Welcome to the North American Subaru Impreza Owners Club Saturday October 31, 2020
Old 07-27-2011, 12:59 PM   #1
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Default 2009 Wrx PO500 vehicle speed sensor A
So I was helping a friend raise his car up for rally x. Wrx 2009. And after we got it done we got a CEL.
We we doing suspension upgrades and for the love of me can't figure out why it tripped this code. Anyway tried to reset the ecu manually and by using learning view. Still comes back. But what's weird is it isn't just the CEL light it's the fuel door light, cruise is blinking.
So why would a faulty speed sensor A not just throw a CEL but additional abs, cruise, fuel door. And not be able to be reset?...
After I used learning view to reset the code I check it and there was no code until you start it up. But the car apparently is sluggish and feels like it's in limp mode, but only throws that one code.
Any guru help would be great!
Rob
sackytar is offline   Reply With Quote
Old 07-27-2011, 09:49 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
double check harness for transmission..
Old 07-28-2011, 06:52 PM   #3
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Yeah we did.
Old 07-29-2011, 03:22 PM   #4
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Anyone else got ideas?
Old 08-29-2011, 06:09 PM   #5
thenick
Member#: 199580
i been hatin'
Hellas since 2012
Anyone? I got this same problem
thenick is offline   Reply With Quote
Old 08-29-2011, 07:13 PM   #6
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
We figured it out it ls a wheel speed sensor issue.
Old 03-10-2012, 03:43 PM   #7
SubaruStein
Member#: 313132
2011 WRX
I'm having the same issue and it's driving me nuts, what did you end up having to do to solve the problem?
Thanks for the help.
SubaruStein is offline   Reply With Quote
Old 03-10-2012, 05:50 PM   #8
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
I'm not sure why they named it that, but P0500 means you should really check for codes stored in the VCD system.
I had one that was throwing a P0500, but also a few other codes. It turned out to be iron casting debris floating around between the wheel bearing and the dust cap on the axle, intermittently throwing off the wheel speed sensor.
CosmoTheCat is offline   Reply With Quote
Old 03-10-2012, 07:15 PM   #9
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Do you know anything about pass codes?
Old 08-13-2012, 06:44 PM   #10
Jeff8407
Member#: 134316
2009 WRX STI
Satin Pearl
Default Bump
Bumping the thread.
I am having same problems. When starting the car get a CEL, dash lights up like an Xmas tree--VDC, CEL, Cruise, the works...
Any additional info regarding "P0500 Speed Sensor A" would be appreciated.
Jeff8407 is offline   Reply With Quote
Old 08-13-2012, 08:38 PM   #11
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Originally Posted by Jeff8407
Bumping the thread.
Unfortunately we had to take it to the dealership which replaced the sensor.
Old 07-19-2020, 07:00 PM   #12
jclancy1981
Member#: 468362
Default 2010 WRX Same Issue
I replaced my front ball joints, dust covers, wheel hubs/bearings, rotors, brake pads, and ABS speed sensors and I am still getting this code. I tried resetting the ECU and deleting the code, but it keeps popping up as soon as I turn on the car. Any help with this would be great.
jclancy1981 is offline   Reply With Quote
Old 07-20-2020, 10:14 AM   #13
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
Greetings,
9yr old thread for a '03 WRX.
You have a 2010. Same premise though.
What brand speed sensors did you go with?
What brand hubs did you go with?
Hopefully OEM.
Are you sure you didn't pinch something during re-assembly?
Grease? I grease all of the mating surfaces on the hub, and axel splines, but if you put too much or get any near the hole for the speed sensor problems can arise.
Brand matters. There are a several after market hubs out there. Timken, MOOG, Duralast, etc. Not sure who Subaru is using for theirs, but I always buy OEM. Reason. Only have to do it once until the next failure.
If the code is returning after deleting on every restart, you're going to have to take the wheels off and re-inspect. Worst case partly dis-assemble or fully and replace some parts. I know it sucks, and you'll be out twice the amount of your time, some parts and maybe some $$$. Hopefully you can solve without too much trouble.
shadowsports is offline   Reply With Quote
Old 10-16-2020, 10:39 PM   #14
63Denied
Member#: 519177
2014 Impreza
Default Similar problem in 2014 Impreza
I replaced the front left hub and got a Christmas tree of warning lights. Code reader said it was P0500 Speed Sensor A. I replaced that with an OEM sensor. Still have all the lights on. Any ideas much appreciated.
63Denied is offline   Reply With Quote
Old 10-17-2020, 11:44 AM   #15
shadowsports
Member#: 446364
'17 STI LMT '08 LGT
DGM / QSM
Greetings,
What I said above applies in your case as well.
Parts, installation, etc. Hubs are not created equal.
What brand/model# hub did you use?
Also, Free SSM is another option. It might give you more insight into your issue. However, I'd assume brand and installation of parts first.
Old 10-23-2020, 06:27 PM   #16
63Denied
Member#: 519177
2014 Impreza
Thanks for the post.
I used all OEM parts. I also posted a more thorough post here about my issue. Really driving me crazy. For the first time in my Subaru ownership.
https://forums.nasioc.com/forums/sho....php?t=2929215
2008 wrx vehicle speed sensor ECU pin majunche66 Electrical & Lighting 0 07-08-2010 10:56 PM
WTB: vehicle speed sensor 02 WRX freakaccident6661 Private 'Wanted' Classifieds 3 05-29-2009 01:14 AM
NJ: 02' WRX vehicle speed sensor ejsportcom Private 'Wanted' Classifieds 4 03-20-2006 11:37 PM
6-speed w/vehicle speed sensor in 02' WRX ejsportcom Subaru Conversions 3 11-18-2005 02:16 AM
need vehicle speed sensor 2 for JDM WRX! AWJunkies Southern California Impreza Club Forum -- SCIC 1 07-23-2003 10:40 PM
