Welcome to the North American Subaru Impreza Owners Club Saturday October 31, 2020
Old 09-24-2020, 10:38 AM   #1
ImportTun3r
Member#: 376244
2011 WRX
Default 2011 WRX stock intercooler alignment issues
Good morning, I just recently bought a 2011 WRX 3 days ago and so far I'm loving it (coming from an 04 WRX). Anyways, i noticed that i have a boost leak on intercooler to turbo side, so i took it off and I also noticed that it has a mishimoto TB to IC hose with a spectre brand 3" to 2.4" coupler at the end of it and didn't even have clamps on them smh. Anyways, I took the spectre coupler off and tried to reinstall the IC back but now it won't align with the turbo side. I kept fighting with it for 3 hours, trying different ways, sides and even put the spectre coupler back on and still nothing . I've searched on google, here, clubwrx, and wrx tuners and no one has this type of issue. Can you guys help me on how to align the IC properly and reinstall it back on without issues? Thanks in advance.
ImportTun3r is offline   Reply With Quote
Old 09-24-2020, 11:02 AM   #2
Stretch18
Member#: 239822
2010 WRX
pandiculation
Probably not a model specific hose. That OEM throttlebody hose is notorious for folding and causing boost leaks, so wouldn't be surprised if someone fixed with whatever they had on hand.
Pics might be helpful, but consider just buying a replacement; a new aftermarket part can be had for ~$60 and will probably save you some headache...
Stretch18 is offline   Reply With Quote
Old 09-24-2020, 11:09 AM   #3
ImportTun3r
Member#: 376244
2011 WRX
Thanks for replying Stretch 18, it didn't came with an oem TB hose, just a Mishimoto TB hose that is design for that year but the spectre coupler is not. I just can't understand why I'm having a hard time aligning it on turbo side.
Old 09-24-2020, 05:49 PM   #4
Haevn
Member#: 495950
2011 WRX
i know the stock tb coupler has an off set in it and had to be align a certain way. the way i did it was connect the TB side first to IC then you had enough play to make it fit on the turbo side and bolt up to turbo
Haevn is offline   Reply With Quote
Old 09-24-2020, 06:20 PM   #5
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Sorry for your problems. That tmic is known to be a PITA to install.
The easy fix for that is not cheap, but both my cars have the Grimmspeed tmic. So much easier.
Do you still have the OEM tmic ?
Max Capacity is offline   Reply With Quote
Old 09-24-2020, 06:24 PM   #6
enclosedflame56
Member#: 473277
Originally Posted by ImportTun3r View Post
Anyways, I took the spectre coupler off and tried to reinstall the IC back but now it won't align with the turbo side. I kept fighting with it for 3 hours, trying different ways, sides and even put the spectre coupler back on and still nothing.
Since the throttle body hose has a curved part, I've found it easier to leave the TB hoses loose, and then rotate them until you can get the bolts into the turbo. It does take some wiggling to get it lined up correctly, but you should be able to get it. Once you have it all lined up, you can tighten the clamps going around the two sides.
I would leave the hose on the TB side connected (not tightened!), then worry about the turbo lining up, then rotate the hose until it seems to want to slide in. They can definitely be a pain though. Is this on a stock intercooler?
enclosedflame56 is offline   Reply With Quote
Old 09-24-2020, 11:38 PM   #7
ImportTun3r
Member#: 376244
2011 WRX
Thank you all for replying back. Yes this is the oem tmic we are talking about. I just bought a new cobb TB hose thinking that the mishimoto one wasn't fitting properly but i had trouble with the cobb one as well. I've tried different position of the hose and still having a hard time aligning it with the turbo side. Can anybody show me a pic of the TB hose factory position? Or a video? I'm losing my patience here.
Old 09-29-2020, 04:41 PM   #8
ImportTun3r
Member#: 376244
2011 WRX
BUMP! I need help in figuring this out please.
Old 09-30-2020, 08:59 AM   #9
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
You might want to look at www.legacygt.com and see if there is a picture there or ask for help in the 4th Gen forum there. As we have the same set up.
I just remembered I have the set up from one of my cars in the basement, OEM tmic with TB hose on it.
I'll post pictures over there and link them here. I don't think I can post pictures here, haven't taken the time to figure that out.
Here you go,
https://legacygt.com/forums/showthre...26#post5993726
Old 09-30-2020, 04:42 PM   #10
ImportTun3r
Member#: 376244
2011 WRX
Thank you so much for the pics Max Capacity, but I think that's how i have the tmic and hose orientated and still not aligning correctly on the turbo side. I'm beginning to think that maybe the previous owner has rotated the turbo a bit to the right?? idk, tmic looks a bit tilted instead flat and flushed with intake manifold, if that makes sense.
Old 09-30-2020, 05:02 PM   #11
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Your welcome.
You may need to "re-clock" the turbo.
I thought there used to be a white dot on the OEM TB hose, that went up on the tmic side... ?
Another thing I've learned when working with the turbo is to leave it loose on the up pipe and start all the bolts on the tmic and TB hose before tightening things down.
Old 10-01-2020, 06:56 AM   #12
ImportTun3r
Member#: 376244
2011 WRX
How do you "re-clock" the turbo? Also, wrx came with a red mishimoto TB hose when i bought the car last week, not oem.
Old 10-01-2020, 08:53 AM   #13
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
The compressor housing should be clamped to the center section of the turbo. Or it could be the exhaust housing that's clamped. Either way loosen that and you can rotate the outlet side.
Spray the area with something like PB Blaster, and loosen the clamp and tap the outlet hosing in the correct direction.
Look at an on line photo of your turbo from one of the Vendors and you should be able to see how its clamped to the center section.
Google search "how to clock a turbo".
Old 10-23-2020, 08:09 PM   #14
ImportTun3r
Member#: 376244
2011 WRX
Can i do this while it's in the car or do i have to remove the turbo out of the car?
Old 10-24-2020, 08:03 PM   #15
ImportTun3r
Member#: 376244
2011 WRX
UPDATE: i figured out how to reclock the compressor housing by loosing the 5 bolts behind the housing and now was able to align the tmic at the turbo flange without any issues. Now she runs and pull strong, so happy.
