Welcome to the North American Subaru Impreza Owners Club Saturday August 24, 2019
Old 01-18-2013, 07:42 PM   #1
Ziggyrama
Member#: 53665
2011 STI Stg2 w/ ELH
Focal 2way Active w/ DSP
Default SD card logging, alternative start/stop switch
If you're using SD card fast logging and you don't like using the defogger switch to trigger and stop the logging, there is an alternative. Personally, I don't like using the defogger as it pumps unnecessary current through the back window and if I really want to use it on the back window, I have to disconnect Tactrix so that I don't get extraneous logs on the SD card. For those of you with 08+ WRXs and STIs, there's a better way. Instead of the defogger, I decided to use the cruise control buttons on the steering wheel instead. The set button can act as a start and cancel button as stop. To pull this off, you have to change the logger configuration file and define a new way of starting and stopping the logger:
1. On the SD card, open LogCfg.txt text file with an editor of choice.
2. Add the following sections to the file which define cruise control buttons and how to use their signals to start and stop the logger.
Code:
; cruise set signal
paramname = cruise_set_coast
paramid = 0x000121
databits = 1
offsetbits = 5
isvisible = 0
; cruise cancel signal
paramname = cruise_cancel
paramid = 0x0000D7
databits = 1
offsetbits = 0
isvisible = 0
; start action,
conditionrpn = cruise_set_coast,1,==
action = start
; stop action
conditionrpn = cruise_cancel,1,==
action = stop
3. Comment out your current start and stop actions by placing semicolon in front of the section that defines your current start and stop actions. The logger will ignore them and if you ever decide to go back to using the defogger switch, you'll have an easy way to reference it.
Note, I tested this with latest EcuFlash version 1.44.3719.
How did I find these addresses? They come from RomRaider's logger definition file. I'm not sure if these switches vary between ROMs. Based on the definition file, they seem to be universal for all the ROMs.
Ziggyrama is offline   Reply With Quote
Old 01-23-2013, 07:01 PM   #2
stackedape
Member#: 344670
Look at you my Brotha, teaching the folk! hahaha
stackedape is offline   Reply With Quote
Old 01-23-2013, 08:42 PM   #3
Ziggyrama
Member#: 53665
Hey Bro, good to see you on the site!
Old 02-14-2014, 03:02 PM   #4
uk2006wrx
Member#: 331547
Thanks that's really useful to learn, and agree this is a neater way of triggering the logging.
uk2006wrx is offline   Reply With Quote
Old 12-16-2018, 08:37 PM   #5
pdximpreza
Member#: 17606
2008 STI hatchback
I know necro'ing threads bothers people. But search engines pull up this thread, and I don't find much information on it. So I thought I would post what I have found here so that others who do a Google search wont find multiple thread hits and have to try and dig through it.
Ziggy's information is great, unless you want to try and figure out what other alternate triggers you might want to use on your own.
First you can use ANYTHING the logger is capturing to start and stop the log. You can chose an RPM, coolant temp, throttle position, anything you are capable of and defined in your logcfg.txt. If you are like me, you are using the website http://romraider.com/logcfg/ to create the logcfg.txt from the Romraider profile. So you aren't digging into who its all figured out.
The addresses and offset bits are found in the logger definition .xml. So the latest I am using is logger_STD_EN_v346.xml. I use Notepad++ to open it because it allows me to collapse the file structure. I then did a ctrl+F 'find' for cruise, and I found what Ziggy used. Here is the line;
<switch id="S65" name="Cruise Control Set/Coast Switch" desc="S65" byte="0x000121" bit="5" ecubyteindex="45" target="1" />
Now the reason why I was motivated to write this is, how do you determine what that offset bit is supposed to be? Thats the bit=5 on that line in the logger def.
So for instance cruise resume is offsetbit = 4 instead.
So my next step is I don't want to use cruise set. I want to use the cruise light. I tried using the cruise toggle, but its only momentary so I get 3 lines of data. But nothing in the logger def is obvious for that light. So now I will log each of these cruise other cruise values, mainly;
<switch id="S77" name="Cruise Control Signal" desc="S77-TCU input." byte="0x00006A" bit="6" ecubyteindex="28" target="2" />
and
<switch id="S133" name="Cruise Control System Status" desc="S133" byte="0x000121" bit="0" ecubyteindex="45" target="3" />
To see if one of those holds a high 1 status like the 'cruise' on light on the dash.
So I will just add this to my logcfg.txt;
; Cruise Control Signal
paramname = Cruise1
paramid = 0x121
databits = 1
offsetbits = 6
; Cruise Control System Status
paramname = Cruise2
paramid = 0x121
databits = 1
offsetbits = 0
Unfortunately with the cruise status I have to drive the car because of the cruise inhibitor when its not running or moving... But normally you can just go plug the OP2.0 in and turn the key over to power up the ECU and press the switches you're going to use. Then check your log. If it works then you can add the isvisible = 0 so its no longer logged and then configure your trigger with that paramname.
I think I'll have to go through and edit that sound it makes sense outside my head.
pdximpreza is offline   Reply With Quote
Old 12-16-2018, 09:56 PM   #6
Ziggyrama
Member#: 53665
Nice job! Wow, I totally forgot I wrote this up few years ago. Glad to see folks find it useful.
Old 12-17-2018, 12:07 AM   #7
pdximpreza
Member#: 17606
2008 STI hatchback
Thank you! There is honestly almost nothing regarding this topic! But it allows so much possibilities. Like logging if it starts knocking. Or logging if it starts over heating. But the only examples are RPM and the defroster. This thread was the only thing that gave me hope at doing something more haha.
Cheers!
