02-07-2010, 12:49 AM | #1 |
Member#: 218185
South East
Vehicle:2016 WRX STI Blue |
best location for fuel pressure sensor
Which do you think is the best location to tap for fuel pressure, in the distributor block of this fuel rail kit?
http://www.agency-power.com/catalog/...09-p-7778.html or in the pressure sensor port in this fuel pressure regulator? http://www.sard.co.jp/after/products...regulator.html Thanks!
02-07-2010, 09:53 PM | #2 |
Member#: 218185
South East
bump anyone?
02-08-2010, 06:01 AM | #3 |
Member#: 192599
Vehicle:2004 STI 2007 Outback Wagon |
Anytime you check/install fuel pressure, as close to delivery as possible. So that block would be fine.
02-08-2010, 02:08 PM | #4 |
Member#: 218185
South East
awesome, thank you very much. As it turns out, the sensor "Auber instruments fuel pressure sensor" will not fit on the SARD fuel pressure regulator port. The sensor is too wide and catches on the outer ring of the FPR. So it looks like I have no choice but to put it on the distribution block. Nice how that worked out. Here is a pic of my FPR/EGT setup. I posted the auber setup before with my intake temperature monitoring system and they liked it, so here is a link to more about their stuff just in case anyone else is interested.
http://www.auberins.com/index.php?ma...cdccef1a38baa4 |
Best Location for a WBO2 Sensor? | williaty | Normally Aspirated Powertrain | 4 | 02-07-2008 07:36 PM |
tap location for fuel pressure sensor | HubbieScooby | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 08-05-2004 06:21 AM |
Source for Fuel Pressure Sensor | Aus_RS | Normally Aspirated with bolt-on Forced Induction Powertrain | 3 | 03-23-2004 11:34 PM |
Best place for fuel pressure sending unit | quickgtp | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 12-30-2003 04:48 PM |
Best Location for Rear O2 Sensor? | Austin | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 08-02-2002 10:39 PM |
