Welcome to the North American Subaru Impreza Owners Club Wednesday October 28, 2020
Old 08-30-2020, 07:54 PM   #1
angrychicken
Member#: 202970
1983 Westfalia EJ25
Default P0021 code
While driving my 08 WRX on the freeway my CEL came on, code is P0021. Car drives great, no changes in power or noises. Oil was little low, I topped it off and reset the ECU. CEL comes back on after a bit.
A few months ago, a turbo went out, a new one went in, did a through flush and replaced all the banjo filters, and AVCS sensors. Car is basically stock, with the exception of a v40 turbo and open source tuning after the turbo swap. Oil looks clean now, no particulates noted and the car is building boost. T-belt, water pump, all belts/pulleys were done within the past 3 months. All done around the same time. Before that was getting 23-24 mpg. Could this be a bad sensor?
Is there anything I should be checking?
Thanks in advance!
angrychicken is offline   Reply With Quote
Old 08-31-2020, 07:31 AM   #2
Jay11STI
Member#: 492422
2011 STI
Have you replaced the OCV (Oil control Valves)
Please search, i feel like this has been covered multiple times on this forum.
Jay11STI is offline   Reply With Quote
Old 10-03-2020, 05:48 PM   #3
angrychicken
Member#: 202970
1983 Westfalia EJ25
Still trying to figure this out. Car is still driving good.
Old 10-03-2020, 08:24 PM   #4
akritzer
Member#: 511749
2013 WRX Hatch
Check to see if your AVCS solenoids (OCVs) are both equally advanced while cruising and at idle. You may have had one go bad. Did you reuse your solenoids after your turbo went?
akritzer is offline   Reply With Quote
Old 10-03-2020, 09:11 PM   #5
angrychicken
Member#: 202970
1983 Westfalia EJ25
There were both replaced along with all banjo filters. Did 2 oil flushes that time and 3 more over the next 2-3 weeks for good measure. Prolly overkills.
I also replaced the passenger side AVCS when that CEL came on, no changes though.
Old 10-04-2020, 04:24 PM   #6
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Why don't you check the banjo filters and make sure they are both still clean...?
I believe there is a test for the OCV using a 9volt battery.
Ask google.
Max Capacity is offline   Reply With Quote
