Welcome to the North American Subaru Impreza Owners Club Sunday October 25, 2020
Old 03-31-2014, 02:19 PM   #26
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
30psi I should definitely be over 600whp but the tune is conservative at 570whp with low timing
Jorge pushes >600whp at 30psi when using E85/C16 since he has more leeway to run more timing
user1029 is offline   Reply With Quote
Old 03-31-2014, 06:15 PM   #27
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Hey sorry, I did not seem to sound negative. Your build is a nice one and well sorted out from the looks of it!
When you say conservative timing what are you talking about at peak torque and red line. You've got to figure that this turbo will make at least 25-30 whp/ lb. of boost when it's in it's efficiency range of 25+psi.
Old 03-31-2014, 11:14 PM   #28
user1029
Member#: 57064
2008 STi IAG built
^^^at redline
I can't wait to get an Outfront closed deck and push 37psi through this turbo
Old 03-31-2014, 11:21 PM   #29
manitou
Member#: 193757
2006 XTI Limited
^^^I guess i need to be more clear. What is the timing at peak torque and at red line? I know Jorge is a very good tuner, no question there! I also have fairly conservative timing on my maps as does 05_wRex and others on here. What is conservative from a timing standpoint?
Old 04-02-2014, 12:05 AM   #30
user1029
Member#: 57064
2008 STi IAG built
I need to find time and space to datalog a 4th gear pull to get the exact timing values
Old 04-02-2014, 12:19 AM   #31
manitou
Member#: 193757
2006 XTI Limited
Good luck with that! I have a hard time finding room for a 4th gear pulls, my redline is around 140! I just do 3rd gear pulls and those are 110-115.
Old 04-02-2014, 07:18 AM   #32
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
That's still quite close especially with spool. Jeff's car has less boost with the Cossie as well
Bottom line is this build should be making way more power at 30psi and way sooner! This car had more boost with the Cosworth.
Also worth noting, all the places the cossie makes less than the stock manifold, the boost pressure is actually lower as well because of the bigger runners/plenum.
No doubt if you put boost on equal terms the cossie wouldnt be far off at all on the stock for spool like you said. and top end should be huge on big turbo cars...80 plus whp on 67mm or bigger
stretchedk7 is offline   Reply With Quote
Old 04-02-2014, 07:23 AM   #33
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
^^^at redline
At 37psi I doubt your car will be reliable.
Nice car!
Old 04-02-2014, 06:32 PM   #34
user1029
Member#: 57064
2008 STi IAG built
Nice car!
or will it
Old 01-13-2015, 06:19 PM   #35
user1029
Member#: 57064
2008 STi IAG built
Long term followup:
40,000 miles daily driven with this setup. Motor got hit with the fuel pump failure but the Manley components took it like a champ and recovered apparently
http://i.imgur.com/Wd4rNcx.png
Had the car strapped to the dyno as an annual cardiac stress test in November 2014:
http://i.imgur.com/4QcrVPB.jpg
Still pumpin' out great numbers
IAG BUILT
Sure there are lots of Subaru shops out there, but to aptly quote Meek Mill - there's [sic] levels to this ****
Old 01-13-2015, 08:29 PM   #36
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
you can daily drive it but do you daily drive the **** out of it? i have a friend with a stock motor 35r for like 3 years+ but he doesnt boost it like a teenager all the time. Its called being responsible lol.
BroBroBroBroBro is offline   Reply With Quote
Old 01-13-2015, 08:39 PM   #37
user1029
Member#: 57064
2008 STi IAG built
It sees multiple redlines up to 120mph on familiar roads with great visibility and minimal traffic daily (check my youtube channel bro http://www.youtube.com/user/user1029/videos)...if only I can stream my daily commute.
Multiple redlines a day for 730 days with mixed highway street driving/heat cycles vs. few track sessions which one is more taxing on the motor?
Old 01-14-2015, 01:50 AM   #38
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
cars like this cant be driven like a mini vans, if u got vagina driving habits buy 2nd car
Bariga is offline   Reply With Quote
Old 01-14-2015, 01:51 AM   #39
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Love it!! I'm glad to see more guys enjoying these things long term.
If you canned the guys that cant actually build them and had quality guys like IAG doing it, subies wouldn't have such a bad rap.
Junior2JZ is offline   Reply With Quote
Old 01-14-2015, 07:27 AM   #40
user1029
Member#: 57064
2008 STi IAG built
word
Old 01-14-2015, 08:40 PM   #41
BroBroBroBroBro
Member#: 338211
2011 wrx cobb 20G
your videos are great nice thanks! thats a juicy car right there sir.
Old 01-14-2015, 09:05 PM   #42
user1029
Member#: 57064
2008 STi IAG built
Thanks brah
Old 01-20-2015, 05:56 PM   #43
md2regul8
Member#: 371029
2011 STI Hatch Black
Rotated GTX3076
you my friend are my hero, I have 65K on my stock block. Rotated gtx 3076 with a ETS TMIC .
I am hoping to get 100k before she needs a short block, daily driven sees 17lbs at least once a day, But I don't load the car up down low and I get gas at one place consistently, oil changes every 3k
Mods and Power thread
http://forums.nasioc.com/forums/show....php?t=2673481
md2regul8 is offline   Reply With Quote
Old 01-20-2015, 11:03 PM   #44
user1029
Member#: 57064
2008 STi IAG built
^^Just proves that maintenance and monitoring with a great tune goes a long way
Old 04-04-2015, 02:34 PM   #45
user1029
Member#: 57064
2008 STi IAG built
Old 04-04-2015, 04:04 PM   #46
SW00P_G
Member#: 5591
EJ257 Gt35r
Keep it up! I love it!!!
SW00P_G is offline   Reply With Quote
Old 04-04-2015, 06:08 PM   #47
dstroy
Member#: 283711
2012 STI sedan
Black with scratches
Would you mind posting a plot of your ignition timing on top of the hp/tq plot?
dstroy is offline   Reply With Quote
Old 04-04-2015, 09:26 PM   #48
user1029
Member#: 57064
2008 STi IAG built
Sounds like work and I'm lazy
Jorge runz mad timingz
so just datalog the ignition table?
Old 04-05-2015, 10:24 AM   #49
Shortpersonbk
Member#: 319017
15 Prius
2JZ miata Death Trap
omg look its user1029s car he be famous
Shortpersonbk is offline   Reply With Quote
Old 04-05-2015, 03:45 PM   #50
user1029
Member#: 57064
2008 STi IAG built
said no one ever
