Welcome to the North American Subaru Impreza Owners Club Tuesday October 27, 2020
Old 09-23-2020, 07:26 PM   #1
dmc1240
Member#: 383942
2014 Wrx
Default Install and tune in a couple weeks (what to expect hp/tq wise?)
Below is the full list of parts that will be on. I just want to go into it with realistic expectations. Any other last minute purchases I should make to make everything more reliable?
**Turbo inlet hose
**Cusco catch can
**Perrin equal length headers
**Grimmspeed up pipe w ewg flange
Grimmspeed downpipe
Cobb SF Intake
**Cobb fuel pressure sensor kit
**Turbosmart comp gate 40mm EWG
**Grimmspeed electric boost control solenoid
**Grimmspeed top mount intercooler
**IAG TGV deletes
**1050x injectors
**Am 340 lph fuel pump
**Turbo blanket
**Tein Flexz coilovers
**Whiteline 22m front swaybar
**Whiteline 22m rear swaybars
**Whiteline endlinks and Bushings
Perrin pitch stop mount
**Group N STI motors mounts
**Group N STI transmission mounts
**PST Carbon fiber drive shaft
South bend stage 3 clutch
Perrin light weight crank pulley
Perrin catback exhaust
Enkei RPF1 17X8
Firestone Indy 500
dmc1240 is offline   Reply With Quote
Old 09-23-2020, 07:29 PM   #2
dmc1240
Member#: 383942
2014 Wrx
Forgot to mention I have a 14 dgm hatch
Old 09-23-2020, 07:52 PM   #3
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
Also forgot to mention if you're still using the OEM turbo or something different.
snow_bound26 is online now   Reply With Quote
Old 09-23-2020, 07:54 PM   #4
dmc1240
Member#: 383942
2014 Wrx
Ah yes, OEM turbo as well. Thanks for mentioning that.
Old 09-23-2020, 09:22 PM   #5
JSR84
Member#: 469585
300 Mustang dyno
JSR84 is offline   Reply With Quote
Old 09-23-2020, 10:45 PM   #6
Haevn
Member#: 495950
2011 WRX
e85
Haevn is offline   Reply With Quote
Old 09-24-2020, 12:57 AM   #7
igoiks
Member#: 326692
2012 sti
Dude you read too much garage on these forums instead of consulting with a shop or tuner, you bought whole bunch of parts that won’t make your car faster or drive better. Please put oem crank pulley back on !
You just wasted thousands on nonsense and wont even get up to 300hp on accurate dyno, should of bought turbo instead of headers, driveshaft, crank pully , front sway bars etc....
igoiks is offline   Reply With Quote
Old 09-24-2020, 06:32 AM   #8
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
Dude, what's you definition of fast? Straight line speed? Yes I agree there are several items he could've done differently, but just because some of them aren't power mods doesn't mean he won't go faster. OP should mention what the goals are for this car. Things like the sway bars and driveshaft are actually good to have. I would've skipped the headers or gone with better ones like the Killer B Holy Header. Also would've skipped the Cobb intake and pressure sensor. But the down pipe, EWG items, injectors, and TMIC are all good to have for future upgrades and will make decent gains right now.
And yes get rid of that lightweight pulley and either use the OEM one or something like a Fluidampr pulley.
Old 09-24-2020, 07:30 AM   #9
Jay11STI
Member#: 492422
2011 STI
Id bail on the crank pulley and tgv deletes. I would add turbo inlet and upgrade to one step colder spark plugs. Id say you will make a 300 or so whp on a mustang dyno. Torque i would guess 330-360wtq. This is all provided you're on stock oem turbo and 93 octane fuel.
Remember, the dyno is just a tuning tool and it doesn't actually tell how the car will feel and drive on the road.
Jay11STI is offline   Reply With Quote
Old 09-24-2020, 07:30 AM   #10
dmc1240
Member#: 383942
2014 Wrx
Sorry, realistically I'm just trying to make a fun street car that handles well. I'm not trying to make all the power and want a responsive vehicle with some decent torque and horsepower.
Personally yeah I know the perrin elh aren't has good as the killer bee ones but I got them for 900 and the kb headers are like 1700 which I just don't feel like they are worth it if I'm just trying to break 300+ whp.
And I personally like the crank pulley just since it has hugely improved downshifting feel. Im planning to keep stock turbo and don't plan on going e85 since the nearest station is an hour and realistically ill never go out of my way to get it.
I hope this was a bit more informative on my goals. Last time I was protuned stage 2 I was at 271hp/285tq on a mustang and just want to see how much over 300 whp I could possibly make. Thanks for the replies guys.
Old 09-24-2020, 07:33 AM   #11
dmc1240
Member#: 383942
2014 Wrx
I just added a new turbo inlet hose last night haha thanks for the suggestion. Why forgo tgvs? I got one step colder plus maybe 8 months ago from my tuner. Also why the hate on the pulley? I felt a night and day difference on downshifting consistency.
Old 09-24-2020, 07:35 AM   #12
dmc1240
Member#: 383942
2014 Wrx
For the future I was going to wait until my engine croaks then rebuild with a new block and bigger turbo but thats only if it blows. Otherwise I'm okay with the potential power I might gain. I'm planning to get a new oil pickup and pan just in case as well for some reliability.
Old 09-24-2020, 09:06 AM   #13
snow_bound26
Member#: 395793
2005 92x Aero
Blue(retired�ȸ
It's debated about the crank pulley. But basically, Subaru put a layer of elastomer in the OEM pulley to dampen harmonic frequencies that may cause damage over time to the engine. Flat engines are more inherently balanced than most layouts, but they still resonate at certain frequencies. Aluminum pulleys do nothing to dampen those frequencies.
I had a GrimmSpeed pulley at one time. When I did my first engine swap I opted for a Fluidampr. I now won't use anything else. Your carbon DS makes a bigger difference in rotational mass than the crank pulley. A well designed pulley doesn't have to be insanely light to still have good response. I noticed no perceivable difference in throttle response for down shifting going from the GS pulley to the Fluidampr. However, now I'm doing what I can to protect my engine rather than increase the long term wear.
Old 09-24-2020, 09:23 AM   #14
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
Definitely do the TGV deletes, or you'll just end up doing them later when the shaft end seals on the stock units start leaking vacuum/boost. Ask me how I know.
bicycle_wreck is offline   Reply With Quote
Old 09-24-2020, 10:25 AM   #15
dmc1240
Member#: 383942
2014 Wrx
Ahh that makes sense. Thats for the input, ill be looking into a replacement then. Ill probably be going the fluidampr route too then.
Old 09-24-2020, 11:48 AM   #16
bicycle_wreck
Member#: 226331
2012 WRX Hatch
Poor Man's Panamera
One thing I don't see on this list is air pump delete. Since you're going to have the trans out and the up pipe off, you might as well delete the air pump, related plumbing, fuse, and relay while it is easily accessible.
Your tuner can turn off all the air pump codes in the tune. You'll drop about 15 lb. of weight, and the relays are known to catch fire anyway.
You'll need the block-off plates and gasket kit: https://www.aluminati.us/products/al...-delete-plates
Old 09-24-2020, 01:24 PM   #17
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Everything on your list is fine, just dont need them at this point, but with a OEM turbo you will only make the power the turbo can push out which is around 300whp, MAYBE 320. Deff keep the TGV deletes.
I used a light crank pulley with a built block pushing 450whp with no issues. JR tuned it and my idle and everything was on point. Keep in mind the 5spd tranny is not as strong as 6 spd. So that will limit you pushing high hp.
BlackFighter is online now   Reply With Quote
Old 09-25-2020, 12:23 AM   #18
BuiltWRXFL
Member#: 518888
Originally Posted by JSR84 View Post
300 Mustang dyno
I put down 320 on stock injectors on a Mustang don't clown the guy too hard.
340 was probably too big for 1050s but it doesn't matter pumps are cheap.
I'm not sure what you guys get in the newer WRXs for stock turbos, from google it says its an IHI but GDs all got TDs in the WRXs.
If its a TD then 350 is realistic guess, ~380-400 is hopeful.
If its VF then 380-400 is realistic
BuiltWRXFL is offline   Reply With Quote
Old 09-25-2020, 07:48 AM   #19
dmc1240
Member#: 383942
2014 Wrx
Im on stock 2014 wrx turbo so vf 52
Old 09-25-2020, 09:23 AM   #20
dmc1240
Member#: 383942
2014 Wrx
So I ended up snagging a FP blue nee for 600 from my buddy. Im assuming power goes of 330+ hp should be fairly easily attainable now?
Old 09-25-2020, 09:24 AM   #21
BlackFighter
Member#: 193940
2004 WRX STI Black
380-400 is hopeful.
LMAO really? 400 hp on a stock turbo? There is no freakign way a stock turbo will ever reach close to 400. I have a HTZ FP Green and 420-450 is maxing it out on a Mustang dyno. A 18g-20g will get you to 380.
Old 09-25-2020, 04:42 PM   #22
dmc1240
Member#: 383942
2014 Wrx
Would I be good for 340+ with the fp blue with my parts listed?
Old 09-25-2020, 05:38 PM   #23
Haevn
Member#: 495950
2011 WRX
are you on corn or pump?
Old 09-25-2020, 05:55 PM   #24
dmc1240
Member#: 383942
2014 Wrx
93 pump. Nearest corn is annhour away
Old 09-26-2020, 01:28 PM   #25
BuiltWRXFL
Member#: 518888
Okay watch me give you 450 wheel on E85 with my VF43 when I go get tuned
