Welcome to the North American Subaru Impreza Owners Club Friday August 23, 2019
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > 1993 - 2001 Impreza Specific Parts
Old 08-25-2017, 08:33 AM   #1
BlobeyeSTi
Member Sales Rating: (41)
Member#: 187877
04 FXTi
OMGHi2U WV: 1999 & 2000 RS Coupe Part Out
Parts are from 1999 and 2000 RS coupes both 5 speeds.
Located in Fairmont WV & shipping isn't a problem just message me for a quote. If you want pictures of a certain part just ask.
*Links to albums of individual pictures of each part are located beside each group*
GC Parts
Engine & Drivetrain Pics: https://imgur.com/a/F23PkWq
• Intake manifold $50
• Rear subframe $40
• Engine crossmember $80
• Rear differential carrier 'T' subframe $50
• Rear differential $50
• Transmission subframe $25
• 5 speed transmission *$400
• Transmission mount $20
• Gas cap $10
• Fuel pump $20
• Fuel pump assembly $20 (1 piece broken)
• Fuel lines $50
• Fuel pressure regulator $25
• Injectors $40 set
• Clutch master $30
• Slave cylinder $30
• Steering rack $75
• Throttle cable $10
• Power steering pump $70
• Power steering reservoir $15
• Power steering reservoir bracket $5
• Ignition coil $20
• Plug wires $40 set
• Throttle body $40
• Oil fill neck and cap $15
• Cam gears $10
• Axle with one busted CV joint $25
• Intake silencer $10
• Coolant overflow tank $10
• Radiator fans $25 each
• Valve covers $40 set
Suspension & Brakes Pics: https://imgur.com/a/vaSJf0R
• Sway bars $40 each
• Lateral links $20 each
• Trailing arms $40 set
• Endlinks $20 set
• Control arms $25 each
• Brake booster and master $40
• Front ABS sensors $15
• Front brake caliper mount $5
Exterior Pics: https://imgur.com/a/l3wK1sO
• Taillights $75 each
• Scoop black $75
• Hood vents blue $40 each
• Driver door black $100
• Rear bumper $75 (blue & black available)
• Front bumper beam $60
• Black trunk with small wing (no dents needs repainted) $50
• Blue trunk with small wing (has few dents) $50
• Inner fenders $10
• Door windows $40 each
• Hood release cable $10
• Roof trim $40 each (Shipping is really expensive due to size)
• Windshield trim $25 each
• Wiper cowl $25
• Wiper motor & linkage $40
• Sunroof frame $50
• Driver Taillight trim blue $20
• Taillight trim black $20 each
• Quarter panel trim $10 each
• Hood prop $5
Interior Pics: https://imgur.com/a/zlSelwm
• Steering Wheel $20
• Driver airbag $40
• Dash bar $50 (2 available)
• Door handle $20
• Hood release handle $5 (2 available)
• ECU cover $10
• Wire covers for inside door kick panel $10 side
• Fuel pump cover $5
• Gas pedal $20
• Blower motor $50
• Dash cup holder $10
• Rear view mirror $20
• Map light $10
• Seatbelts $40 (no driver front or rear center but have the rest)
• Steering column $50
• Speaker brackets $5 set (2 available)
• Weatherstripping $5
• Tweeter cover $10 each
• Door handle trim and pocket $10 set
• Door panel bolt covers $5 set
• Gauge cluster surround $10
• Seat bolt covers $10 set of 4
• Passenger A pillar $15
• Rear heat vents $20 set (2 available)
Electronics Pics: https://imgur.com/a/3779vWz
• Knock sensor $10 (2 available)
• Sunroof harness $10 (2 available)
• Interior fuse box $20
• Engine bay fuse box $20
• Door ajar sensor $10
• Horn and cruise control steering wheel switch $20
• Antenna with screws $25
• Wiper switch $20
• Airbag sensors $10 each
• Airbag harness $25
• Airbag control unit $25
• Alternator to battery cable $10 (2 available)
BlobeyeSTi is offline   Reply With Quote
Old 08-25-2017, 09:27 AM   #2
BlobeyeSTi
Member#: 187877
04 FXTi
Old 08-25-2017, 09:28 AM   #3
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 08-25-2017, 09:31 AM   #4
blitzinq
Member Sales Rating: (6)
Member#: 335825
2003 Subaru WRX
How much for side skirts plus shipping? Or local pickup/meet? Depending where you are in WV I might not be far away.
blitzinq is offline   Reply With Quote
Old 08-25-2017, 09:41 AM   #5
BlobeyeSTi
Member#: 187877
04 FXTi
bump.
Old 08-25-2017, 10:56 AM   #6
94VRotary
Member Sales Rating: (1)
Member#: 442744
2004 WRX STi
Is the driver side window regulator any good?
Do you also have door panel brackets & 5mt vss?
part # for door panel brackets: 94230 FA170/180
94VRotary is offline   Reply With Quote
Old 08-25-2017, 12:23 PM   #7
BlobeyeSTi
Member#: 187877
04 FXTi
^PM sent
Old 08-25-2017, 10:26 PM   #8
Yarbleck
Member#: 371561
1996 Impreza LX 2.2
It's a manual I'm hoping. With abs. Looking for the abs computer and harness from under the passenger seat. It stretches to fuse box on drivers side and through the passenger side firewall to speed sensors and g sensor. Looking for the computer, sensors and full harness. Have cash.
Yarbleck is offline   Reply With Quote
Old 08-26-2017, 03:28 PM   #9
BlobeyeSTi
Member#: 187877
04 FXTi
^PM sent and ya its a manual
Old 08-27-2017, 06:18 PM   #10
BlobeyeSTi
Member#: 187877
04 FXTi
updated OP
Old 08-30-2017, 11:21 AM   #11
BlobeyeSTi
Member#: 187877
04 FXTi
Bump...
Old 08-30-2017, 01:08 PM   #12
mellow
Member Sales Rating: (7)
Member#: 183181
2005 Forester XT
PM sent
mellow is offline   Reply With Quote
Old 08-30-2017, 02:34 PM   #13
sk8eroyaker
Member Sales Rating: (3)
Member#: 328067
2008 SWP WRX (sold)
2000 BRP RS Coupe
Do either of them have a rubber trunk liner? Been on the hunt for one for a while.
sk8eroyaker is offline   Reply With Quote
Old 08-30-2017, 03:43 PM   #14
BlobeyeSTi
Member#: 187877
04 FXTi
Originally Posted by mellow View Post
PM sent
Replied
Nope sorry. All I have is the side pieces for the trunk
Old 08-30-2017, 05:13 PM   #15
BlobeyeSTi
Member#: 187877
04 FXTi
Updated the OP with a bunch of pictures. Working on a parts list
Old 09-01-2017, 01:12 PM   #16
BlobeyeSTi
Member#: 187877
04 FXTi
bump...
Old 09-05-2017, 03:37 PM   #17
BlobeyeSTi
Member#: 187877
04 FXTi
OP Updated with a list of parts. If there isn't a part on the list or want a picture of a certain item just ask.
Old 09-07-2017, 03:50 PM   #18
BlobeyeSTi
Member#: 187877
04 FXTi
Bump!
Old 09-07-2017, 06:35 PM   #19
Techie Will
Member#: 76687
2017 WRX STI HUS02
World Rally Blue
PMing about door cards
Techie Will is offline   Reply With Quote
Old 09-08-2017, 10:35 PM   #20
BlobeyeSTi
Member#: 187877
04 FXTi
Replied
Old 09-13-2017, 05:07 PM   #21
BlobeyeSTi
Member#: 187877
04 FXTi
Bump...
Old 09-16-2017, 07:32 PM   #22
BlobeyeSTi
Member#: 187877
04 FXTi
Bump!
Old 09-18-2017, 05:19 PM   #23
BlobeyeSTi
Member#: 187877
04 FXTi
Bump!
Old 09-18-2017, 10:57 PM   #24
blitzinq
Member#: 335825
2003 Subaru WRX
Pming you!
Old 09-19-2017, 08:52 PM   #25
BlobeyeSTi
Member#: 187877
04 FXTi
Originally Posted by blitzinq View Post
Pming you!
Replied
