Welcome to the North American Subaru Impreza Owners Club Tuesday October 27, 2020
Old 04-21-2020, 10:10 PM   #1
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
OMGHi2U 2.5L hybrid, Blouch DOM 3.5XT-R, 93 octane
City and State: Chesapeake, VA
Ambient Temp: ~50*
Humidity: ~80%
Weather: Cloudy
Elevation: 35 FT
Car: 2004 WRX 2.5 liter hybrid + Blouch 3.5XT-R Ball Bearing Turbo
Tuner: Kienan at All Aspects Motorsports
Dyno: Dynojet
Peak HP at RPM: 411 HP ~5447 RPM
Peak Torque at RPM: 401 TQ ~5115 RPM
Baseline HP/TQ for a stock on same dyno: 172HP for stock 2004 WRX
Target Boost: 24 PSI
Fuel: 93 Octane
Engine Management: Cobb AccessPORT V3
Engine Modifications:
2.5L Hybrid using JE FSR Pistons, Eagle rods, ported and polished heads, OEM everything else
Blouch Dominator 3.5XT-R Full Ball Bearing Turbocharger
JDM STi BPV
Grimmspeed Lightweight Pulley
TurboXS downpipe no cat version
TurboXS adapter (makes downpipe normal OEM length)
Borla Hush catback
Killer B equal length header + v-band uppipe
CSS Performance FMIC
Grimmspeed TGV deletes
Grimmspeed FMIC phenolic gaskets
IAG billet cam seals
Turn In Concepts FU cam bolts
Walbro fuel pump
APS turbo inlet
ID 1000 injectors
Cobb AccessPORT ver 3
TurboXS big MAF intake
Grimmspeed BCS
Driveline Modifications:
PPG helical syncro 1-4 gears
South Bend KSB03-SS-TZ Stage 3 Endurance clutch
Lightweight steel driveshaft
Cusco 1.5 way rear differential
Every Kartboy and Turn in Concepts bushing ever made
Story
So...what had happened was....
I had 60,000 miles on my built motor and had to get some things done so I had them throw in a compression/leakdown check because racecar. All values were great as I drive like a grandma, so I started thinking that 400WHP would sure be nice. And all I'd need to get there would be a better clutch and a new Hiroshima Hairdryer as the kids say. 16 sources told me the Easy Button for 93 octane 400 WHP is the Blouch 3.5XT-R, so I rolled up all my pennies and financed one like a real American. I also fell into a scam and found a legit DEI blanket for it on amazon for $40. Someone at DEI screwed up and I scored!
I hollered at my buddy Dave at South Bend clutch and axed him what clutch I should get for guesstimated 400WTQ and he said the South Bend KSB03-SS-TZ Stage 3 Endurance clutch. That was installed a month or two back and for a no messing around 5MT clutch, its amazingly has a 2020 Toyota Corolla clutch feeling. its crazy....a $XXXX clutch that drives within 10% of OEM! While under the hood they found out my Power Steering pump was leaking after I had them reseal it a few months prior (Thanks Obama!).
Next visit was to have the turbo installed and figure out which Power Steering pump to use as I bought both the WRX and STI ones. I have aftermarket PS lines due to swapping in a 16 STI rack and due to those lines I was able to use the "better" STI pump, which oddly, is ~$150 cheaper than the WRX pump. The lines were the key, so don't try this at home kids.
So when all was done, I got a new PS pump, new turbo, and got just a touch over 400 WHP. Next step for teh wagon will be a trip up to Gaithersburg, MD to see my old pal Andrew Yates. I stumbled upon a PPG front Torsen differential for $7 and Andrew is gonna take apart likely the world's oldest PPG gearbox, shake out all the broken bits and install the differential. This should pair nicely with the Cusco 1.5 rear Andrew installed last year and hopefully cause me to torque steer into a ditch.
Old 04-21-2020, 10:16 PM   #2
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
Looks really good. What is the top speed on 4th gear? Any plans to use corn?
gaby is offline   Reply With Quote
Old 04-21-2020, 10:17 PM   #3
chefo.soriano
Member#: 288385
2008 LGT 3071r powah
STi Mikey Tuned
Mmmm...looks like endless smiles! Nice build! I had a stage 3 SB daily and was really nice on my calf muscles hahaha. Enjoy!
chefo.soriano is offline   Reply With Quote
Old 04-21-2020, 10:20 PM   #4
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
I don't know top speed in 4th as I'm old and it scares me. I do know that the top of 3rd is a bit north of 90MPH and that's enough for me.
No corn. My 2 bit ECU means no Cobb Flexfuel t00n and I am not dealing with the drama of fuel/map swapping even though I legit live 2 miles from an E85 pump. If Cobb magically supported it one day.....yeah.....I'd do it. But so far, they have their eyes on other prizes than to waste resources getting it to work on us old guys.
Old 04-21-2020, 10:29 PM   #5
gaby
Member#: 94097
[email protected]
I use Carberry with Pinguin Racing flex fuel on my 16bit. Not to hard to tune. You got plenty there to break into the 11s. I always wanted to build a 5speed.
Old 04-26-2020, 11:47 AM   #6
Hardrvin
Member#: 63647
05 FXT
12.5 @ 109
Good post and nice setup. Haven***8217;t logged in ages and came across this post. Good to see it***8217;s still BA. If I were to build a car again, I***8217;d love to do that trans setup. You***8217;ll love the torsen for the front.
Hardrvin is offline   Reply With Quote
Old 04-26-2020, 12:23 PM   #7
chefo.soriano
Member#: 288385
STi Mikey Tuned
I like that you put that hand on the AP hahaha. I have a tshirt with that hand gesture! *muff* lol
Old 04-26-2020, 12:31 PM   #8
danger1138
Member#: 279525
06 Fxt
What wheels are those? Black racing? They look light.
danger1138 is offline   Reply With Quote
Old 04-26-2020, 10:18 PM   #9
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Super light. https://www.fastwrx.com/products/mac...-awesome-wheel
Old 04-28-2020, 01:11 AM   #10
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
damn bro most kids on here weren't even born on your join date lol
Bariga is offline   Reply With Quote
Old 04-28-2020, 02:21 AM   #11
vicious_fishes
Member#: 158864
2003 SOHC destroker
great sleeper.
vicious_fishes is offline   Reply With Quote
Old 04-29-2020, 07:42 PM   #12
chrisd87
Member#: 344446
2012 00 GC8, 02 S202
Nice build. Did you smack on the S20 heads without matching them to the ej25? Oem ej25 head gasket?
chrisd87 is offline   Reply With Quote
Old 04-29-2020, 09:16 PM   #13
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Ah Ron, how I've missed your colorful posts. Looking forward to seeing the good old wagon, and you, next time I'm home and lines up with a cars & coffee or HR Subie meAt.
Old 04-29-2020, 10:53 PM   #14
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
There's 3 ways to hybrid
1. Special JE pistons
2. Mill the heads
3. Stack 32 head gaskets
I used the special JE pistons designed for hybrid builds because cheaper.
Old 04-29-2020, 11:54 PM   #15
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Congrats Ron!!! Also, nice work Kienan. Looks like fun. Hanging out with you guys is one of the things I miss about Hampton Roads.
speedyHAM is offline   Reply With Quote
Old 05-03-2020, 01:43 AM   #16
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Awesome!
Fierysun is offline   Reply With Quote
Old 05-03-2020, 02:06 AM   #17
makeitso2008
Member#: 514376
2015 WRX
whats the damage on the build?
makeitso2008 is offline   Reply With Quote
Old 05-04-2020, 08:31 AM   #18
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Not much as I have lots of friends and sponsors. My build would cost somewhere around $8000ish. Builds are hard to price as many leave stuff out. Like a new clutch that holds 400tq for a 5MT is $1000 alone. That turbo is north of $1500. Motor work for a hybrid is $2500 without labor. Injectors, lines, installation, add ons, tuning....lots of hidden costs in a build.
Old 05-04-2020, 09:28 PM   #19
vicious_fishes
Member#: 158864
2003 SOHC destroker
The real killer is always labour - DIY if you can.
Old 05-04-2020, 10:26 PM   #20
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Cool deal, I almost went with the hybrid JE pistons and someone convinced me to hybrid the head chambers instead. Could have saved some cashola for sure, but it was fun and a learning experience...was bored I guess. That is good powa and stock location ftw. Any video with sound? Which walbro did you go with?
2slofouru is offline   Reply With Quote
Old 05-09-2020, 08:00 PM   #21
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Walbro 255 pump that's old as hell. Been in the car for over 10 years without a hitch.
https://imgur.com/7cVRRO0
Old 05-10-2020, 01:12 PM   #22
NighthawkSTI
Member#: 495630
little off topic but why are Blouch turbos called Polka Pickles???
NighthawkSTI is offline   Reply With Quote
Old 05-11-2020, 02:35 PM   #23
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
the 2.5 is the only one with the real name of polka pickle. It got that name 10+ years ago and I think everyone who knows why or how is dead.
Old 05-11-2020, 04:06 PM   #24
T-37
Member#: 175624
0304 WRX WRX
SY WRB
Spin off from Disco Potato?
T-37 is online now   Reply With Quote
Old 05-12-2020, 01:10 PM   #25
NighthawkSTI
Member#: 495630
is it some kind of phallic reference? Is it a reference to dance (doing the polka) from the increased performance causing bouts of euphoria? It is quite puzzling. Polka Pickle could have some interesting implications.
