10-15-2014, 11:23 PM | #1 |
Member#: 360509
E. Canada
Vehicle:2005 2.5RS Wagon Red |
Speaker buzz from ONE speaker - no amp.
Hey guys, I have a 2005 impreza RS. I've had a pioneer x6500BT for a little over a year now. I recently changed out the front speakers for 6.5 inch polk audio speakers. I have no amp or subs.
The problem I am having is that the passenger side speaker is always buzzing when the engine is running. I can't hear the buzzing when music is playing, but if the volume is low or I'm using the BT to make a phone call, I'll hear the buzzing and it drives me nuts. Keep in mind: the speaker only buzzes when the engine is running. Troubleshooting I've done: I put the stock head unit back in... same thing. I put the stock speaker back on that side, it still sounded like it was buzzing but the buzzing was so quiet cause the speakers are so ****ty that I guess I could never hear it from the driver seat? Any ideas? Thanks.
10-16-2014, 08:31 AM | #2 |
Member#: 138957
Vehicle:2016 WRX STI Limited DGM |
Sounds like the speaker wire is running next to a power wire somewhere. Advise is check your wire run to areas it is near a power wire and try to minimize it as much as possible.
10-16-2014, 05:35 PM | #3 |
Member#: 360509
E. Canada
10-16-2014, 08:15 PM | #4 |
Member#: 138957
All along the speaker wire run from the head unit to the speaker. Any power wires running along near by need to be separated from the speaker wire as much as possible or noise can be induced.
10-16-2014, 10:50 PM | #5 |
Member#: 360509
E. Canada
Ah okay, I'll check that tomorrow morning. THANKS! Is there a common thing that it may be near that I should look out for? Do you think adding a ground to anything will help? Like head unit?
10-16-2014, 11:17 PM | #6 |
Member#: 22863
Vehicle:2015 WRX, 2022 Fozzy Painted fender collection |
Speaker wires don't pick up noise. It is possible for preamp level signals to pick up noise, but even that is uncommon. I am assuming that is not the case since there was no mention of an amp. Most likely something is wrong with the speaker or the head unit. Switch the speakers and see if the buzz switches. If it does it's the speaker. If the buzz remains with the other speaker it's something in the head unit. You can also just take it out the buzzing speaker and hook it up to a home stereo to see if it buzzes.
10-16-2014, 11:45 PM | #7 | |
Member#: 138957
10-16-2014, 11:51 PM | #8 |
Member#: 138957
Your head unit should already have a ground attached to it on your year impreza it was a quick disconnect on the side of the bracket, if not definitely reconnect. Not having the casing grounded results in a floating ground for it and often causes weird EMI problems that can be a pain to trace otherwise.
10-17-2014, 06:59 AM | #9 |
Member#: 392683
Vehicle:2014 LS hatch quartz blue |
10-17-2014, 06:59 AM | #10 | |
Member#: 22863
I just re-read the original post and didn't realized he already swapped head units and speakers. If the stock unit is making the noise as well it's possible the speaker wire has somehow been damaged. I would try running a new speaker wire to the speaker temporarily and see if that kills it. Maybe the stock wire was somehow damaged. Unlikely, but possible. It's also possible that the noise is in all speakers and he only hears the passenger door because it's on axis. Last edited by rexster; 10-17-2014 at 07:44 AM. |
10-17-2014, 08:28 AM | #11 |
Member#: 138957
Quick google search and http://www.cablestogo.com/product/29...I_saAldl8P8HAQ
10-17-2014, 08:37 AM | #12 | |
Member#: 138957
10-17-2014, 01:22 PM | #13 | |
Member#: 392683
ground loop isolation is just a bandaid to the bullet wound. Find the root problem, and fix it. OP, to aid in troubleshooting, try running new temporary speaker wire directly from the source to the speakers and see if the problem still exists. You dont need to run it behind all the panels and what not, we are just trying to help narrow down the issue. If you still hear the noise, we will investigate further. |
10-17-2014, 03:22 PM | #14 |
Member#: 360509
E. Canada
Alright I'll do it asap and then get back. Thanks guys.
10-17-2014, 06:40 PM | #15 |
Member#: 22863
That is in wall speaker wire that is used for nearly all home and commercial applications where you have much longer runs, usually higher resistance, and 120 or 220 voltage lines. I have used it in cars, and have worked in shops that use it as the default wiring for car installs. But not because it's insulated, because it's easier and neater to run one wire instead of two, and it has good protection against being punctured. I ran some 16/4 in my wrx from my amp to the head unit for the rear channels in case I ever want to hook up rear speakers. If speaker wires picked up noise, every production car built in the last 40+ years would be buzzing, because they all run the speaker wires along the same looms of wire that carry voltage throughout the car.
10-17-2014, 06:42 PM | #16 | |
Member#: 138957
Yeah, I'm not suggesting he use it either as it is not needed in a car. It was just a statement that EMI intrusion does happen in 12VDC environments and this stuff exists after someone said it doesn't happen. I have only ever used it in high EMI (not voltage) or security environments where source and receiver isolation is important. OP, have you confirmed that your head unit is in fact grounded? Most of what we all are suggesting pretty much goes out the window if your head unit isn't grounded. There should be a separate quick disconnect ground that connects to the mount since the dash frame is plastic. I think it was on the passenger side near the back if that helps. |
