Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 07-04-2004, 01:13 AM   #1
dogWagon
Member#: 61558
04 wrx wgn silver
Unhappy koni insert install
So i decided to install the inserts this weekend. 04wrx wagon, I had installed tein h-tech springs a month ago.
Everything was going ok until I broke the threaded part of the inserts off
Now the car is sitting in the garage un-driveable. I have to wait until I can get a new insert shipped to me. damn.....
I was putting the tophat on and was using a electric impact wrench to put the nut on, I had done this on the other 3 with no issues. Then snap, took another hour to get the nut off. I had to drill through the top of the koni piston to get it off. Totally trashed it.
I hate it when this happens. This will cost me a good 150.00 to get a new one, plus the shipping and the wagon is dead untill I get it. Of course its the holiday weekend and the tirerack and koni is closed.
live in learn, if anyone was thinking of doing this dont let this scare you, it went pretty easy. I just wish I could run over to autozone and get a replace part, not that easy. Most places dont carry koni inserts.
dogWagon is offline   Reply With Quote
Old 07-06-2004, 05:16 PM   #2
cooleyjb
Member#: 55727
#533 Spec Racer Ford
what tophats did you use to put the rears in with???
konis don't fit 04 without some fiddling
cooleyjb is offline   Reply With Quote
Old 07-06-2004, 07:51 PM   #3
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Sorry to hear about it; I've certainly had mishaps in install days of my own.
DrBiggly is offline   Reply With Quote
Old 07-06-2004, 11:20 PM   #4
dogWagon
Member#: 61558
04 wrx wgn silver
stock tophats
I used the stock top hats, there is a lot posted on this board regarding the rear issues. The top of the insert piston and the top hat fit fine, the issue is the length of the threads. The inserts do not have enough threads to get a tight fit. I used two hardened washers as spacers.
That was what some others had done before.
Old 07-07-2004, 12:44 PM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed (sold)
Default Re: koni insert install
Sorry to hear you had some bad luck, but your description is kinda confusing me. You were putting the top nut on the strut shaft correct? And it broke. Wouldnt that mean the nut would have come off with some the threaded tip stuck in the nut? Why would you have to drill the piston to get the nut off? You mean drill through the threaded piece stuck in the nut?
ss
subysouth is offline   Reply With Quote
Old 07-07-2004, 11:07 PM   #6
dogWagon
Member#: 61558
04 wrx wgn silver
ss
The threaded part brok off in the nut, the nut and the very top of the insert were still attached to the piston. I could not back the nut off, it just turned the whole piece around, the tit adjuster on the top was attached through the hollow threaded tip. The nut didnt separate from the the rest of the shock. In the end I got the top inch of the piston top.
anyway it was kinda nuts, I finished the install today.
Of course in the directions it says not to use an impact wrench. I need to keep off the smokey smoke...
Old 07-08-2004, 01:09 AM   #7
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed (sold)
Got it, I'm glad you got it sorted. Maybe the tip is weaker because of the adjuster?
ss
Old 09-13-2004, 01:44 AM   #8
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
sorry to bring this thread back, but how are you supposed to secure the top to the strut without using an impact wrench?
whtlegacy is offline   Reply With Quote
Old 09-13-2004, 03:16 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
I think every strut manufacturer in the world tells you not to use an impact wrench to tighten down the top mounts, but everybody does it anyway. I did it with my old DMS Golds (repeatedly, since they sucked and had to come off the car 3 times), and I've done it with stock struts and my Koni inserts. Never had a problem.
My guess is that dogWagon got that last one cross-threaded and that's why it broke, but I dunno. I still don't understand his description of what happened, so my hypothesis could be completely wrong.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 10-06-2004, 08:40 AM   #10
gotsol
Member#: 17346
08 Cayman S
Originally Posted by dogWagon
stock tophats
Can you give me some more details about this?
I am about to put 04 sti springs and top hats on my 02 wrx with Koni inserts, thanks
Patrick
gotsol is offline   Reply With Quote
Koni Inserts...install suggestions shwrx Southern California Impreza Club Forum -- SCIC 9 02-25-2007 11:53 PM
Koni inserts installed in WRX sedan strut housings PossumK Private 'Wanted' Classifieds 0 12-16-2005 06:29 PM
koni insert installation 4 fair fee ? psun786 Southern California Impreza Club Forum -- SCIC 11 08-26-2005 12:49 PM
STi RA springs and Koni inserts installed- impressions TheMirror Brakes, Steering & Suspension 24 12-19-2003 10:00 PM
Koni inserts install [wrx sedan] MrBrian Brakes, Steering & Suspension 3 07-10-2002 09:15 AM
