Welcome to the North American Subaru Impreza Owners Club Sunday October 25, 2020
Old 08-16-2020, 10:37 PM   #1
karlknaupp
Member#: 60871
19 Sti & 19 Ascent
Default 2019 Sti stock motor FP Black
Its been a few years since ive made a post on here, back from my 2004 wrx days..
Currently gathering all my parts to install in september. Going to be pushing the stock motor to its upper limits with fp black on e85.
Parts that i have gathered so far:
Fp Black 10cm with fp inlet
Radium dual pump hanger with aem 340 pumps
Torque Solutions fuel rails and lines, tgv deletes, cyl 4 cooling, air pump delete
Aeromotive fuel pressure regulator
Injector Dynamics 1700cc inj
Cobb flex fuel, fuel pressure, AOS, AP, Intake
ETS FMIC with air temp sensor
Omni 4 bar MAP
Invidia dp with spt catback
Vibrant -8 feed line and -6 return line, inline fuel filter
Kartboy shifter and all bushings
Grimmspeed Up-pipe w tial 38mm wg
iWire Fuel Pump Controller Hardwire Kit for Radium - Double Pump
MikeyTuned
Ill come back once i have everything installed and update.
karlknaupp is offline   Reply With Quote
Old 08-17-2020, 01:10 AM   #2
NighthawkSTI
Member#: 495630
sounds like an AWESOME set up!
NighthawkSTI is offline   Reply With Quote
Old 09-17-2020, 10:16 AM   #3
gtlyearsley
Member#: 501308
2020 STI
MGM
I like it! I'm on the same route except using a FP Red on my 20 STI, everything being installed as we speak just waiting now for completion lol
gtlyearsley is offline   Reply With Quote
Old 10-10-2020, 02:19 PM   #4
K24 Madness
Member#: 519273
My first post so go easy on me.
I purchased a 2018 STI limited without an engine. I bought a stock 2019 engine with 8k miles to replace the missing one. The car came with Twin Scroll Dom 3 XT-R, TS Tomei headers and TS downpipe. I also have E85 fueling upgrades (pump, lines, ID1300, rails etc and EMTRON ECU. I've been told by tuner the Dom 3 is to big for stock engine. I was looking at TS Dom 1.5 to replace it but reading this post I question my decision since both the FP Red and FP black are larger turbos. I'd appreciate some feed back from both you guys.
K24 Madness is offline   Reply With Quote
Old 10-10-2020, 02:50 PM   #5
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
I can give you the Dom 1.5 perspective. It's an especially great turbo on flex fuel, with exceptional spool and very good on the top end. You could get a nice 350 - 400whp on flex, if this is your goal.What are your goals?
Dave D. is offline   Reply With Quote
Old 10-10-2020, 05:32 PM   #6
K24 Madness
Member#: 519273
Thanks Dave.
I know when people ask for a "goal" they expect a number. My first goal is to not blow up the engine. I am also looking for a perky setup with a broad flat torque curve.
I know the bigger you go with turbos the narrower the torque gets. It helps the bigger turbo helps starve off detonation since I will run mostly 91oct. So my "goal" is to go big enough to help 91 but small enough to keep good response and let the numbers fall where they will within limits of 2019 block. I'd also be willing to trade some torque for top end HP. Love the way a big cam NA engine revs out. I want similar personality out of the STI. I am a road racer hence the preferences.
Old 10-10-2020, 07:46 PM   #7
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
Thanks Dave.
Honestly you could do nothing and it will blow up. If that is a concern, save for a block first no? Rather then spend xxxx on a big turbo that wont be tuned to its potential due to the concerns
silversurfer05 is offline   Reply With Quote
