Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 05-09-2018, 01:20 AM   #251
Falcon WRX
Member#: 400310
2017 WRX Sport
Crystal White Pearl
^Thanks for the info!
Falcon WRX is offline   Reply With Quote
Old 05-16-2018, 09:39 PM   #252
TurboSteez
Member#: 484072
Does anyone run Avid.1 av-54 on a 2008 sti? 18x8.5 +35. Really want these but not down for it to rub on my brembos calipers
TurboSteez is offline   Reply With Quote
Old 05-27-2018, 01:25 AM   #253
chris the man
Member#: 287783
08 predator evo X
RR
Originally Posted by joe_m2009 View Post
Anyone try 18x9.5 +22mm offset? Curious if it's a bigger concave?
Curious to this as well guys! Anyone running the (+22mm)?
Also where is everyone buying the hub centric rings at?
Thanks so much!
chris the man is offline   Reply With Quote
Old 05-27-2018, 04:44 AM   #254
Chuckls
Member#: 280696
Thanks so much!
Amazon. $10 for plastic / $20 for aluminum
Chuckls is offline   Reply With Quote
Old 05-27-2018, 12:38 PM   #255
Cab0oze
Member#: 443914
2015 WRX
Aluminum would be a terrible idea and a waste of money, and would add needless weight. Also, garages lose (steal?) these things constantly, so it's really not something that's worth investing much money in. Get the cheapest plastic ones you can find.
I've never paid more than $4 for rings, shipped. Usually get them from ebay, and usually from aspiremotoring. These were the ones I bought for my wheels, although the price is a bit higher right now for some reason.
https://www.ebay.com/itm/4-Hub-Centr...cAAOSwIFtaEPBP
Cab0oze is offline   Reply With Quote
Old 05-28-2018, 01:24 AM   #256
pthompson_
Member#: 485715
What lugs are yíall running all my 15+ bros?
pthompson_ is offline   Reply With Quote
Old 06-19-2018, 09:10 PM   #257
Le_Pong
Member#: 478116
Hey guys so Iím thinking about ordering the Av-20 18x9.5 et38. Will the stock 245/40 fit on them?
Le_Pong is offline   Reply With Quote
Old 06-19-2018, 09:35 PM   #258
Cab0oze
Member#: 443914
2015 WRX
Originally Posted by Le_Pong View Post
Hey guys so I’m thinking about ordering the Av-20 18x9.5 et38. Will the stock 245/40 fit on them?
One of the guys in my local club did it (and subsequently regretted it), so yes, it is possible, but it looks terrible so don't do it. If you want to keep the stock tires, get the 8.5s, it looks great and everything fits.
Old 06-20-2018, 12:27 PM   #259
Le_Pong
Member#: 478116
Okay so Iíve ordered the wheels. Anyone know what size lugs and hub centric ring sizes? For a 2017 wrx
Old 06-20-2018, 11:43 PM   #260
Cab0oze
Member#: 443914
2015 WRX
Should be the same as a 2015, I got 73.1mm to 56.1mm. You should probably do your own research to confirm that though, I'm a bit tipsy right now.
Mine cost $3.98 on ebay from Aspire Motoring, they're excellent quality.
Old 06-23-2018, 08:29 AM   #261
Kyleisnice
Member#: 370138
2013 Impreza Sport
Ice Silver
Default Lugs
Iím purchasing some Av32ís, what lugs seem to work best with these wheels?
Kyleisnice is offline   Reply With Quote
Old 06-28-2018, 05:37 PM   #262
Kyleisnice
Member#: 370138
2013 Impreza Sport
Ice Silver
Originally Posted by Stealthfish View Post
I'll join I guess.
What lugs are you using?
Old 06-28-2018, 05:50 PM   #263
Kyleisnice
Member#: 370138
2013 Impreza Sport
Ice Silver
Originally Posted by Midarete View Post
So here they are. Mounted up on my DGM WRX
What lugs did you go with?
Old 07-18-2018, 04:50 PM   #264
aloferradas
Member#: 398157
2004 WRX Sedan
JBP
Nice looking wheels! I am about to purchase a set but I cant freaking decide whether to go 17x8 or 18x8.5 . I like the meaty tire look so I am leaning towards 17x8 on some 245/40s. I really wanted to go for 255/40 on a 17x8 but I've heard that this isnt ideal. I am not super informed when it comes to wheel specs but I am slowly learning. If i went with the 18X8.5 i would def go for 255s but i just dont want to deal with endless rubbing issues. Anyone that could give me some advice/pointers would be greatly appreciated. I have a 2004 WRX on stock struts and epic engineering springs .
aloferradas is offline   Reply With Quote
Old 08-13-2018, 02:37 AM   #265
Ksig511
Member#: 490068
I am looking to get a set of the Avid AV20's 18x9.5 35 offset for my 18' STI. I see them mounted on previous year STI's but am trying to get an answer as to if they will fit/clear the new brembo's on the 18'. Any help would be greatly appreciated.
Stock suspension, and planning on running 245/40 to keep the same tire diameter. I was told by the dealership that changing the diameter of the tire could lead to issues with the transmission down the road and will void the warranty....something I wasn't aware of.
Ksig511 is offline   Reply With Quote
Old 08-23-2018, 01:26 PM   #266
MN_SnoWRX16
Member#: 490306
2016 WRX
I am looking at the Avid AV34ís. Has anyone mounted them on a WRX or Sti?
MN_SnoWRX16 is offline   Reply With Quote
Old 09-07-2018, 06:07 PM   #267
SlushBoxWRX
Member#: 490120
got some bronze av20 for my blue 17 wrx that il be slapping on tomorrow along with coil overs so a nice drop. will post photos once its done.
SlushBoxWRX is offline   Reply With Quote
Old 09-17-2018, 02:32 AM   #268
MrStiggy
Member#: 491537
2013 WRX STI
Pearl
I'm a newb to wheels, just learned the hard way that AV32s will not clear the STI Brembos. I got the correct bolt pattern and size and everything but the wheel design won't clear and I'm iffy on using spacers.
I had to buy tires sooner than expected and couldn't get wheels at the same time, so I need to reuse my stock 18x8.5 tires I just got a few months ago.
So, for a 2013 STI, will the AV06, AV20, or AV27s clear the Brembos in a 18x8.5? Couldn't find that exact spec throughout the whole 11 pages so just wanted to check. Thanks!
MrStiggy is offline   Reply With Quote
Old 09-20-2018, 06:36 PM   #269
Le_Pong
Member#: 478116
Put these on a few months ago. 18x8.5 stock Dunlops. Stock suspension.
Old 09-21-2018, 10:50 AM   #270
KENTEND0
Member#: 371448
2015 WRX
Galaxy Blue Pearl
Av20s clear brembo in both 18x8.5 and 18x9.5 sizes
KENTEND0 is offline   Reply With Quote
Old 09-22-2018, 01:57 AM   #271
MrStiggy
Member#: 491537
2013 WRX STI
Pearl
For sure for sure for sure? Lol
Have you seen them mounted on an STI before with no spacers?
Old 09-24-2018, 12:58 AM   #272
Blev2922
Member#: 477029
Default The AVID thread
I use to be on AV-20 now Iím on AV-38s 9.5 +30
Then
Now
Blev2922 is offline   Reply With Quote
Old 10-01-2018, 03:53 PM   #273
Rowrx11
Member#: 338312
Hi! Any here with Avid av-27 18x9.5 +38 Bronze ? 2017 STI.
Rowrx11 is offline   Reply With Quote
Old 10-06-2018, 01:43 PM   #274
AZsubi18
Member#: 491763
Originally Posted by subiedante View Post
Avid1 AV20s
17x8 35 offset
stock Dunlop 235/45/17 tires.
I was thinking about staying with the stock 17in tires how do u like the new rims?
AZsubi18 is offline   Reply With Quote
Old 10-25-2018, 12:32 AM   #275
wildboy55
Member#: 493175
Default What color?
Originally Posted by Phantom_EJ25 View Post
Pics of my STI with AV20's 18x9.5 +38mm.
-Thanks!
What color are these?
wildboy55 is offline   Reply With Quote
