08-22-2010, 07:33 PM | #1 |
Member#: 233751
NWIC
Vehicle:04 STi PSM |
04 STi Intercooler Spray Not Working
So when I bought the car the tank in it was cracked, bought a replacement from a guy this weekend. Got home and installed it and to my displeasure I still didn't have a functioning system. I have blown out the lines, tried 2 switches, and 2 motors, I'm thinking the relay is the culprit possibly. Anyone know which relay operates the sprayer? I'm not so great with decyphering service manuals and would appreciate the help.
08-24-2010, 04:46 PM | #2 |
Member#: 39086
NWIC
Vehicle:2004 STi White |
Can you adjust your side mirrors? They are on the same fuse as the intercooler spray. #4 behind the change pocket to the left of the steering wheel.
The relay (INTERCOOLER WATER SPRAY TIMER in suby speak) is a 4 pole plug to the right of the glove box under the dash. It looks like you have to pull the glove box to get at it. It's only 13 screws... If you are that far into a PIA job I would change out the cabin air filter too. Odds are it's 6-7 years old and you will be in the neighborhood. There are threads on changing that filter if you need instructions. Edit: The plug is B286 if you care. |
08-24-2010, 11:24 PM | #3 | |
Member#: 233751
NWIC
09-28-2010, 03:27 PM | #4 |
Member#: 133597
SCIC
08-24-2010, 09:48 PM | #5 |
Member#: 153216
Tri-State
could you by any chance have a pic?
08-24-2010, 09:53 PM | #6 |
Member#: 39086
NWIC
Service manual just has a drawing of where the harness plug is. It is in Adobe and I only have the reader. Sorry.
08-25-2010, 08:34 PM | #7 |
Member#: 233751
NWIC
Well contacts aren't corroded or anything and relay seems to be in working condition, however I can't feel it clicking over when I press the switch unless it is a solid state relay (probably now that I think of it). Unless someone has some good insight I'll probably end up taking it to PIA.
08-29-2010, 12:50 PM | #8 |
Member#: 233751
NWIC
Turns out the fog light dongle was plugged into the I/C spray switch.
08-29-2010, 06:19 PM | #9 |
Member#: 39086
NWIC
09-07-2018, 07:25 PM | #10 |
Member#: 491179
Spray not working
2004 STI intercoller spray isn't working.. where is the intercooler spray motor
09-07-2018, 11:17 PM | #11 |
Member#: 33782
MAIC
Vehicle:96 3MI Racing search FIRST, then PM!!! |
Similar Threads | ||||
04 STI intercooler spray tank. | EvanOT | SCIC Private Classifieds | 0 | 09-24-2009 09:04 PM |
JDM STI intercooler spray switch/V7 sti scoop rear windsheld spray pump spliter. | subrandon | Private 'Wanted' Classifieds | 1 | 07-07-2006 12:45 AM |
04 STi intercooler spray switch, headlight leveling motors | my04sti | Private 'For Sale' Classifieds | 5 | 06-26-2006 09:10 PM |
04 STI Tach wire not working for eBoost2, anyone? | bboy | Electrical & Lighting | 5 | 04-19-2006 06:32 PM |
MRT Intercooler Spray - FINALLY WORKS! | hotsam | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 10-21-2001 12:21 AM |
