Welcome to the North American Subaru Impreza Owners Club Thursday July 20, 2017
Old 04-17-2017, 06:08 PM   #826
jimbosv650
Member#: 261307
04 wrx wagon
The porting helps. It's fully spooled by about 3500rpm, if not a little sooner. I really can't complain. For a smallish turbo, it feels really good for daily driving. I'm running out of fuel due to my small injectors. Once I get another set (for the third time) I should be able to make more power.
jimbosv650 is offline   Reply With Quote
Old 04-18-2017, 11:53 AM   #827
Superorb
Member#: 135252
2002 WRX Wagon
Nice. Is there any benefit to running 205 heads? My bottom end might be dead, but I could use my heads from my 205.
Superorb is offline   Reply With Quote
Old 04-18-2017, 08:46 PM   #828
jimbosv650
Member#: 261307
04 wrx wagon
Default Post your Dyno Plot and Mods, see format inside.
No there's no benefit, unless you consider not having to deal with avcs as a benefit. I was on a budget, but in retrospect I should have at least ported the heads and thrown in some cams. If you do build a hybrid motor, I recommend porting the heads to match the block, or at least get the JE hybrid pistons like mine. Otherwise, the sti knock sensor will randomly pick up false knock.
Old 04-18-2017, 09:52 PM   #829
Superorb
Member#: 135252
2002 WRX Wagon
K, thanks.
Old 04-26-2017, 07:51 PM   #830
magicmike7
Member#: 396660
2015 WRX STI
Facility:P&L Motorsports
Type of Dynoynojet
Tuner: JR
Boost:30psi
Fuel:E66
Peak HP at RPM:480
Peak Torque at RPM:472
Mods:IAG Stage 2.5 Closed Deck
P&L Refreshed Heads
ID 1300X
Walbro 485 hardwired
P&L Fuel Rails, Lines
Aeromotive Fuel Regulator
Cobb Flex Fuel and Fuel Pressure kit
Exedy Hyper Twin Disk Clutch HD version
P&L Up-pipe with Tial 38mm EWG
P&L ELH ceramic coated
P&L Hi-flo intake
AMR Hard turbo inlet
FP Green HTZ
Grimmspeed TMIC with IAT sensor for speed density
Tial Q BOV
Invidia Catless Downpipe
Invidia Q300 Catback
magicmike7 is offline   Reply With Quote
Old 05-10-2017, 09:32 AM   #831
12wrxwagon
Member#: 462639
2012 wrx hatch w/74k miles
Facility: DynoComp Scottsdale,AZ
Type of Dyno: Dyno Dynamics I believe
Tuner: Richard(I think I forgot lol)
Boost:18psi
Fuel:the worst azn 91octane
Peak HP at RPM:[email protected]
Peak Torque at RPM:[email protected]
Mods:
Process West top mount
Cobb Ebcs
Cobb SF intake
Grimmspeed downpipe
Grimmspeed up pipe w/Tial 38mm ewg
Invidia Catback N1
ID1000cc Injectors
DW300 fuel pump
http://imgur.com/a/YO3gm
http://imgur.com/a/xq6DI
Last edited by 12wrxwagon; 05-10-2017 at 09:40 AM. Reason: can't get pictures to show:(
12wrxwagon is offline   Reply With Quote
Old 05-22-2017, 06:53 PM   #832
hypersti2017
Member#: 464376
2016 STI
Hyper Blue
2016 Subaru STI Hyper Blue Edition
Facility:Bren Tunning
Type of Dyno: Mustang
Tuner: Bren
Boost: 22psi
Fuel: 93oct
Peak HP: 318
Peak Torque: 355
Mods:
Cobb Accessport
Cobb SF intake with air box
Cobb 3" high flow downpipe
Cobb 725cc injectors
Cobb High flow fuel pump
Cobb Heat shield
Cobb Fuel pressure regulator fix
Mishimoto TMIC
Perrin Turbo inlet
Grimmspeed Up pipe
Tial 38mm EWG with 14psi spring
Grimmspeed EBCS
Invidia Q300 cat back
Crawford AOS
NGK 1 Step colder plugs
hypersti2017 is offline   Reply With Quote
Old 05-23-2017, 08:47 AM   #833
Tidgy
Member#: 167242
1998 Impreza Type R
Grey
1998 V5 STI Type R
Facility:Scoobyclinic
Type of Dyno: Dyno dynamics
Tuner: Scoobyclinic
Boost: 29psi
Fuel: 99 oct shell Vpower
Peak HP: 398.2bhp @ 5000rpm (dam you 1.8bhp lol)
Peak Torque: 465ftlb @ 3800rpm
Mods:
Closed deck converted EJ257 block
Mahle Pistons
Manley Rods
ACL race bearings
ARP headstuds
Rebuilt V5 heads with supertech valve kit
custom Gt2871R Billet turbo
Nismo 700cc injectors
Perrin FPR
Perrin 4 bar map sensor
Perrin intake pipe
Perrin Induction Kit
Front mount intercooler
Walbrough 400 fuel pump
Syvecs ECU
Perrin oil cooler
Cobra Full exhaust (inc downpipe)
GT spec Gen 2 headers
Harvey smith up pipe
NGK PFR7 spark plugs
2006 STI 6 speed gearbox
Competition clutch Twin plate clutch
Tidgy is offline   Reply With Quote
Old 05-30-2017, 01:09 AM   #834
swiffy
Member#: 214656
1997 Impreza
SWIFTUNE
JDM Subaru Impreza GC8 WRX STi
Instagram : @swiftuneja
Sponsor : Chungs Catering
Driver. : Ian "swiffy" Galbraith
Team. : SWIFTUNE
Built by : SWIFTUNE
Tuned by: SWIFTUNE
Mods:
Ej207 OEM open deck block
JE pistons 92.5mm
Standard 75mm crankshaft
Manley H-beam rods
Garrett GT3582r
3" straight pipe
Haltech Platinum Sport 1000 Ecu
1200cc injectors
Methanol Injection
MSD blaster Coils
FMIC
OEM JDM 6 speed gearbox
M&H slicks
ACT 6puck clutch kit and flywheel
swiffy is offline   Reply With Quote
Old 06-05-2017, 07:39 PM   #835
DansharSti04
Member#: 458775
2004 Impreza WRX STI
rally blue
Big congratulations to you, Jerome and the entire Swiftune team for destroying the previous 10.5s Subaru 1/4 mile record in Jamaica!!!!! That 10.07s run was unbelievable glad i could witness it. Can we say 9s. You should also post this in the sticky for time slips.
DansharSti04 is offline   Reply With Quote
Old 06-07-2017, 01:50 AM   #836
swiffy
Member#: 214656
1997 Impreza
Will do and we appreciate the props . We still on the road to 9s, if all goes well at the next test session, we will run the Nos and go for a best time.
Old 07-12-2017, 10:47 AM   #837
magicmike7
Member#: 396660
2015 WRX STI
Type of Dynoynojet
Tuner: JR
Boost:30psi
Fuel:E70
Peak HP at RPM:490
Peak Torque at RPM:478
P&L Refreshed Heads
ID 1300X
P&L Hi-flo intake
FP Green HTZ
P&L FMIC kit (4.5" core)
Tial Q BOV
Got retuned as we swapped out the Grimmspeed TMIC for P&L's monster core FMIC kit. Gained a little up top on a terribly hot day, quoted previous tune for comparison below.
Type of Dynoynojet
Tuner: JR
Boost:30psi
Fuel:E66
Peak HP at RPM:480
P&L Refreshed Heads
ID 1300X
P&L Hi-flo intake
FP Green HTZ
Tial Q BOV
Post your OLD ride and your NEW ride. MF-DIF Member's Car Gallery 1291 03-02-2016 11:43 PM
Post your dyno results from today. (Mach V) banzai Mid Atlantic Impreza Club -- MAIC 70 03-28-2006 10:08 PM
hey baic folks, post your dyno results LEOSPEED Bay Area Impreza Club Forum -- BAIC 16 11-25-2003 02:22 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Post your dyno results here! Darryl Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2001 05:40 PM
