Welcome to the North American Subaru Impreza Owners Club Saturday October 31, 2020
Old 09-26-2020, 01:09 PM   #1
Ashmanfish1
Member#: 518805
2006 Impreza WRX
Steel Grey
Question Changing cat back
I have an Invidia N1 cat-back and I want to put on the Crawford Gymkhana one 3" exhaust on. Will the Crawford axel-back bolt right up to the Invidia mid pipe with no problems? or do I need to get the whole Crawford cat-back?
Ashmanfish1 is offline   Reply With Quote
Old 09-26-2020, 03:16 PM   #2
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Best answer:
Call CRAWFORD and ask them. It's that simple.
Samurai Jack is offline   Reply With Quote
Old 09-28-2020, 03:15 PM   #3
Ashmanfish1
Member#: 518805
2006 Impreza WRX
Steel Grey
To anyone looking at this in the future and has this question, No. I called Crawford Performance and they said that their axel-back will not work with an Invidia mid-pipe
Old 09-29-2020, 09:02 AM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
OK, so, do you have any custom exhaust shops in your area?
I have one and I know they could easily make a piece to connect the two together so it would almost look as if it came that way.
It would be a LOT cheaper to fix it this way than buying the whole Crawford set-up.
This is the problem when mixing and matching products between manufacturers. They usually make their stuff to fit with their stuff only. Some make their stuff more universal to fit most other manufacturer's parts. Makes more sense that way since they open up their market.
Old 10-01-2020, 04:01 PM   #5
Ashmanfish1
Member#: 518805
2006 Impreza WRX
Steel Grey
I already bought the whole cat-back setup from Crawford, it was on sale so it was only around $650 including shipping. Once I put that on I should be able to sell my Invidia cat-back for I'm hoping around $200 which will cover a third of the Crawford cat-back.
