Welcome to the North American Subaru Impreza Owners Club Tuesday August 20, 2019
Old 07-19-2019, 04:22 PM   #1
dhatcher
Member#: 276377
2018 WRX
World Rally Blue
Default Coilovers for autocross and daily driving
I'm currently daily driving and autocrossing a 2018 wrx in d street. I'm planning to trade in for a 2019 STI just for the better transmission, brakes and lsd.
On my WRX I added Cusco Touring A struts to the OE springs to help with body roll and they improved the body roll a bit but, for the STI, I'm thinking I'm just going to go ahead and put coilovers in and jump into the STU class and then figure out what else I want to add as I gain more experience in that class.
Looking at budgeting $1,500 for the coilovers. What are some recommendations for a set that will give me a good benefit towards autocross? Mainly looking to control body roll and attempting to keep the rear wheels planted as much as possible (even though the STI does have the lsd, I still want to keep all 4 wheels touching as much as possible).
I don't track the car and don't plan to. Strictly autocross and daily driving. If it makes any difference, I'm planning to keep the 19" wheels and just run the Bridgestone RE71R's on them.
dhatcher is offline   Reply With Quote
Old 07-19-2019, 05:22 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Feal 441 or even the 441 long travel with swift springs are pretty close to your budget.
Then figure in install (if you're not doing it yourself), corner balance (because you're after performance and not stance), alignment.
Bump your budget to 2K and see if you can make all that work out.
Turn in Concepts is online now   Reply With Quote
Old 07-19-2019, 05:47 PM   #3
dhatcher
Member#: 276377
2018 WRX
World Rally Blue
Thank you, appreciate it! And yes, the $1,500 is just for the hardware. Not factoring install and corner balancing etc. That's separate budget
Old 07-22-2019, 05:11 PM   #4
Mike_Feal
Member#: 462296
2003 Lexus IS300
2JZ 620HP/595TQ
Feal 441+ will work for a mix of comfort or light track use, probably your best bet out of our lineup. If you are more serious about track performance and not too worried about comfort the 441+ Road Race are a much more aggressive setup for the track and include custom valving and spring rates to match your specific setup. The guys at Turn In can offer some great insight on setup for you.
Mike_Feal is online now   Reply With Quote
Old 08-02-2019, 02:42 AM   #5
JMH332
Member#: 487065
2018 WRX
I just finished installing Racecomp Engineering Super Street 1 coilovers on my 18 WRX and had it aligned yesterday. It's lowered just over a half an inch and I have the rebound adjustment set at 5 clicks from firm in the rear and 8 clicks from firm in the front. I also installed some rear adjustable LCAs and have alignment set to -1.80 front and -1.50 rear, with 0 toe and stock caster (6.50 I think). The rear toe was fine so I didn't install adjustable toe links which I have.
I have corner balanced the car and currently am at 49% cross weights and will be installing a lightweight battery this weekend to take some weight off the left front, and checking the cross weights again. Total vehicle weight with 1/4 to 1/2 tank is 3245 pounds with the spare tire and jack.
Oh yeah, it's on Advan TC4 18x9.5 -45mm wheels and 265/35/18 Re71Rs
I have not driven the car a lot, but it feels very good, with sharp turn in and nice ride. The front feels more compliant than stock and the rear feels similar to stock. I plan to drive more this weekend, but so far, I am very pleased.
I think the looks are just right, modestly lowered and no poke, and no fender roll... the inner clearance to the coilovers is also greater than the 5mm minimum recommended by Racecomp, so I think I'm good to go.
The car handled quite well at the track in stock form so I'll have to get back out there... I suspect I'll have quite a bit better overall grip due mostly to the wheels and tires, although I'm looking forward to tinkering with the shock setting to dial out some of the stock understeer, which was much less that I expected, BTW. The alignment specs should help that too.
Myles at Racecomp is very good to deal with
Jim
JMH332 is offline   Reply With Quote
Old 08-04-2019, 08:36 PM   #6
subaru_gc8
Member#: 29292
2004 WRX wagon
I would save up and get some inverted coilovers. I have had bilstein, ohlins and I have the feals max travels, there is a big difference in they way they absorb bumps. the bilsteins and ohlins are much better but they are much more expensive, just saying that if you are willing to save your money that you can get a much better coiliver.
subaru_gc8 is offline   Reply With Quote
Old 08-06-2019, 11:00 PM   #7
uofime
Member#: 421271
2015 WRX
Galaxy Blue Pearl
Jim
If youd be so kind please post back here with further impressions once youve had more time with the car and done an event or two. Im very interested to hear how it goes since I think those are the front runner for me.
uofime is offline   Reply With Quote
