Welcome to the North American Subaru Impreza Owners Club Wednesday October 28, 2020
Old 04-13-2009, 10:59 PM   #26
SlickRick51586
Member#: 66735
2004 WRX
Originally Posted by FuJi K View Post
That's with stock WRX/STi rod length?
130.5mm, center to center
SlickRick51586 is offline   Reply With Quote
Old 04-13-2009, 11:10 PM   #27
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
When I go with a bigger turbo in my 08, this sounds very interesting.
I have a set of CP pistons already, so +2mm forged rods, and an EJ207 crank will allow me to run 8000+rpms? What about valve float? Would I have to upgrade the springs and valve train?
silver arrow is offline   Reply With Quote
Old 04-14-2009, 09:06 AM   #28
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
just slapping a +2mm rod and some STi pistons won't allow you to run 8000 rpm....it does relieve some stress from the rod bearings IF you are careful about rod and piston weight.
A long rod design just shifts the torque curve (volumetric efficiencies) to the right. the longer the rod, the more 'free' RPM's you can get from the motor and the more top end power you'll have.
You still need to address oiling mods (bearings, pump, cooler, etc for extended rpm use) as well as cylinder head flow; be it port job, valves, cams or all of the above and of course stronger valve springs so you don't float your valves and have a catastrophy.
Anyone intersted in this should first read:
http://forums.nasioc.com/forums/show...ing+crankshaft
http://forums.nasioc.com/forums/show....php?t=1181857
and for the sake of spool up, as long rod won't and can't be as good as a shortrod motor...
http://forums.nasioc.com/forums/show....php?t=1228477
oh and lastly, don't forget about cam LSA and LCA for a long rod. Also be certain to clay the setup to check for proper piston to valve clearance. There is a reason I'm not running AVCS.
Old 04-14-2009, 11:03 AM   #29
cellgeek101
Member#: 143941
04 STI JBP
07 LIMITED #602/ 06 BUSA
So is it possible to run AVCS with a long rod setup?
cellgeek101 is offline   Reply With Quote
Old 04-14-2009, 11:32 AM   #30
Homemade WRX
Member#: 33782
96 3MI Racing
you can but pending cam, piston and valve...the amount of adjustment you will have will be limited.
I'd say unless you know how to do your homework, let someone else do it for you
Part of why I'm telling people to do some reading and understanding if they really wanna do it on their own. Turbo mike and Bamofo both were at running with an extra 2mm of clearance due to their stock rod length.
For my particular build with my large custom cams and little room in the piston for valves and +1mm valves; AVCS would have been near pointless...so I elminated it as a reliability and to conserve oil pressure for the bearings.
With certain cams and piston's designed with ample valve relieves; AVCS would definately be usable. I actually do want to get my AVCS up and working on my setup sometime after september. IIRC from my piston to valve checking, I have about 7* of adjustment (not much).
Old 04-15-2009, 07:27 PM   #31
smileyou
Member#: 152045
2003 PIA wrx
wrb..future ppg/fggreen
im going to copy bamofo's list most likely just with a updated ej205 crank. Bamofo, if you could pm me with any specifics left out i would REALLY appreciate it. As far as the list given, let me know if theres anymore specific about the build I should know or change?
Homemade - Im still curious of your price of the componet kit from the group buy. LMK how much it comes out to be.
smileyou is offline   Reply With Quote
Old 04-15-2009, 09:30 PM   #32
Homemade WRX
Member#: 33782
96 3MI Racing
it'll be coming soon and pends on how many people are buying in...the more, the cheaper I can make the prices.
As Bamofo will tell you, there's more to it than simply a list of parts
Old 04-20-2009, 02:55 PM   #33
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I am interested, please PM me prices and info
Old 04-20-2009, 03:55 PM   #34
cellgeek101
Member#: 143941
04 STI JBP
+1
Old 04-20-2009, 07:39 PM   #35
Homemade WRX
Member#: 33782
96 3MI Racing
prices won't be getting pm'ed...don't need to be in bad graces while my vending account paperwork is going through
thanks for the interest though.
-Micah
Old 04-20-2009, 08:53 PM   #36
juanmedina
Member#: 133146
-Micah
okay good, you got an email
Old 04-20-2009, 11:04 PM   #37
Homemade WRX
Member#: 33782
96 3MI Racing
well, that's not what I meant but I guess that works
Old 04-21-2009, 06:01 PM   #38
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
Can I use a EJ22T crank for the destoker build? I just noticed that the EJ20 and EJ22T cranks both have a stroke of 75mm. I think the rod journals may be narrower on the 22T. Anyone?
hustleshark206 is offline   Reply With Quote
Old 04-21-2009, 06:07 PM   #39
Drakar
Member#: 68402
2016 WRX
I think the bearing setup is different and that crank potentially would only work in a Phase I 2.5 (correct as required please)
Drakar is offline   Reply With Quote
Old 04-21-2009, 06:18 PM   #40
hustleshark206
Member#: 182227
2000 MPS Built RS
Thrust bearing is #5 on the block and #3 on the EJ22T crank. Thats right. Plus the oiling timing is probably different. Probably easier to find someone who would trade a EJ22T crank for a EJ20 crank.......
Anyone?????
Old 04-21-2009, 09:01 PM   #41
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Both cranks are the SAME stroke and journal sizes. The difference is the thrust bearing location. That's it. Oiling holes are the same. The revised WRX crank are the ones with double cross drilled crank journals.
The only crank with the smaller "diameter" rod bearing journal are the phase1 2.5L DOHC NA motors. Phase2 2.5L DOHC NA motors went with the phase2 crank and newer rods, however retained the phase1 heads; which are found in the '99 Legacy 2.5GT and Outbacks.
FuJi K is offline   Reply With Quote
Old 10-09-2015, 08:23 PM   #42
Dropmymonkey89
Member#: 374300
2003 Subaru WRX
Sonic Yellow
I'm curious, do the stock (ported ) ej205 heads flow enough for the 2.35 destroyed motors? (+2mm) contemplating this or a stroked 2.1, just thought I'd ask, because searching didn't help me, nor Google.
Dropmymonkey89
Dropmymonkey89 is offline   Reply With Quote
Old 10-09-2015, 09:12 PM   #43
Homemade WRX
Member#: 33782
96 3MI Racing
You'll want to do cams and valvesprings at the least, to take advantage of the revs, assuming you have a turbo to flow for the RPM.
Old 11-02-2015, 07:56 PM   #44
snowdrift86
Member#: 273920
05 Legacy GT
Regal Blue Pearl
So I am going this route on my 05 lgt should I use the cams from a 2.0 liter instead with gears to eliminate the avcs. I mean technically at high rpm that these engines run, isn't it somewhat useless?
snowdrift86 is offline   Reply With Quote
Old 11-05-2015, 12:52 AM   #45
wrx1392
Member#: 342331
2003 wrx
blue
what kind of bearing clearances are you running to rev above 8,000 ?
wrx1392 is offline   Reply With Quote
Old 11-07-2015, 04:09 AM   #46
subi400
Member#: 216984
1996 Impreza outback
Green
For a mix of street and spirited driving, 0.0015" for the mains and 0.002" for the rods. I would have the case halves once bolted together checked for the line bore straightness from main # 1 - # 5 so oiling is consistent.
subi400 is offline   Reply With Quote
Old 11-07-2015, 10:56 AM   #47
2000subie
Member#: 207638
2004 WRX
Yellow
Some 2.34 tach action.
2000subie is offline   Reply With Quote
Old 09-16-2020, 01:10 AM   #48
PlayersLtd
Member#: 500366
Anybody care to talk more about destroked 2.5's?
I am rebuilding my 257 and my builder just brought the destroked option to my attention. I like the reliability factor that I am reading. Car is being built for the track but dd as well. Goals are not absurd, aiming for 450 hp, short block will be fully built.
Thanks for any information.
PlayersLtd is offline   Reply With Quote
Old 09-17-2020, 03:58 PM   #49
Jedi03
Member#: 491095
2009 STi Blue
+1 on more information, could more on the tuning be shared as well? I am getting some killer deals on parts and may build or sell off depending on how i feel about it all!
Jedi03 is offline   Reply With Quote
Old 09-17-2020, 07:13 PM   #50
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
What turbo? 450whp or crank? What model year, transmission choice?
I need opinions on a sleeved and destroked 2.5 shvrdavid Built Motor Discussion 9 12-02-2008 12:08 AM
Can you side gap spark plugs on the 2.5's? spshultz Normally Aspirated Powertrain 4 07-07-2001 01:40 AM
Do any 2.5's have a rear LSD? jeffg Normally Aspirated Powertrain 5 12-15-2000 02:42 PM
2000 2.5's are not aloud in touring Donnie Mid West Subaru Owners Club Forum -- MWSOC 26 06-22-2000 07:38 AM
How much air do our 2.5's take in per 1RPM? 8Complex Technical Forum Archive 14 06-08-2000 12:31 AM
