Welcome to the North American Subaru Impreza Owners Club Tuesday October 20, 2020
Old 12-11-2018, 08:28 PM   #1
Awdthony
Member#: 494783
2006 WRX STI
World Rally Blue
Default $600 Closed Deck?
Has anyone got their EJ Closed Decked here?
Awdthony is offline   Reply With Quote
Old 12-11-2018, 09:20 PM   #2
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Looks like he used a pretty thick material for the deck. I'd be curious what material he used for the deck, in regards to thermal expansion.
Old 12-12-2018, 12:05 AM   #3
Awdthony
Member#: 494783
2006 WRX STI
World Rally Blue
The sales rep is a really kind lady, her name is Candy. I didnt quite ask much because i came across them by accident from a friend of mind saying something element tuning
Old 12-12-2018, 10:08 AM   #4
Awdthony
Member#: 494783
2006 WRX STI
World Rally Blue
They look pretty good and i havent seen any bad responses on anything about it
Old 12-12-2018, 11:08 AM   #5
Waddlz
Member#: 395275
2012 STi
emerald coast is built ej on facebook. they post amazing quality stuff and everyone seems to be really happy with their products.
I've been wanting to get a builder EJ case halves and send in for CD.
Waddlz is offline   Reply With Quote
Old 12-12-2018, 12:07 PM   #6
Jedi03
Member#: 491095
2009 STi Blue
its only a service...you need to send them the case...looks like a pretty well setup shop tho, they do their stuff through ebay primarily from what i could find...
Jedi03 is offline   Reply With Quote
Old 12-13-2018, 12:08 AM   #7
Awdthony
Member#: 494783
2006 WRX STI
World Rally Blue
Update
$600 Closed Deck
$250 Bore & Hone ( if you go above 99.50 )
$400 Assembly ( if you opt for it )
+ (Whatever Parts )
Old 04-02-2020, 07:59 PM   #8
alexmartynyuk
Member#: 191967
2005 EVO VIII
@boost_reality
Any updates on this? Has anyone used these guys recently? how is your build holding up?
alexmartynyuk is offline   Reply With Quote
Old 04-03-2020, 10:46 AM   #9
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
https://www.iagperformance.com/IAG-Closed-Deck-Subaru-Engine-Case-Conversion-p/iag-mss-1400.htm
Just pay $400 more and have something proven and tested to 1200hp
user1029 is offline   Reply With Quote
Old 04-03-2020, 11:25 AM   #10
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Looks good. I'd make sure coolant ports match up with head and gasket though.
Old 04-11-2020, 06:31 AM   #11
Fozzanator
Member#: 446204
I am just getting done building a short block with some of their machine work. I bought from them a couple months back and have measurements that I went thru and triple checked as with any build i ran into some issues that were minor on my end but with these guys so far everything is looking good, They did tell me if I had any problems I can send it back for them to take care of things as so far I’m not seeing anything as of now, I do need to check the gasket line up before final assembling sometime this week.. They do use torque plates and seamed to left a little more room for expansion with my pistons but not to much as they seam to be leaving space for high horse power applications without over doing it. As for the mains came within spec. Cylinder walls matched with piston. This is my test block before I start building and selling basically their machine work since dedicating a lot of my spare time to this, so I will let you all know how it holds up & if anyone’s interested but needs someone in the southwest to put this together for them. Just gapped the rings today. And looking to build some cylinder heads to drop it in something light. If anyone is interested dm me and I can send you my build sheet specs of what I got. I’m excited to see the results. I will check back in hopefully a month or two from now. I do want machined cylinder heads so I want to chat with them about some porting work on that end. other wise I’ll post some photos/dyno & results here when the time comes.
Thanks, I’m glad I happen to stumble across this thread and give some insight. I wasn’t expecting to come across this.
Fozzanator is offline   Reply With Quote
Old 05-31-2020, 11:42 AM   #12
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
Originally Posted by Fozzanator View Post
I am just getting done building a short block with some of their machine work. I bought from them a couple months back and have measurements that I went thru and triple checked as with any build i ran into some issues that were minor on my end but with these guys so far everything is looking good, They did tell me if I had any problems I can send it back for them to take care of things as so far Iím not seeing anything as of now, I do need to check the gasket line up before final assembling sometime this week.. They do use torque plates and seamed to left a little more room for expansion with my pistons but not to much as they seam to be leaving space for high horse power applications without over doing it. As for the mains came within spec. Cylinder walls matched with piston. This is my test block before I start building and selling basically their machine work since dedicating a lot of my spare time to this, so I will let you all know how it holds up & if anyoneís interested but needs someone in the southwest to put this together for them. Just gapped the rings today. And looking to build some cylinder heads to drop it in something light. If anyone is interested dm me and I can send you my build sheet specs of what I got. Iím excited to see the results. I will check back in hopefully a month or two from now. I do want machined cylinder heads so I want to chat with them about some porting work on that end. other wise Iíll post some photos/dyno & results here when the time comes.
Thanks, Iím glad I happen to stumble across this thread and give some insight. I wasnít expecting to come across this.
Any update to this thread? Im thinking about going with them for my upcoming 500whp daily build
WRXXXED is offline   Reply With Quote
Old 08-19-2020, 03:46 PM   #13
1VIPWRX
Member#: 107554
yellow
I also had them build me a cd 2.1 stroked block . Havenít installed it yet . Need to get the heads done
1VIPWRX is offline   Reply With Quote
Old 08-25-2020, 10:15 AM   #14
subiscoobie
Member#: 518043
many STI
Blk, Wht, Red, Grn, Slvr
Default Closed Deck/SemiClosed Deck--Great Reputation & price
I found some people that have an excellent reputation for ClosedDeck, SemiClosed Deck Blocks, and offer excellent guarantee. Their price is reasonable, and they are great people with years of experience (30+ years). Call Outfrontmotorsports.com at 714-994-5222 and ask for Jeremy Hunt. He is super nice/knowledgable to deal with.
Just a FYI
R. Stuart
subiscoobie is offline   Reply With Quote
Old 08-28-2020, 12:14 PM   #15
Homemade WRX
Member#: 33782
96 3MI Racing
We all know who Jeremy at Outfront is. Been around a long time.
Old 08-28-2020, 02:02 PM   #16
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
lol right. Thought the same just didn't want to be a dick about it. Also IAG, and Dave at Rallispec does great work. I went with Rallispec since he also rebuilt my tranny and changed out my gear ratio to longer gears. Best decision i ever made.
Old 09-22-2020, 04:23 PM   #17
mobysti
Member#: 518562
Any update now?
mobysti is offline   Reply With Quote
Old 10-14-2020, 01:53 PM   #18
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
Quick update to this thread, i went with them, very friendply bunch. Sent my case halves in for a 100mm hone with .0035 PTW clearance and closed deck, came back looking beautiful and shiny, washed out the machining chips and assembled it, got the heads on and in the car, started up and sounds good on idle. No funny noises and working great! Will continue to update when motor is broken in
Old 10-14-2020, 07:11 PM   #19
cboggess
Member#: 30804
87 Yugo
Red
Did you happen to measure the cylinders for PWC, roundness and taper?
Please understand I'm not being sneaky so I can go "A-HA! You're a big dummy!" 1) that would be rather dickish of me and 2) I am genuinely curious as to how they did.
cboggess is offline   Reply With Quote
Old 10-15-2020, 07:58 PM   #20
benflynn
Member#: 515308
I am going to use them as long as looks good here
benflynn is online now   Reply With Quote
Old 10-17-2020, 08:17 PM   #21
BuiltWRXFL
Member#: 518888
I bought my closed deck short block used off facebook and been looking to find out where it was done, looks like it was done there from the water passage patterns, here's a pic
Was bored over to 100mm so we'll see how it will handle power on built internals
I bought the block for $600, seemed to have a small crack but my mechanic says it feels fine so we're continuing with this block, if anything I have my OG block waiting to get reinforced as well.
Car is not together yet but will keep you guys updated on how it works for me
BuiltWRXFL is offline   Reply With Quote
Old 10-18-2020, 08:24 AM   #22
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
I sent them the pistons and case halves and they did it all, although they must've used only one piston to measure all cylinders with because when I sent the pistons they had all the rings on them and only one came back without rings so that's what I'm assuming they used, when I measured out the cylinders and pistons they all came back within .0002
Old 10-18-2020, 12:22 PM   #23
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
I don't think yours was done at emerald coast, it didn't look anything like mine. The teardrop coolant passages are different from me. Mine were just circular
Old 10-18-2020, 04:35 PM   #24
BuiltWRXFL
Member#: 518888
Look at the pics from awdanthony the one block looks exactly like mine, same space between the small passages. I sent them a message on Insta. I might actually be wrong they said it was done in Melbourne I didn't realize Milton is in panhandle
Old 10-18-2020, 04:54 PM   #25
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
His doesn't look like yours... its not even his, the picture he posted to start is a screenshot from their Facebook. The coolant openings for where the headbolts go are totally different shapes than the picture you posted. They're not the same at all, I think you've got the wrong shop
