Welcome to the North American Subaru Impreza Owners Club Saturday October 31, 2020
Old 10-10-2020, 10:19 PM   #1
tannerdc
Member#: 437133
06 WRX Limited
Default No idle
So I finally got my car back together after a year. Battery has been sitting on the charger outside the car. The car started up just fine cold start. I let it warm up and and didnít touch anything. About 5-8 minutes. I got int he car and touched the gas to idle down and the car just dies. Only way I can keep it started is a bit of gas and it sounds just fine. Just wonít idle. Itís a Ď06 WRX. Ran fine before it was parked. Just suspension work. I read something about an idle control valve and also read it isnít on my model. Another person said it goes away after a few miles. Any help is appreciated
tannerdc is offline   Reply With Quote
Old 10-10-2020, 11:16 PM   #2
truck7575
Member#: 516780
2008 Subaru wrx sti
Maybe a vacuum leak?
truck7575 is offline   Reply With Quote
Old 10-11-2020, 07:15 AM   #3
Jay11STI
Member#: 492422
2011 STI
Does it change if you un plug the MAF?
Jay11STI is offline   Reply With Quote
Old 10-11-2020, 12:55 PM   #4
tannerdc
Member#: 437133
06 WRX Limited
I havenít tried that yet.
Old 10-12-2020, 09:40 AM   #5
klinebau
Member#: 122383
2006 WRX Wagon
'06 does not have an idle air control valve. These exist only on the cable operated throttle valves and the '06 was the first year for drive by wire. I would try this procedure.
https://forums.nasioc.com/forums/sho...ght=idle+learn
klinebau is offline   Reply With Quote
Old 10-12-2020, 09:47 AM   #6
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
My 04 STi TB was not cable operated and i had a idle air control valve on top of my TB.
BlackFighter is offline   Reply With Quote
Old 10-13-2020, 09:05 AM   #7
klinebau
Member#: 122383
2006 WRX Wagon
I forgot about the STI. 2006 was the first WRX with the 2.5l engine, drive by wire and no IACV.
