06-16-2008, 11:38 AM | #1 |
Member#: 120057
Vehicle:2018 WRX (base) 6spd WRB |
Question about OEM 02-03 rear diffuser
Everyone says this is a oem part, but I have checked subarugenuineparts.comand there is nothing but the 06 one. I have an 04 with the rear spats that have the lip on the bottom it. Many bug eye owners have them in association with the oem rear diffuser. 2 questions.
Would this fit my car, some say it wont, Why? Where can this part be bought from?
06-16-2008, 12:51 PM | #2 |
Member#: 116123
NWIC
Vehicle:93 MR2 T Blue metallic |
Here is the 02 03 set. Don't know if it will fit your car though
https://www.subarugenuineparts.com/p...roducts_id=780 |
06-16-2008, 12:58 PM | #3 |
Member#: 170501
TXIC
Vehicle:2002 WRX PSM TXS Stage Eleventy |
It's discontinued, can only be bought in Aspen White, and won't fit the '04 bumper without a lot of modification because the bottom of the bumpers are totally different shapes.
06-16-2008, 01:33 PM | #4 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
The rear diffuser is an STI 2006-2007 OEM part, but there are three kits available to fit it to any pre 2006 STI or 2002-2007 non-STI model.
Subaru Genuine Parts, for example, sells two kits: One comes with OEM style bolt-on brackets The other comes with OEM style weld-on brackets A third kit, not available from SGP, is the Cusco frame bar and rear diffuser kit. The kit comes with a frame bar, forward bracket that mounts to the frame bar and a rearward bracket that mounts to two OEM points just below the rear bumper cover. The diffuser in this case uses four of the five mounting holes -- the center hole is not used. I have the Cusco kit. The diffuser is on there solid -- no rattling or flexing. I got this kit because I did not want to either drill holes or have welding performed. The Cusco kit is available through JSC Speed and other vendors. |
06-16-2008, 02:06 PM | #5 |
Member#: 170501
TXIC
^ You and the OP are not talking about the same things.
06-16-2008, 02:33 PM | #6 | |
Member#: 120057
06-16-2008, 02:39 PM | #7 |
Member#: 170501
TXIC
There isn't one that looks like them for later years.
06-16-2008, 04:22 PM | #8 |
Member#: 36135
Vehicle:2005 WRX Aspen White |
here's mine. it needed lots of work to fit my 05 bumper properly. just get an 02-03 rear bumper and you will have a much easier time fitting it on.
06-16-2008, 04:23 PM | #9 |
Member#: 120057
Like what did you have to do. I dont see how are back middle part of the bumpers are different
06-17-2008, 02:52 AM | #10 |
Member#: 36135
the 05 bumper is wider by about 3 inches and rounder whereas the rear lip is more angular. molding is needed and urethane is needed to fill in the gaps.
FS: 02-03 Rear Diffuser, Borla XR-1, Shift Knob, STi Pillow + Random Stuff | Rufryda | Tri-State Area Private Classifieds | 41 | 05-09-2009 01:15 PM |
putting a jdm 02-03 rear diffuser on a 05 wrx | esker | Interior & Exterior Modification | 16 | 01-04-2009 08:48 AM |
FS: WRB OEM 02-03 Rear Diffuser, $285shipped&paypalled | i50caL | Exterior/Styling | 2 | 08-17-2008 02:39 AM |
FT CT: OEM 02-03 rear diffuser/lip painted aspen white | bren wrx | Private 'For Sale' Classifieds | 2 | 02-24-2006 08:16 PM |
02-03 rear diffuser fits 04 wrx? | LqSilver | Interior & Exterior Modification | 1 | 06-09-2004 12:05 PM |
