Welcome to the North American Subaru Impreza Owners Club Wednesday October 28, 2020
Old 09-18-2020, 12:05 AM   #1
whiterabbitrexy
Member#: 379271
Default rear thrust bearing clearance
So I'm a little confused with what to aim for on the rear main thrust bearing clearance....subaru factory manual says 0.030-0.115mm ?
Online On eveyones build they aim for 0.012-0.015mm including the rear thrust...
Why dont people open it up at least to 0.030mm rear thrust clearance?
Is it ideal to aim for 0.045mm ?
0.033mm is about the size of a human hair...so having that tight clearance at the back where the heavy flywheel and clutch engages on heavy load could have a bit of premature wear ? Can't be too much wear because its not a common thing for rear thrust bearings to spin or wear out?
whiterabbitrexy is offline   Reply With Quote
Old 09-18-2020, 08:19 AM   #2
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
My guess is someone is reading/interpreting specifications wrong. Quoting inches and dropping a zero (fatal mistake) Although Subaru is designed and built in metric very few techs actually use metric measuring gear.
like you said - the spec is: 0.030mm to 0.115 mm (0.0012" to 0.0045")
Elbert Bass is offline   Reply With Quote
