Welcome to the North American Subaru Impreza Owners Club Monday June 1, 2020
Old 12-14-2019, 04:53 AM   #1
jeff6666p
Member#: 400078
1998 2.5rs06wrx swap
black
Default Gd radiator hose question.
Those who used the gd rad. Did you have to trim both sides of the upper hose to clear or just one. I just released my upper hose is resting on the fan blade.
jeff6666p is offline   Reply With Quote
Old 12-14-2019, 05:56 PM   #2
kaos200
Member#: 2692
I use the GD radiator and i-wire shroud, with Samco GD hoses on a Koyo radiator, no trimming. I do remember on some swaps back in the day we trimmed ever so slightly (depending on what radiator you were using, OE, Koyo, Mishimoto and what block was swapped in) but ever since I redid my swap, no issues at all there.
Re: the fans, I switched to low-profile fans so I don't have that issue, sorry I can't help on that
kaos200 is offline   Reply With Quote
Old 01-20-2020, 07:38 PM   #3
HOK
Member#: 447
1999 RSTI
Trimmed both sides of the upper hose... i put a greddy water sensor adapter in to make it easier... it was tough to put in even using grease but it doesn;t leak... looking at silicone options but will look just as twisted and just more expensive...
HOK is offline   Reply With Quote
Old 01-20-2020, 11:27 PM   #4
subaru_gc8
Member#: 29292
2004 WRX wagon
yes, when I changed my radiator to a aluminum one, the first one i changed got taken out by the fan, so the second one, I cut so it sat a little more towards the engine and I havent ahd a problem since
