Welcome to the North American Subaru Impreza Owners Club Thursday August 22, 2019
Old 04-09-2001, 07:17 AM   #26
hotsam
Member#: 3862
Post
* Manual
* 4/8/00 ~1500 miles
* Didn't take it to the dealer
* Van Bortel
* I reset the ECU, tightened the gas cap
hotsam is offline   Reply With Quote
Old 04-09-2001, 04:01 PM   #27
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
ttt - I spoke with the regional (NW) SOA service person and he said he was not aware of SOA HQ issuing a TSB on this problem.
From my limited calls, dealers in this area are only just beginning to get aware of it (parts guy at Carter sounded like he just got the clue to order a few more valves, they don't have any).
It seems SOA will have to wait to see a lot of calls to the tech hotline and a lot of this part ordered under warranty to figure out there is a larger problem.
My light went off this morning.
Glenn
ANZAC_1915 is offline   Reply With Quote
Old 04-09-2001, 07:39 PM   #28
AutoXr
Member#: 2047
'04 Audi S4
Red
Post
  • Manual
  • 4/5/01 - ~1250
  • P01443
  • Continental Subaru
  • Currently diagnosing this code on another car and will contact the owner (me) when the problem has been isolated
Other items to note:
  • I had just taken on 5 gallons of 90 octane gas with 1/4 tank of 92 octane remaining
  • Just about to enter a corner at about 45 miles per hour and had lifted throttle
AutoXr is offline   Reply With Quote
Old 04-09-2001, 09:10 PM   #29
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
Interesting, mine came on when I lifted throttle about to turn into work.
Old 04-10-2001, 09:15 AM   #30
JahWind
Member#: 1988
Post
Sedan-Manual 830 mi.
P01443
Subaru of Santa Cruz
Didn't find anything unusual and they are reporting to district or national service reps.
Reset ecu and fine so far.
JahWind
JahWind is offline   Reply With Quote
Old 04-10-2001, 10:16 AM   #31
jimbo02
Member#: 4017
Post
*Manual
*CE light came on at 500,1000 and 1200miles, went off by itself first 2 times
*Carter Subaru, Seattle,WA
*Code P0303, misfire on cylinder 3
*Dealer is replacing sparkplug as I write this. I will talk to him about swapping injectors between cylinder #1 and #3 as I suspect that the plug isn't the problem.
RESULT: They replaced defective sparkplug. I now have 1800 miles and no problems with missing or CE light since fix. Also worth noting. They had to order the sparkplug and said at the time there were only 26 available in US. Hopefully this will change. So it was in the shop 4 days just for sparkplug.
Text
[This message has been edited by jimbo02 (edited April 26, 2001).]
jimbo02 is offline   Reply With Quote
Old 04-13-2001, 10:29 AM   #32
dave-o
Member#: 3609
Post
* Manual
* 4/13/00 ~2300 miles
* Didn't take it to the dealer yet
* Santa Cruz Subaru
* No action yet...
dave-o is offline   Reply With Quote
Old 04-14-2001, 11:37 AM   #33
Trevers
Member#: 3883
2008 WRX STI
Post
Manual Trans...
1550 Miles...
Off at 2100 Miles, this I attribute to the fact that I have started the car 4 times since the light came on.
Took it to the dealer code P1443 - vent control solinoid. Reset it and sent me on my way.
Happened the first time that I ran the AC.
[This message has been edited by Trevers (edited April 17, 2001).]
Trevers is offline   Reply With Quote
Old 04-16-2001, 11:17 AM   #34
orbit03
Member#: 2300
2002 Impreza WRX
Banana Pudding
Post
Got my second CE light. I posted earlier in this thread, but wanted to add my second experience.
-5-spd
-Came on at 867miles (4/12) off at ~950miles (4/14)
-Code P1443 (same as first time)
-Took to New Motors in Erie, PA (same as before)
-Mechanic read code, reset, sent me on my way. He called SOA, they said they are working on it (the P1443 and the misfire in cyl 3 are common). He personally expects a CPU reburn/replace in the coming months.
orbit03 is offline   Reply With Quote
Old 04-16-2001, 05:54 PM   #35
Blackskull
Member#: 5616
2002 Impreza WRX
Post
Manual
On at 250 miles 4/10.
Code P1443 (vent control solenoid)
Dealer reset 4/12. Hasn't come on since.
Don Docksteader Subaru
Dealer checked code, checked vent control solenoid (was good), reset code.
Blackskull is offline   Reply With Quote
Old 04-16-2001, 06:23 PM   #36
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
Post
*Manual
*1530
*P0340 Cam Angle Sensor
*Don Beyer, Alexandria, VA
* I was lucky as a Subaru Technical Rep was at the dealership when I brought my car in for the 2nd CEL. He said that the cam angle relative the the crank position is what is causing the fault code. They don't know why some WRXs have this prob and others don't but the number is substantial and they are working on fixing the problem. It is a problem but the car is in no danger of being harmed he noted. What's interesting is that the light came on under hard acceleration both times. OB2 software takes a snap shot of what the engine was doing at the time of the fault. It was at 6750 RPM @ 44 KPH or wide open in 1st gear. He didn't imply that i was doing anything wrong but did state this. I drive like this every day and this car should be able to take it! He told me to reset the computer by cycling the key on an off 4 times and that the fault codes will be stored for them to check later.
The CEL light came back on once again later that evening under the same driving style but the light cleared itself.
I hope this helps everyone out.
motoxphil is offline   Reply With Quote
Old 04-16-2001, 08:50 PM   #37
Mr. Ixnay
Member#: 3707
2006 Legacy Spec. B
Titanium Silver Metallic
Post
-Manual
-04/16/2001, 1543 miles
-vent control solenoid code
-Pence Subaru
I was able to get my car back after being in the shop for two days. The part is on order. I have driven it 200 miles without the CE light coming back. I am not too worried about it now. Glenn convinced me it's no big deal
04/26/2001 - Dealer Replaced Evaporative Drain Valve (vent control solenoid thingee).
[This message has been edited by Mr. Ixnay (edited April 22, 2001).]
[This message has been edited by Mr. Ixnay (edited April 26, 2001).]
Mr. Ixnay is offline   Reply With Quote
Old 04-18-2001, 10:11 AM   #38
Prog
Member#: 1473
2005 Legacy GT 5MT
Satin White Pearl
Post
I guess my knocking on wood didnt work, my car is 2044 miles old or so, and i got the CE light during lunch, it was after a downshift/hard accel..
The car feels slower, but it may be a placebo effect, since it idles/sounds just like it were normal, and it still boosts, although it feels like its boosting less..
oh and my info:
* Manual
* 4/18/00 ~2044 miles
* Havent Taken it in
* AutoPlaza/Trebol Motors (in PR)
[This message has been edited by ProgWRX (edited April 18, 2001).]
Prog is offline   Reply With Quote
Old 04-18-2001, 10:47 AM   #39
paulw
Member#: 4507
05 STI
Aspen White- No wing
Post
625 miles
4/17/01
Carr Subaru (in right now)
Made a hard right uphill turn and the light came on and has stayed on.
paulw is offline   Reply With Quote
Old 04-19-2001, 08:46 PM   #40
Greg I
Member#: 384
2002 Acura RSX-S
Post
5spd, no mods.
On at 1540mi (~80MPH, lifting throttle on highway)
Off at about 1700mi
No code pulled yet; will get it checked at first oil change. Noticed no difference in the behaviour of the car either while the CEL was on, or after it went off.
Greg.
[This message has been edited by Greg I (edited April 19, 2001).]
Greg I is offline   Reply With Quote
Old 04-19-2001, 09:37 PM   #41
blkwag
Member#: 4838
2002 WRX Wagon
Black in Recovery...
Post
I just received some info from my dealer and they are being told that it could be a faulty construction in the passenger rear where the charcoal canister is. They have actually reported leaks due to cracks in the hose or assembly. I will check mine this weekend for anything visible.
blkwag is offline   Reply With Quote
Old 04-21-2001, 03:26 PM   #42
Bugsie1
Member#: 72
2008 BMW Z4M Coupe
Post
5 Speed Wagon
ON at 1906 miles
OFF somewhere in 1907-1910 miles
No code (fixed itself)
other details:
1/4 tank
accelerating in first gear
K&N filter & Silencer Mod
filled the tank and it turned off the next morning
[This message has been edited by Bugsie1 (edited April 22, 2001).]
Bugsie1 is offline   Reply With Quote
Old 04-21-2001, 07:53 PM   #43
eprklims
Member#: 5991
Post
* transmission: manual
* CE at 160kms (last week - first day i got my car!!)
* codes: P0301 and P0303 - cylinder misfires in #1 and #3
* dealer: Oakville Subaru
* they weren't able to look at it until they have their lead guy there... hopefully this week
Does anybody have any clue as to the long term effect of these misfires? I'm pretty worried about it, but i might just be over cautious
eprklims is offline   Reply With Quote
Old 04-22-2001, 09:12 PM   #44
ScoobyDriver
Member#: 195
2001 BH9
Thumbs down
Hi, up until today I hadn't gotten the infamous light. It came on after a high rev pass at Auto-X. After my drive home it was still on. But later when I went for a trip to the store it was off. I won't reset the ECU until the dealer checks it.
* transmission - manual
* 04-22-2001 / 1555 miles
* what code ??
* Morries Subaru
* no action yet
Shane Kullman
'02 WRX Blue
ScoobyDriver is offline   Reply With Quote
Old 04-23-2001, 05:15 AM   #45
Force[FED]
Member#: 292
2011 BMW 535i
Havana Metallic
Post
Scoobydriver, I had the same situation. 1600+ miles and no CE light. Ran my first autox yesterday, and it was on after my 2nd run. :/ Oh well, I will let everyone sort it out, and when they figure out the 'fix', I will get it taken care of. I am sure it will turn itself off soon.
Kev
Force[FED] is offline   Reply With Quote
Old 04-23-2001, 09:59 AM   #46
ScoobyDriver
Member#: 195
2001 BH9
Post
Funny, mine was after the second run also. Must be a warmed up hot something situation.
Shane Kullman
'02 WRX Blue
Old 04-23-2001, 07:39 PM   #47
scoobysport
Member#: 1671
'16 WRX Sport
Post
* Manual
* 4/23/00 ~2500 miles (3/4 tank of gas)
* code: P1443
I just installed a K&N air filter yesterday, however, it seemed to happen when I lifted my foot of the gas. Dealer (specialty subaru) found nothing wrong, so reset ecu.
Brian
[This message has been edited by scoobysport (edited April 24, 2001).]
scoobysport is offline   Reply With Quote
Old 04-23-2001, 09:38 PM   #48
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
Mine came on when I was coming off the gas in 2nd, turning into work.
Old 04-24-2001, 12:48 AM   #49
SLOMatt
Member#: 5040
2002 WRX Cobb Stg2
Platinum Silver Metallic
Post
* Manual
* 4/19/00 ~1700 miles (1/4 tank of gas)
* Taking it to the dealer today
SLOMatt is offline   Reply With Quote
Old 04-24-2001, 02:17 PM   #50
tacksharp
Member#: 5257
Unhappy
* Manual
* 4/21 on at 2025 mi. - 4/23 off at 2113 mi.
* Haven't taken to dealer yet.
* Carlsen Subaru (Bay Area)
Dang, I thought I was home free after 2K CEL-free miles... I was taking it easy in the mountains when it came on. When I started the car for my 4th trip after coming on (the car was off for only 2 minutes between the 3rd and 4th trip), it turned off. The car runs fine. I'll get the code when I take it to get the oil changed.
tacksharp is offline   Reply With Quote
Little Help please stock 06 WRX Check engine light Jkmaynard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-08-2008 10:33 PM
2004 wrx check engine light fix kbcr3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 02-21-2005 05:29 AM
o4 wrx check engine light came on? shaka17yeah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2004 04:00 PM
WRX Check Engine light log albunny88 New England Impreza Club Forum -- NESIC 1 05-18-2001 11:45 AM
