02-16-2008, 02:54 PM | #1 |
Member#: 171336
NWIC
Vehicle:2002 WRX Blue |
Question after replacing rear o2 sensor
Posted here a bit back about my rear O2 sensor issue. Got the replacement from a local parts place for a good deal (it was a Bosch, but I noticed that the sensor itself said Denso on it - which was the original brand so that's good I guess). Was a breeze to put in and I was amazed after the 10 minutes of work that the garages I called wanted $260 for the sensor itself and another $100 plus for labor for a total of about $375 to replace the thing. This is easier than an oil change. The CEL is all taken care of now, so thats a relief, but I wanted to know if there is anything I need a technician to do with the ECU or whatever its called after this sensor has been replaced (does it have to be adjusted or anything)?
Thanks for any info and I appreciate the help given in the previous thread.
Rear O2 sensor difficult to replace? '99 2.5 | Hagbard | Normally Aspirated Powertrain | 7 | 01-22-2007 10:51 PM |
Do you think my Rear O2 Sensor Needs Replacing? | rekondyte | Newbies & FAQs | 3 | 04-07-2006 10:41 PM |
Why would my rear O2 sensor go out after 1100 miles? | MattDell | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 08-30-2004 10:05 PM |
Rear O2 sensor replaced under warranty | blackbok | Normally Aspirated Powertrain | 5 | 12-04-2003 08:39 AM |
MIL Eliminator install question - where's the rear O2 sensor? | WHTWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 10-13-2002 04:15 AM |
