Welcome to the North American Subaru Impreza Owners Club Tuesday October 27, 2020
Old 08-07-2019, 10:02 AM   #1
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Default Built 2.5l, Xona Rotor 7164, Water to Air, 592hp atw
[IMG][/IMG]
Ambient Temp: 30 degrees C
Elevation: sea level-ish
Weather: humid
Conditions: Shop
Tires: 235/40/18
Car: 2007 WRX
Tuner: Dave @ GT Autogarage
Dyno Info: Dynapack Hub
Transmission: 6 Speed Long Ratio
Gear: 4rd
Peak HP: Dyno 592whp
Target Boost: 28 psi
Fuel: Pump E85
Engine/Power Modifications: Engine work done by Flat 4 Performance.
EJ257 closed deck, bored 99.75 Wiseco pistons, Argo I Beam rods with ARP bolts, ACL race bearings, ported heads, Billet 284 custom cams, 1mm oversize supertech valves, double valve springs, 1/2 inch head studs, Killer B pickup and baffle, Gates timing set, Plazmaman custom 1000hp water to air intercooler, 5bar MAP Sensor, Grimmspeed ECBS, Xona Rotor 7164 1.03 hot side , TGV's deleted, 3mm phenolic spacers, Cosworth air pump delete kit, Fab Lab rotated kit up / 3.5" down pipe, Tial 44mm EWG @ 1 bar springs, ID1700cc injectors, Walbro 460 fuel pump Hard Wired in tank, Aftermarket Industries Surge tank with 1000hp Holley dominator pump, Aeromotive fuel rail kit w/ FAST regulator, Jim Berry Race Clutch, EWG Rerouted to DP
CEEBEE is offline   Reply With Quote
Old 08-07-2019, 10:12 AM   #2
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
2 plots are .86 rear 3" DP vs 1.03 Tial rear 3.5" DP, Cosworth intake manifold.
Old 08-07-2019, 10:17 AM   #3
motorbykemike
Member#: 273868
very interested in the fab lab rotated kit w/ 3.5" dp for tial hot housings
motorbykemike is offline   Reply With Quote
Old 08-07-2019, 10:33 AM   #4
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Not a kit it was custom made here in Australia.
Old 08-07-2019, 12:21 PM   #5
motorbykemike
Member#: 273868
ok , still interested
pics ?
Old 08-07-2019, 02:31 PM   #6
TDagen
Member#: 163648
V9 6mt R180 Brembos
Awesome!
Looks like that thing hits hard. How is it on the street? The hotside and downpipe swap made a huge difference, good work!
I***8217;ve got the xona 7864 with the new uhf 64mm turbine wheel and tial .82 hotside, can***8217;t wait to test it.
TDagen is offline   Reply With Quote
Old 08-07-2019, 09:41 PM   #7
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
Originally Posted by TDagen View Post
Awesome!
I’ve got the xona 7864 with the new uhf 64mm turbine wheel and tial .82 hotside, can’t wait to test it.
Totally different car! Would have liked to try the uhf rear but you have to buy a supercore which is a joke. The motor could have taken more boost but the turbine wheel design is still causing back pressure so left where its happy.
Comes on very hard and torque steers quite a bit, turned the tyres when cold
Interested to see how yours goes!
Old 08-07-2019, 09:43 PM   #8
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
pics ?
I'll upload some later today
Old 08-08-2019, 03:30 AM   #9
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
[IMG][/IMG]
Old 08-08-2019, 03:32 AM   #10
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
[IMG][/IMG]
Old 08-14-2019, 08:12 PM   #11
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
I’m curious as to why you went with this particular turbo over a ball bearing FP black
silversurfer05 is offline   Reply With Quote
Old 08-15-2019, 01:00 AM   #12
can250
Member#: 452601
Rotated is better then stock location
can250 is offline   Reply With Quote
Old 08-15-2019, 01:09 AM   #13
silversurfer05
Member#: 366241
Dgm
At higher power yes. Ive seen 600+ from a black in stock location at lower boost and stock heads. Hence the question
Old 08-15-2019, 01:13 AM   #14
can250
Member#: 452601
These are australian numbers remember
Old 08-15-2019, 08:29 AM   #15
silversurfer05
Member#: 366241
Dgm
I know. Op states 592 at the wheels
Old 08-15-2019, 11:22 AM   #16
TDagen
Member#: 163648
V9 6mt R180 Brembos
Silver, someone had to test the xona 7164
Here’s one way to look at it, the largest exhaust housing fp black is offered with is 10cm, the op was having issues with .86 exhaust housing choking and swapped up to a 1.03. If we crunch some numbers 10 cm2 = 0.73 A/R. Although these two turbos share the same compressor wheel, the turbine wheel on the black is a bit smaller 67.3MM Inducer / 58.8MM Exducer for the black and 68/62.2mm for the 7164.
Also FP says this about the black “This combo nearly maxes out the stock location possibilities on this platform.” The 4” inlet paired with the correct sized exhaust housing/turbine really does make a difference, that’s the advantage with rotated setups vs stock location.
Another angle to look at, with the ported heads and 284 custom billet cams this car “gulps” some serious air per combustion event.
Old 08-15-2019, 11:34 AM   #17
Waddlz
Member#: 395275
2012 STi
that graph looks great.
Waddlz is offline   Reply With Quote
Old 08-15-2019, 02:40 PM   #18
silversurfer05
Member#: 366241
Dgm
Understood that its a bigger housing for back pressure reasons. But now im confused as to why this is making less power on more boost, headwork, and bigger housing than some of the fp blacks. Id expected this turbo to surpass the black especially with headwork and the boost being 5-7 psi higher
Old 08-15-2019, 03:23 PM   #19
Waddlz
Member#: 395275
2012 STi
hub dynos load the car weird
I bet this thing spools so much faster than an FP black will on the street while making similar power.
Old 08-15-2019, 06:30 PM   #20
TDagen
Member#: 163648
V9 6mt R180 Brembos
+1 I agree with waddlz.
You seen a black make 600whp on 21psi? IMO that must have been a high reading dyno. Or was the map sensor maxed out and it was flatlined and 21.7 or something? I guess who knows, 25 degrees at peak torque and 35-40 degrees up top might do it, and it might do a few other things too
Dyno numbers differ. You never know how much ignition timing is being run by the tuner. Maybe one car is rolling with a tune on the edge of doom, and the other is safe for years to come. So many variables come into play when comparing numbers on the rollers, especially between different dynos.
Now if we could get some 40-100mph times via logs between cars like xlubens old thread (don***8217;t quote me on the mph***8217;s can***8217;t recall) I think that***8217;s a pretty good look at the power a given car is making. Especially for the people that don***8217;t make it to the track or have a local track available.
Old 08-15-2019, 09:48 PM   #21
can250
Member#: 452601
A fp black wont make 600hp on australian dynos
Old 08-16-2019, 08:49 AM   #22
2JZ
Member#: 291949
Awesome!
where were you when I was selling a brand new 7864 for $1800
The Xona rotor turbos are hands down the best for making power and especially reliability. Australian stuff always seems to be built with a much higher degree of quality and knowledge, thank you for sharing your graphs. Would you mind sharing any pictures of your AWIC setup?
2JZ is offline   Reply With Quote
Old 08-16-2019, 03:23 PM   #23
silversurfer05
Member#: 366241
Dgm
Now if we could get some 40-100mph times via logs between cars like xlubens old thread (don’t quote me on the mph’s can’t recall) I think that’s a pretty good look at the power a given car is making. Especially for the people that don’t make it to the track or have a local track available.
Iirc it was 24 or 26 psi in e85 tuned by junior barrios. Will try to find the link
Old 08-16-2019, 03:26 PM   #24
silversurfer05
Member#: 366241
Dgm
Here is the link. Pics are no longer available but comments still tell the story
https://forums.nasioc.com/forums/showthread.php?t=2785052
Old 08-16-2019, 05:09 PM   #25
TDagen
Member#: 163648
V9 6mt R180 Brembos
In post number 25 the OP says he was wrong it was 28psi.
Originally Posted by dlapham View Post
That is INSANE for 24PSI, and with a stock cams at that. That new Black HTZ must be world class. I wonder if the heads on the 2015 somehow breath better.
Mine is an 04 with VSR Motorsports built block. It should be pretty close in specs.
Originally Posted by TGxNavy View Post
I was wrong, Its 28 PSI.
So they both made 600 @ 28psi. It’s pretty much down to who’s dyno reads lower and what’s the curve look like.
Since tgxnavy deleted basically all his stuff and sold the car after that Texas street racing fiasco I think it’s safe to say your never gonna see that particular curve.
