Welcome to the North American Subaru Impreza Owners Club Thursday September 20, 2018
Old 02-09-2011, 09:41 PM   #1
RealDealTarheel
Member#: 142447
2018 F-150 Lariat
17 Focus RS
Default V-7 EJ207 into 05 STi?
I have in my possession an 05 STi, and a V-7 EJ207 with the ecu and entire harness to include the body harness. I want to make those two friends using the 05 STi ecu, is this do-able? I know an aftermarket EMS would work just dandy, but due to the wonderfulness that is OBD-II emissions this is just not a possibility for my car.
RealDealTarheel is offline   Reply With Quote
Old 02-10-2011, 03:42 PM   #2
RealDealTarheel
Member#: 142447
2018 F-150 Lariat
17 Focus RS
Anyone?
Old 02-10-2011, 06:53 PM   #3
SubasaurusWrex
Member#: 70285
2011 JCW Mini
Midnight Black/Red roof
very confusing, do you want to use the V7 ecu or the 05 STi ecu?
SubasaurusWrex is offline   Reply With Quote
Old 02-10-2011, 07:29 PM   #4
RealDealTarheel
Member#: 142447
2018 F-150 Lariat
17 Focus RS
05. Looking to use the USDM ECU, intake manifold, injectors and harness, JDM everything else.
Old 02-11-2011, 12:20 PM   #5
RealDealTarheel
Member#: 142447
2018 F-150 Lariat
17 Focus RS
After talking with my tuner apparently it's a relatively straightforward affair. Just need to change the cams and tune for the 2.0l motor.
Old 02-11-2011, 01:01 PM   #6
IDRVSLO
Member#: 194375
2015 MB GLA45
Mountain Grey
Sell the 207 and buy a 257...I dont see why would want to go down in engine size?
IDRVSLO is offline   Reply With Quote
Old 02-11-2011, 02:56 PM   #7
RealDealTarheel
Member#: 142447
2018 F-150 Lariat
17 Focus RS
Ever driven an EJ207 powered car?
Old 02-11-2011, 06:50 PM   #8
illmatic
Member#: 3536
2017 SWP BRZ PP, FXT
2002/2003 AW/PSM WRX
Anything is possible with time and money. Ultimately, what is your goal? I'd swap the EJ207 into a GC/GF and do a 2.34L long rod with your current EJ257(sounds like you want high RPM power band). You will also have to convert the V7 intake manifold to DBW and I'm not sure if the AVCS wiring will be the same.
Maxwell Power 2.34L GB
http://forums.nasioc.org/forums/show....php?t=2103960
illmatic is offline   Reply With Quote
Old 02-12-2011, 08:01 AM   #9
RealDealTarheel
Member#: 142447
2018 F-150 Lariat
17 Focus RS
From what my tuner is saying I just need to use my current intake manifold, injectors and harness. My goal is to drive an EJ207 again. I have no desire to build an engine right now if I don't have to. But if I were going to do so, the MP 2.3l is the way I'd want to go.
Old 03-30-2011, 10:22 AM   #10
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
I'm sure that you resolved what you set out to do, by now.
I just wanted to comment that for the future, the best way may turn out to be to swap a V10 EJ207, for USDM Sti owners.
I did not find yet any documented swaps, but the V10 is throttle by wire and seems to be a very strong shortblock, different casting than the previous 207.
For GR series owners, this V10 is dual AVCS. Now, if the past is to be any guide for the current situation, AVCS capabillities with JDM hardware, may turn out to be different than USDM
What this means is: The USDM exhaust AVCS was somewhat dissapointing, when people went to tune it trying to extract more power.
JDM exhaust AVCS may be much more capable, just as JDM intake AVCS.
Also, the V10 EJ207 can only be Spec C.
This is only speculation, but maybe an USDM GR series ECU could be made to control the GR 207, without too much trouble?
Old 03-30-2011, 07:01 PM   #11
Homemade WRX
Member#: 33782
96 3MI Racing LLC
search FIRST, then PM!!!
easiest way is take off the cam sensors, solenoids and cams and swap over USDM parts...this way the ECU doesn't know the difference...
by retaining the usdm cams and sensors, the ecu doesn't know the change as it'll receive the same signal type. The solenoids I'm not 100% sure if the swap is necessary as I've seen it written either way.
do you still have the jdm bits btw? I'd be interested in them and the ecu if you have it. I've been looking to run usdm avcs heads with jdm parts on my newly picked up bugeye
Old 06-05-2011, 12:51 AM   #12
smokeynyc
Member#: 235198
97 V7 207'd GC
04 JBP WRX
Anyway to get this to work running the JDM ecu? I got a V7 in my GC, but the age of the body is really starting to get to me and I was looking at alot of STI shells to transplant my motor into. Would you have to change out the entire bulkhead? The dash swap in my GC has kinda turned me off from doing that again lol.
smokeynyc is offline   Reply With Quote
Old 11-18-2013, 10:02 PM   #13
dfoy01
Member#: 315002
16 WRX
CPW
Has anyone completed this?
Im currently trying to do this very samething.
dfoy01 is offline   Reply With Quote
Old 11-20-2013, 10:30 PM   #14
sleepysubie
Member#: 81069
1995 ej257 gm6 ewg
A/R .60 Rotated
I have. Pm me your phone number and ill text you. It's pretty easy actually
sleepysubie is offline   Reply With Quote
Old 11-20-2013, 10:41 PM   #15
amroof
Member#: 211224
2005 Saabaru
Who knows
I also have multiple times. I can also walk you through this.
amroof is offline   Reply With Quote
Old 11-26-2016, 08:07 PM   #16
sbecke10
Member#: 458800
Default Ej207 in Outback Xt
I recently bought an outback xt with a ej207 swap. The swap retained the ej257 intake and DBW. The swap runs. It has a long crank and several cam codes. It is appears there are some differences in the ej207 vs ej257 cam sensors. How is the easiest way to make this work and run correctly?
sbecke10 is offline   Reply With Quote
Old 11-26-2016, 08:08 PM   #17
sbecke10
Member#: 458800
I have an ej207 in a 2005 outback xt. There seems to be an issue with the cam sensor. Is there a way you could walk me through what needs to be done to correct this?
Old 11-26-2016, 08:21 PM   #18
H_wells3000
Member#: 322035
You are in a pickle.
No way that I know of to make the jdm rear cam sensors work with the usdm ecu and vice versa. The sensors send different kind of signals and the camshafts have different pickups.
I've heard of swapping the cam shafts, in your case putting usdm cams and rear cam sensors into your block. But it isn't plug and play. I don't think the usdm sensor is an exact fit in the jdm block.
H_wells3000 is offline   Reply With Quote
Old 11-30-2016, 07:57 AM   #19
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
you might be able to make it work if you find a 16bit JDM ECU w/ AVCS Control, and then find a v7/v8/v9 complete intake manifold /w cable driven throttle.
essenstially, im saying to convert to cable throttle. all you should need is the correct ecu and intake then wire it all up. wont be simple though. also would need a few little things like a pedal and a cable.
or
you could sell the 207 since its worth alot and buy a 257 longblock for probably less than what you would sell the 207 for.
Titter is offline   Reply With Quote
Old 12-02-2016, 04:38 PM   #20
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
This... a million times this.
DHRDAN is offline   Reply With Quote
Old 04-30-2018, 11:38 PM   #21
diehard733
Member#: 483991
Default Do it because you enjoy it
Don't mean to revive a dead thread but I feel like the last answer is sudden and simplified. Sure you probably could just get a stock still engine although as an enthusiast shouldn't we build these cars how we want? If you want to swap in a 207 sounds like we need to change to usdm cams, cam sensors, and for these dbw cars I would use your usdm intake and get a tune? What else am I missing? I'm not going to fight a wiring harness on a car that is so similar. Why not just treat it as a long block swap like in a wrx??
diehard733 is offline   Reply With Quote
06 6spd into 05 sti blue05 Transmission (AT/MT) & Driveline 3 07-22-2008 01:59 AM
Interior Swap Compatibility: 05 WRX into 05 STi ??? worksti Interior & Exterior Modification 3 08-06-2007 03:40 AM
TSX lens swap into 05 STI AnorexicSTI Vancouver Impreza Club Forum -- VIC 1 06-14-2007 11:27 AM
Bracket for 6.5" speakers into 05 STi STI2NV Car Audio, Video & Security 11 09-12-2006 04:01 PM
JDM Ver 7 seats into '04 STi PRODRIVEN Interior & Exterior Modification 1 09-03-2005 06:21 AM
