Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 07-16-2019, 12:25 PM   #1
Rabbit Farmer
Member#: 46095
Default Proflex coilover springs... how to read the numbers
Searching the entire internet has yielded very little.
Does anyone know how to read the numbers on Proflex coilover springs?
Front: Proflex 26-420
Rear: 30-60 TDI
I found on a motorcycle website (and a different spring manufacturer), that the first number is rate in N/meters and second is length in MM. That doesn't work... reversing it makes sense on the fronts (420 N/M = 310 ft/#) and the length could work if CM (26 CM = 10 inch). But... none of that works for the rear springs.
Thank you
Steve
Rabbit Farmer is offline   Reply With Quote
Old 07-23-2019, 01:29 AM   #2
Rabbit Farmer
Member#: 46095
One response I got was "26KG" and "420 is the length"
Which could make sense if 26 KB per CM (vs. pounds per inch) and 420mm.
Still unsure about rear springs.
Old 07-23-2019, 01:24 PM   #3
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
You can measure the length of spring yourself. That could help you figure out one of the numbers at least.
AndyRoo is online now   Reply With Quote
Old 07-23-2019, 02:48 PM   #4
Rabbit Farmer
Member#: 46095
That is true, but I donít want to inconvenience the owner too much ad he has it in storage.
