Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Old 01-09-2018, 08:38 PM   #8776
Myslow02
Member#: 480352
02 wrx/398whp 360wtrq/3076r/820cc injectors/wally 255/idc ~75%/1100'
Cars only running 16ish psi atm do to a bad dyaphram in the ewg.
Myslow02 is offline   Reply With Quote
Old 02-21-2018, 02:12 AM   #8777
boostinsticnd
Member#: 437417
2004 Wrx
04 wrx/743.8hp & 651.1tq/E42 mixture/Compound(s366 and s480)/2000Id injectors/645M ASL
Lots of timing pulled back and stock avcs map.
boostinsticnd is offline   Reply With Quote
Old 03-30-2018, 11:25 PM   #8778
UFoFuN04
Member#: 205685
2006 WRX STI
Great numbers bud, it's not easy hitting those numbers out west. Do you have a build thread?
UFoFuN04 is offline   Reply With Quote
Old 04-05-2018, 03:34 PM   #8779
kevmo11
Member#: 403684
2006 sti
cgm
Are there different tiers of e85 like gasoline or does solely ethanol content matter?
kevmo11 is offline   Reply With Quote
Old 04-06-2018, 09:16 AM   #8780
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
6466 @ 40psi
Old 04-21-2018, 12:17 PM   #8781
181stLeader
Member#: 184183
1996 Impreza RSTi
V8 EJ207 Aerosim Carbon
Facility: YimiSport Tuning
Type of Dyno: Mustang
Baseline Stock sti on dyno:No base line yet, I was the first car on the new dyno
Boost: 24psi peak(tapering to 17 at redline)
Fuel: E85
Target AFR:
SAE Corrections: SAEJ1349
Peak HP at RPM: 302 @5506
Peak Torque at RPM: 312 @4678 RPM
Mods: version 8 EJ207, Stock UEL headers, APS uppipe, Vf-34 turbo(p20 exhaust housing swap), DW1050x injectors, AEM 320 fuel pump, 3" hard turbo inlet, K&N Typhoon SRI, TurboXS 3"catless downpipe + midpipe, Prodrive Axleback, Carberry ROM on the v8 JDM ecu(flexfuel).
Tune on 91:
Then on E85:
picked up +40 hp and +66 ft/lbs switching to E85. When I saw the numbers I was then I drove it and was Mustang Dyno is a heart breaker for sure! I'd like to see what numbers a stock STi does on their new Mustang dyno.
E85 is awesome!
181stLeader is offline   Reply With Quote
Old 04-23-2018, 05:54 PM   #8782
BrandonMorgan20
Member#: 397364
2015 Sti
CWP
15 sti
cobb tbe /flex fuel 1050x
Phatbotti Tuning Ron
BrandonMorgan20 is offline   Reply With Quote
Old 05-03-2018, 01:00 AM   #8783
181stLeader
Member#: 184183
1996 Impreza RSTi
^Looks good! I'm sure its super fun with all that tq on tap! You wont want to fill up on 91 any more
Old 05-06-2018, 03:28 AM   #8784
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
6466 @ 40psi
that is ****ing nuts dude, what kind of pump u run ?
Bariga is offline   Reply With Quote
Old 05-09-2018, 10:52 PM   #8785
sysfailur
Member#: 135993
08 Area1320GTX3071
V-Mount, 18x12, 315 NT01
455whp 421wtq / sysfailur / 08 STi / EJ257 + GTX3071 .63 / 1000cc DW / ~500ft
Pics of car/build: https://clients.zacharyemerick.biz/C...8-STi-V-Mount/
Vid of pull: https://clients.zacharyemerick.biz/C...nt/i-XLCPJhZ/A
sysfailur is offline   Reply With Quote
Old 05-11-2018, 01:08 PM   #8786
devkiwi
Member#: 467192
Anyone help me with my route forward?
I've got a 16' STI.
- Cobb SF intake
- Full Invidia Catted TBE
- eTuned By Eric @ Torqued Performance
I've been eyeing Cobb's Flex Fuel kit but haven't seen answers to a few questions I have.
Will my stock injectors handle an e85 blend? 4th gear WOT currently hits 88% injector duty cycles on a run up to redline. What sort of blend would begin maxing my system?
Will the stock fuel pump handle that blend or do I need to upgrade?
Other suggested supporting mods for the conversion?
I'd do GS EBCS and a protune upon install.
devkiwi is offline   Reply With Quote
Old 05-11-2018, 02:33 PM   #8787
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
I would try 50% first with the lowest boost level.
gaby is offline   Reply With Quote
Old 05-13-2018, 11:35 PM   #8788
rexblake
Member#: 178426
2010 S4
Gray
If you are going to get a pro tune anyway buy a pump and bigger injectors and run full E85. That’s a huge expense to be limited by stock fp and injectors, plus you won’t get much of a bump in power. Quite frankly, at 88% I wouldn’t do anything more, you are just asking for issues.
Old 05-30-2018, 09:28 AM   #8789
Furlybird
Member#: 459433
Savage
Furlybird is offline   Reply With Quote
Old 05-30-2018, 01:58 PM   #8790
02RexWI
Member#: 165141
6466 @ 40psi
Build list?
02RexWI is offline   Reply With Quote
Old 06-04-2018, 04:01 PM   #8791
STi320
Member#: 148655
2005 STi CGM
Facility: FAST of West Chester, TurboTekTuning LLC
Dyno: Mustang MD-AWD-150
Temperature: 86 F
Baseline:
Boost: 27 psi
Fuel: Ignite 85
Target AFR:
Peak HP: 520 @ 6100
Peak TQ: 493 @ 5150
Mods:
iAG 2.5 CD, ETS PTE 6062 0.64 a/r, ETS 4" FMIC, iAG rails, ID 1700, Walbro 450, Iwire Hard Wire Kit, Stock Cams and Heads, GS 3 port, Speed Density
We made 555/537 @ 28 psi but backed it down as everything is still pretty fresh with this new build. Lots of room to go, we left plenty on the table.
STi320 is offline   Reply With Quote
Old 06-21-2018, 07:03 PM   #8792
mharris137
Member#: 487095
2013 wrx
black
Default flex kit
I have the full cobb flex kit. So Aem pump 320lph I belive. 1000cc injectors, fuel regulator, flex sensor, 3 inch turbo back exhaust with a stock turbo( for now). Made 315 hp and 320ish tq at 5500 feet on what is know as a bit of a heart break dyno. 2013 wrx. It was a killer mod love me some ethonal.
mharris137 is offline   Reply With Quote
Old 06-24-2018, 09:55 PM   #8793
MegaEagleThrust
Member#: 487592
Some good dyno sheets being posted
MegaEagleThrust is offline   Reply With Quote
Old 08-06-2018, 10:56 PM   #8794
04sedantyson
Member#: 233011
2004 04 sedan
Default The E85 Army Thread
Sooooo, just got my 04 back ej205 . Had the engine rebuilt with sti rods and Manley piston kit, heads rebuilt. Engine was in good condition, just had 165k miles on it. Iím running a VF30 on E85 with 1050x injectors and all supporting equipment.If I wanted to upgrade the turbo for a little more bump or just a simple upgrade, what would be a good choice?
04sedantyson is offline   Reply With Quote
Old 08-09-2018, 05:35 AM   #8795
JakeGri
Member#: 489905
Iíve had sooo many e85s
JakeGri is offline   Reply With Quote
Old 09-29-2018, 12:56 AM   #8796
partsforsale
Member#: 492064
2011 sti-420hp 480tq-e85 with 1000cc id's
partsforsale is offline   Reply With Quote
Old 10-25-2018, 03:55 PM   #8797
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
98 Forester
ej22e, S20 heads, S252 turbo at unknown boost but between 25 and 28psi. Forgot to log, ebcs was acting up..
room for improvement but too late in season
415/398 on e70
a few days later i pulled that drivetrain and spent the last year building this around it. Next year i plan to break 500whp with it. Just need a 4bar, some 1200-1400's and a toon
oh and it's ^^^ street legal!
no694terry is online now   Reply With Quote
Old 10-26-2018, 02:12 PM   #8798
TDagen
Member#: 163648
2002 Resurrected WRX
That thing is so rad. Every time I see a photo of that: "I am like what is it, how was it done?" LOL!
Old 11-04-2018, 01:30 AM   #8799
fgfgdfgrrre
Member#: 493582
Default c.com/forums/newreply.php?do=n
fgfgdfgrrre is offline   Reply With Quote
Old 11-04-2018, 01:34 AM   #8800
fgfgdfgrrre
Member#: 493582
Default ms.nasioc.com/forums/sh
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY Motion Lab Tuning Proven Power Bragging 125 04-12-2010 03:57 AM
jid2 Track Car - e85 ARMY jid2 Member's Car Gallery 38 01-22-2010 11:44 PM
The Honduran army is the bravest in the world... wrxcelent Off-Topic 36 07-07-2009 09:21 AM
Spacific E85 Tuning thread Here ? discopotato03 Engine Management & Tuning 1 09-09-2008 12:01 PM
Did anyone hear the one about the Italian army and the IRAQI satiation? Asinine Off-Topic 3 09-20-2005 08:06 PM
