tie the other wire (e.g. BLACK) to that. This will allow your gauges to dim along with your instrument panel.
-WaC
wayne
wac is offline   Reply With Quote
Old 08-05-2001, 09:32 PM   #4
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
heheehe.. I'm writing all of this down I'll have you know...
Fitz
Fitz is offline   Reply With Quote
Old 08-06-2001, 01:39 AM   #5
d00f
Member#: 6000
BRP
Hrm. Dimming them is a great idea. As long as the dimmer circuit can handle a little more power drain. Thanks for the suggested part numbers. God knows where I can find a single part like that.
-Michael
Old 08-06-2001, 01:59 AM   #6
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Radio Shack... or any do it yourself electronics store....
Fitz
F/S prosport boost and oil pressure gauge and sender kit W0R7Xsubi Tri-State Area Private Classifieds 7 09-21-2009 02:24 PM
bushings, adapters, and senders (oh my!) Lachlan Newbies & FAQs 3 02-04-2004 01:44 PM
Guaging interest- guages and other wrx parts Redline8k Private 'For Sale' Classifieds 2 12-03-2003 05:43 PM
WTB: Knocklink and Omori WRX Look EGT with WPH and sender parid Private 'Wanted' Classifieds 1 08-25-2003 11:23 PM
gauge sensors and senders? wrxmechman Interior & Exterior Modification 14 12-30-2002 11:24 PM
