Welcome to the North American Subaru Impreza Owners Club Sunday October 25, 2020
Old 06-03-2020, 11:43 PM   #426
spoolinsti05
Member#: 108051
2005 TickingTimeBomb
Jr tuned TT Sleeved
Idk if it was mentioned here I've been busy away haven't been on here in a minute got a new shop it's super rad! but anyways.
A valve job will change install spring seat pressure hence the need to shim!
And to much springs pressure will beat a valve up pretty good. Just saying.
And I'm using stock oem keepers.
spoolinsti05 is offline   Reply With Quote
Old 06-04-2020, 12:01 AM   #427
spoolinsti05
Member#: 108051
Jr tuned TT Sleeved
Originally Posted by 2slofouru View Post
GSC contacted me and basically reiterated what they'd mentioned on the Evo forum. They also declined posting here, as if it would turn into some sort of roast. I guess it's understandable, considering what happened on the Evo forum.
The gist of it was that their springs are designed to last as long or longer than oem for their rated range and that the actual number of defect related failures has been infinitesimal considering how many sell.
"The fatigue life of our springs is designed well above the estimated life of a built or OEM engine so for a spring to fail after 10k, 20k, 50k, etc. is almost impossible without the influence of some external factor."
" I won't claim it's impossible but in 10+ years of history I can count the amount of confirmed defects on a single hand. "
"External factors like rust (#1 killer), handling damage, or installation issues are really what we deal with these days."
and
"As for your build, if you are planning on 500 whp as a starting point our 5043 kit is perfectly fine for that. This is our most popular installed kit for the EJ engine which we sell thousands of per year. Shimming this kit later on in its life is not recommended because it changes the springs working range (see below) as well as gets you closer to coil bind. Depending on your future goals if you are looking into higher power/boost/rpm's I would suggest our 5073 dual conical kit. This kit can handle just about anything below dedicated drag car power levels. It really boils down to turbo size and its supporting modifications."
were a few things he mentioned. He also mentioned e85 use and moisture introduction into the crankcase as a factor with rust related spring damage.
Say you have GSC s3 cams and shimmed the springs then yes but with GSC s2 id say you can shim them. Always check your spring height at full lift. Record your data.
Old 09-18-2020, 12:34 PM   #428
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Got the 66mm wastegate welded into exhaust to drop back pressure, crazy gains
user1029 is offline   Reply With Quote
Old 09-18-2020, 01:24 PM   #429
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
WOW!!! You must be a happy camper!!!
Scuby04STi is online now   Reply With Quote
Old 09-18-2020, 04:36 PM   #430
user1029
Member#: 57064
2008 STi IAG built
Iím scared to drive this car
Old 09-19-2020, 12:46 AM   #431
user1029
Member#: 57064
2008 STi IAG built
Granny shifting not double clutching as I should, trying keep 800whp straight
Old 09-19-2020, 10:29 AM   #432
user1029
Member#: 57064
2008 STi IAG built
Big chonker 66mm wastegate off of the downpipe opening at 15psi boost pressure
Old 09-19-2020, 11:51 PM   #433
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
Did you re-tuned for this, Iím sure you did, just wanna be sure
silversurfer05 is offline   Reply With Quote
Old 09-20-2020, 12:04 AM   #434
user1029
Member#: 57064
2008 STi IAG built
Yup retuned
Old 09-22-2020, 12:26 PM   #435
K3rm1tth3fr0g
Member#: 508105
2002 VF39 Bug Wagon
Love the flipped intake
K3rm1tth3fr0g is offline   Reply With Quote
Old 09-22-2020, 04:04 PM   #436
user1029
Member#: 57064
2008 STi IAG built
I would go with a better design intake than cosworth like AMS and process west but then I got to get rid of AC in flipped configuration
Old 09-22-2020, 04:54 PM   #437
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
Keep the AC, for sure.
Maybe I missed it, but what valve springs did you end up going with in your new long block?
bicycle_wreck is offline   Reply With Quote
Old 09-22-2020, 05:10 PM   #438
user1029
Member#: 57064
2008 STi IAG built
Ferrea dual valve springs
Old 09-22-2020, 08:11 PM   #439
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
Ah, good deal. I'm glad you stuck with it. Here's to 65,000+ miles on your new build!
Old 09-22-2020, 08:29 PM   #440
user1029
Member#: 57064
2008 STi IAG built
with 800whp even I'm doubtful
Old 10-21-2020, 08:03 PM   #441
blckholehurican
Member#: 515368
still looking forward to the ETS header comparison!
blckholehurican is offline   Reply With Quote
Old 10-21-2020, 09:06 PM   #442
user1029
Member#: 57064
2008 STi IAG built
The ETS V2 header is being installed by shop right now
Iíll make a separate thread for the epic KillerB vs ETS header showdown, stay tuned
Old Today, 07:20 PM   #443
blckholehurican
Member#: 515368
how many lbs/min was your turbo that went from 430whp to 500 whp on meth with the stage 5 iag heads?
