Welcome to the North American Subaru Impreza Owners Club Thursday September 20, 2018
Old 02-13-2018, 09:04 AM   #1
Nomadic Logic
Member#: 135213
2012 2.0i Sport Prem
Default 2012 Impreza Sport - Odd Sound
I'm the original owner of my 2012 Impreza Sport (CVT), which currently has 86k on the odo.
I've noticed a sound getting progressively worse. It's a whirring or droning sound coming from the rear of the vehicle (I think it's the passenger side but I can't be sure). It starts to get noticeable at about 35 mph, is very loud from about 50-60 mph, and gets a little bit softer at speeds higher than that, but it's still there.
It does not change with pedal pressure. Coasting or not, it's still there.
Does anyone have any ideas?
Thanks.
Nomadic Logic is offline   Reply With Quote
Old 02-13-2018, 09:08 AM   #2
Obviously Tyler
Member#: 395955
2016 WRX
2018 Crosstrek
Possible wheel bearing. Does the sound increase in relation to speed or just get louder? Is it a rotational sound?
My other guess would be an axle or diff. But start at the hub/bearing. Maybe check your tires too. Move the tires around on the vehicle and see if the sound is coming from the same area.
Obviously Tyler is offline   Reply With Quote
Old 02-13-2018, 09:15 AM   #3
Nomadic Logic
Member#: 135213
It only gets louder with speed. There isn't a rhythm to it, if that makes sense. It's a constant sound that varies only in volume.
Old 02-13-2018, 11:51 AM   #4
v2rocket_aka944
Member#: 408701
wonder if the rearmost exhaust flange has loosened up a bit.
v2rocket_aka944 is offline   Reply With Quote
Old 02-14-2018, 04:19 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Most likely a wheel bearing.
Do a bit of swerving back and forth at speed and see if the noise changes in pitch or intensity. If it does, it's a wheel bearing. If it doesn't, it's tire or differential noise most likely.
CosmoTheCat is offline   Reply With Quote
Old 02-15-2018, 08:32 AM   #6
TylerD94
Member#: 482149
2008 Impreza OBS
+1 for wheel bearing. When I worked at Subaru, any time a car came in with a whirring noise from any corner that was the first thing they checked. Nine times out of ten it was always the wheel bearing was shot.
If I remember correctly, the rear bearings on the '12s weren't hard to remove. But if you have a lot of rust back there, be ready to bring out the air hammer/slide hammer
TylerD94 is offline   Reply With Quote
Old 02-15-2018, 04:18 PM   #7
Nomadic Logic
Member#: 135213
So it was indeed the wheel bearing (passenger rear).
$604 later, I'm good to go. Ugh.
Old 02-17-2018, 05:10 PM   #8
CosmoTheCat
Member#: 3409
98 My FMIC
Good stuff.
