05-23-2001, 08:01 AM | #1 |
Member#: 1904
TXIC
Vehicle:2017 Impreza Sport E36 M3/4/5 |
No cruise control...
Well, I actually tried using the cruise the other night...which I have used in the past, but not for a while...and it didn't work...at all.
The light went on, on the button, but when trying to set it with the little steering wheel stick, nothing. I did adjust the cruise cable under the hood (thinking it was the throttle, at the time, whoops), would that have done it? I also have an intake on their, but I wouldn't think it's related...
05-23-2001, 09:42 AM | #2 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
fuse?
connetor in the dash? is it plugged in all the way? double check... if all seems well.. go see your dealer... it should still be covered under warranty right??? j. www.subiegal.com |
05-23-2001, 10:13 AM | #3 |
Member#: 1904
TXIC
ummm..warranty? riiiight... Well, I think I kinda threw that down the gutter when I cut into my ECU
as for fuses, I did check them all, and they are all good. It could be a plug in the dash, now that I think about it...cause I have taken that apart a fair share of times. Thakns |
05-23-2001, 10:24 AM | #4 |
Member#: 4418
Vehicle:2019 CTR White |
if you cut into your ecu, there might be a short wire...get a wire tester (I dont know what theyre called ) and that should show what the problem is..just trying to help..
goodluck . |
05-23-2001, 10:26 AM | #5 |
Member#: 1904
TXIC
well, I'm rather sure that there's no short. I did a good soldering job, and an even better taping job when finished... hmmm...
05-23-2001, 07:14 PM | #6 |
Member#: 756
Vehicle:2003 Legacy L wagon 2009 Kawasaki C14 |
Check all the vacuum lines. ON another car I had with cruise, one of the lines came loose and it didn't work.
Jim |
05-23-2001, 09:19 PM | #7 |
Member#: 1248
NESIC
Vehicle:04 Impreza WRX STi Java Black Pearl |
this may sound wierd... thats cuz it is.. check your brake lights... i changed mine over to LED's and cruise is lost... i was told because the car is seeing no load (burnt bulb) mebbe that will fix it
05-24-2001, 09:58 AM | #8 |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
Is it a 5-speed? If it's like my car, there's a switch that interacts with the clutch pedal. There is a plastic stopper covering a hole on the pedal. Check to see that the stopper isn't broken. I don't know why there is a hole there in the first place. Cost for me was $1.45. Hope you can understand my very technical explanation.
edit: Here's my post Dennis [This message has been edited by bluesubie (edited May 24, 2001).] |
05-24-2001, 10:54 AM | #9 |
Member#: 1904
TXIC
good call! I have a 5-speed, and recently replaced my pedals. I bet I jarred something out while drilling into the clutch!
thanks, now at least I have a lead |
05-24-2001, 04:17 PM | #10 |
Member#: 786
JGard18,
If you have no luck finding something wrong in your pedals, you may have to have your "clockspring" replaced in the steering wheel. That's what went wrong with my RS - my cruise and horn quit working. The clockspring, as the mechanics called it, is where all the mechanical connections are for your steering wheel (horn, cruise, wipers, headlights, airbag, etc). Does your horn still work? I hope you find something wrong with your pedals, because it cost me $450 total to have my dealer diagnose the problem and then replace the part. |
05-25-2001, 08:28 AM | #11 |
Member#: 1904
TXIC
Thanks for the advice. Haven't used the horn in a while, so I don't know. Will check it though...
oh, and also will fix myself for much less ...well if I fix it at all |
FXT-No cruise control above 80MPH???? | wadejg | Forester Forum | 37 | 10-17-2006 01:49 PM |
new headunit = no cruise control | Blindeye_03 | Car Audio, Video & Security | 11 | 03-26-2003 02:52 PM |
Cruise actuator but no cruise control!! | Improviser | Normally Aspirated Powertrain | 14 | 11-13-2002 04:48 PM |
Why No Cruise Control Ind. Light in WRX? | rally_wannabe | Newbies & FAQs | 7 | 05-16-2002 03:56 PM |
