Welcome to the North American Subaru Impreza Owners Club Saturday October 31, 2020
Old 06-23-2013, 03:35 PM   #1
erok81
Member#: 300717
2004 WRX
JBP
Default Correct AVCS Delete Method
I have an '04 Wagon that I bought with an already swapped EJ257. I was chasing a low oil pressure issue that lead to a rebuild. I want to make sure I do the build right so I don't destroy another engine.
Everything has been checked and now I am my final things. The AVCS system was disconnected when they did the swap. Cam oiling hole were blocked off, I'm pretty sure new cam gears swapped (I'll have to check that), but I noticed they completely removed the AVCS solenoids from the housings.
I have no idea the tolerances inside that housing (I looked in the FSM but didn't see anything) but I would imagine filling a big hole instead of small oil clearances might make a difference.
All of the swaps I've read about don't say anything about removing them. Only the blocking of the cams and the correct cam gears. I think down the road I'll might swap in the AVCS but I have to recover from this latest engine build first.
erok81 is offline   Reply With Quote
Old 06-23-2013, 03:55 PM   #2
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
You cant get rid of the AVCS solenoids because that's where the cams get the oil from. There isn't a oiling hole drilled into the head, just the AVCS Solenoid/Girdle. You can disconnect the plug from the solenoids, but you still have to have the oil lines hooked up.
You would also need 2.0 WRX Intake Cam gears with the 2.0 cam seals.
You will still have to run cams with the trigger marks on the back of the intake cams for the cam sensors.
banshee04 is offline   Reply With Quote
Old 06-23-2013, 03:59 PM   #3
erok81
Member#: 300717
2004 WRX
JBP
I'm pretty sure the cam gears were swapped. The oil lines and everything are there, but there is nothing where the solenoids would go - just an empty cavity with a plug sealing the hole where I assume the wiring would normally come out of.
Old 06-23-2013, 04:03 PM   #4
banshee04
Member#: 179014
'06 WRX/STi
That hole is where the AVCS Solenoid goes. As long as the lines are still hooked up to the housings, then your good to go.
Old 06-23-2013, 04:07 PM   #5
erok81
Member#: 300717
2004 WRX
JBP
Here are a couple of pictures. Getting one inside the hole was tough, but you can see there is nothing in there.
So it sounds like this isn't the correct way to disable the AVCS? The cams were still getting some oil. I ran it this way for ~50k miles. In that 50k I blew a turbo in two weeks (swapped in a bigger one) that was fed from this housing. Maybe that's part of the reason my turbo went so fast.
Old 06-23-2013, 04:13 PM   #6
banshee04
Member#: 179014
'06 WRX/STi
Deleting the solenoids are just fine as long a the oil hardlines are still attached to the top of the AVCS Housings.
Old 06-23-2013, 04:24 PM   #7
erok81
Member#: 300717
2004 WRX
JBP
Yeah the oil lines are still there.
I was hoping they needed to be there. That means I still have no idea what caused my low oil pressure and blown turbo issue.
Old 06-23-2013, 04:33 PM   #8
banshee04
Member#: 179014
'06 WRX/STi
Do you still have the AVCS filter? If so, throw them in the trash.
Old 06-23-2013, 04:34 PM   #9
erok81
Member#: 300717
2004 WRX
JBP
Nope. That was probably the second thing I did.
I'm hoping the issue was just a crappy build on the shortblock
Old 06-23-2013, 10:49 PM   #10
erok81
Member#: 300717
2004 WRX
JBP
Maybe I'll throw some solenoids in there just incase. Seems like a lot of additional volume to fill without those being there. Depending on how tight they fit I guess.
Old 02-21-2015, 12:18 PM   #11
midnightlamp
Member#: 321627
Just in case anyone sees this and trys the same thing, this is NOT the correct way to delete the AVCS system. The front cam girdle with the AVCS solenoid has release lines so that oil going into the cam gear has a source to return and drain. You'll see this as two holes on the girdle, leaving it. When you just plug the solenoid hole all your oil pressure is just being dumped out of those two holes.
midnightlamp is offline   Reply With Quote
Old 10-13-2020, 02:50 AM   #12
DAVIS5267
Member#: 408532
Default avcs solenoid delete?
I know this is an old thread but,....I am in the process of swapping a ej255 into my 05 wrx. I plan on using the heads that came on the motor. In an effort to get he engine bay as clean as possible, I would really like to get ride of the AVCS solenoids. There must be a way to do it with out the solenoid itself.
Could I plug the oil passage so that it will maintain oil pressure in the cavity that the solenoid would be mounted in and still keep cam journal fed?
DAVIS5267 is offline   Reply With Quote
