Welcome to the North American Subaru Impreza Owners Club Wednesday November 14, 2018
Old 07-01-2008, 01:13 AM   #1
Brydon
Member#: 107569
1998 Forester S
SRP
Default 1999/2000/2001 RS Wiring Swap to WRX or STI (Help me add notes!)
For all those people looking to do a USDM WRX or STI swap this is your thread! I'm putting a list of swapped wires together to make the conversion really easy for people looking to do this themselves. If I have forgotten anything or if you would like to add anything don't be shy. These are guides I made for myself so I can follow them just fine but I don't know if anyone else thinks like me. Anyway here you are This is a start and cars that I have done so these should be correct. I would eventually like to add wire colors but I haven't got around to it.
Just click on the links below and you will get to the wiring guide you are look for. Or scroll down to view them all. Let me know what I can do to make this more useful. I have lots of pictures of wiring merges but they are a little overwhelming when you first see them.
Conversion From 2002-2005 WRX to 1998RS
Conversion From 2002-2005 WRX to 1999/2000/2001
Conversion From 2004 STI to 1999/2000/2001
Conversion From 2005 STI to 1999/2000/2001
Conversion From 2006 STI to 1999/2000/2001
Conversion From 2007 STI to 1999/2000/2001
USEFUL STUFF TO KNOW BEFORE STARTING:
Immobilizer:
Drive by wire pedal plug for a 2005 STI:
Drive by wire pedal plug for a 2007 STI and Immobilizer Wiring. The Immobilizer wiring is the same but the 2007 Pedal was changed:
In this picture you can clearly see where the Immobilizer and Antenna and Key are located on the STI column:
Note: For all Immobilizer cars the Key, Immobilizer Unit, and ECU need to match in order for the car to start.
Fuel pump controller:
Fuel pump, DBW, ECU power relays:
Brydon is offline   Reply With Quote
Old 07-01-2008, 01:14 AM   #2
Brydon
Member#: 107569
1998 Forester S
SRP
Conversion From 2002-2005 WRX to 2000 RS Pinout
Description - WRX pin location - RS pin location
*VSS B134/1 - B135/24
*Starter Switch B134/16 - B135/28
*A/C Switch B134/2 - B135/27
*Ignition Switch B134/5 - B135/7
*Neutral Position B134/8 - B135/26
*Test mode connector B134/14 - B135/14
*Back-up Power B137/10 - B136/9
*Control Power B137/2 - B136/1
*Control Power B137/3 - B136/2
*Sensor Power Supply B135/9 – B136/15
*Ground (Power Supply) B136/17 - B134/8
*Ground (Control System) (B134/7&15) – (B135/6&25)&(B136/21&22)
*Self Shutoff Control B134/6 - B135/19
*Line End Check 1 B134/10 – B135/20
*Line End Check 2 B134/20 – B135/12 This is the OBDII connector Pin 5 but needs to be moved to pin 8 to make reflashing possible (Doesn’t exist on the RS so you need to Repin the OBDII connector or try switching to a 2002+ OBDII connector.)
*A/C relay B137/27 - B134/17
*Fan1 Relay B137/17 - B134/3
*Fan2 Relay B137/28 - B134/12 *Changed from actually wiring diagram one says pin2*
*CEL light B137/15 - B134/11
*Tach B136/9 - B134/30
*fuel tank pressure sensor B135/15 - B136/12
*Fuel tank pressure solenoid B137/22 - B134/1
*Drain valve B137/11 - B134/10
*Fuel level sensor B135/25 - B136/27
*Fuel temp sensor B135/6 - B136/26
*Small light B134/17- B136/3 (Doesn’t exist on 99 RS only on 2000+)
*Blower fan switch B134/9 - B136/30 (Doesn’t exist on 99 RS only on 2000+)
*Rear defogger Switch B134/3 - B135/21 (Doesn’t exist on 99 RS only on 2000+)
*SSM/GST Communication line B134/21 - B135/3
*Not complete still need powers and grounds and randoms*
Addition Wiring on the 1999/2000?/2001? RS harness:
OBDII Connector Pin4 B135/11 (G/W) - Not Used for the WRX
OBDII Connector Pin5 B135/12 (Lg/R) - Not Used for the WRX But I use this wire for pin8 for reflashing. This needs to be changed at the OBDII connector.
Fuel Pump Relay Control B134/16 – T’ed to B135/19 (This makes the relay on when the key is on.)
Sensor Ground Joint Connector - Fuel Tank Pressure Sensor Ground (R/Y on RS) - (G/Y on WRX)
W/G RS >>>Water temp>>> W/G WRX to dash gauge
G/W or G/B RS>>>>Oil pressure >>>G/W WRX to dash light.
Addition Wiring on the 2002 WRX harness:
Injectors/Ignition needs switched 12volt Power
2002 WRX Fuel Pump Controller
R122/1 (B) - To the ground leading to the fuel pump (B)
R122/2 (V/W) - Wired directly to the ECU
R122/3 (B/Y) - Wired to the 12Volt power leading to the fuel pump (B/R)
R122/4 (B/W) - Wired to negative side of fuel pump (B)
R122/5 (Lg/R) - Wired directly to the ECU
R122/6 (B/Or) - To positive side of fuel pump (B/R)
Old 07-01-2008, 01:14 AM   #3
Brydon
Member#: 107569
1998 Forester S
SRP
Conversion From 2004 STI to 1999/2000 RS Pinout
Description - STI pin location - RS pin location
VSS B135/27 - B135/24
Starter Switch B137/8 - B135/28
A/C Switch B137/16 - B134/17
Ignition Switch B137/15 - B135/7
Neutral Position B137/9 - B135/26
Test mode connector B137/14 - B135/14
Back-up Power B135/19 - B136/9
Control Power B135/5 - B136/1
Control Power B135/6 - B136/2
Sensor Power Supply B136/16 -
Evaporation Thermo Switch B135/7 - B135/27
A/C relay B135/33 - B134/17
Fan1 Relay B135/25 - B134/3
Fan2 Relay B135/24 - B134/12 *Changed from actually wiring diagram one says pin2*
CEL light B134/17 - B134/11
Tach B134/23 - B134/11
fuel tank pressure sensor B136/21 - B136/12
Fuel tank pressure solenoid B134/12 - B134/1
Drain valve B134/13 - B134/10
Fuel tank valve B134/24 - Not on the RS body will need to be flashed out.
Fuel level sensor B136/20 - B136/27
Fuel temp sensor B136/12 - B136/26
Small light B137/12 - B136/3 (Doesn’t exist on 99 RS only on 2000+)
Blower fan switch B137/13 - B136/30 (Doesn’t exist on 99 RS only on 2000+)
Rear defogger Switch B137/11 - B135/21 (Doesn’t exist on 99 RS only on 2000+)
SSM/GST Communication line B137/20 - B135/3
OBDII Connector Pin4 B135/11 (G/W) - Not Used for the STI
OBDII Connector Pin5 B135/12 (Lg/R) - Not Used for the STI
OBDII Connector Pin8 B135/21 (W/R) - Not Used for the STI
Line End Check 1 B135/20 (R/W) - Not Used for the STI
Fuel Pump Relay Control B134/16 – B137/15
^^^****The Opposite side of the fuel pump relay now needs to be ground instead of power. This can be tapped off of the main relay****
Self Shutoff Control B135/19 – B137/15
W/G RS >>>Water temp>>> W/G STI to dash gauge
G/W or G/B RS>>>>Oil pressure >>>G/W STI to dash light.
Addition Wiring on the 2004 STI harness:
Throttle Control relay needs switched 12volt power
2004 STI Fuel Pump Controller
2004 STI Cruise Control:
B134/16 - Set light on dash - B161/6 (B)
B134/15 - Cruise light on dash - B161/4 (V)
B134/1 - Clutch switch - B94/9(L/Or)
B136/11 - Set/coast - B94/6 (Lg/B)
B136/9 - Brake switch1 12v switch - B94/8 (R/Y)
B136/8 - Brake switch2 12v switch - B94/19 (W/B)
B136/10 - Resume/accel - B94/7 (R/W)
B136/7 - Cruise button on - B94/4 (Br/W)
**RS Connectors at stock cruise module**
B94/5 (Y/G) spliced to B94/3 (G/B)
B161/2 need to be T’ed to B161/1
B107/1 needs to be T’ed to B94/8
Old 07-01-2008, 01:14 AM   #4
Brydon
Member#: 107569
1998 Forester S
SRP
Conversion From 2005 STI to 1999/2000 RS Pinout
VSS B135/26 - B135/24
A/C Switch B137/17 - B134/17
Ignition Switch B137/14 - B135/7
Test mode connector B137/15 - B135/14
Sensor Power Supply B136/16 – B136/15
Evaporation Thermo Switch B137/16 - B135/27
Immobilizer B137/19 - Immobilizer/Pin10
Immobilizer B137/27 - Immobilizer/Pin23
Fuel Pump Relay Control B134/16 – B137/14
Self Shutoff Control B135/19 – B137/14
Addition Wiring on the 2005 STI harness:
2005 STI Fuel Pump Controller
2005 STI Cruise Control:
Immobilizer Pinouts:
Pin 1: Antenna
Pin 2: Fused 12v power (Power into Main Relay)
Pin 3: Fused 12v power (Power into Main Relay)
Pin 5: Security Light on dash ???
Pin 8: Door light switch (Yellow wire from doors, color is the same on STI and 99RS)
Pin 9: Keyless entry wire but T'ed to impact sensor. This does not exist on the 99 RS. But I think you will be ok.
Pin 10: ECU wire (B137/19)
Pin 14: Antenna
Pin 15: Ground (B137/1)
Pin 23: ECU wire (B137/27)
Pin 24: Ignition fused 12v Power (B135/19)
Pin 25: Ground (B134/5)
Pin 26: Ignition Starter & Steering Lock assembly T’ed to (B137/14)
Old 07-01-2008, 01:14 AM   #5
Brydon
Member#: 107569
1998 Forester S
SRP
Conversion From 2006 STI to 1999/2000 RS Pinout
Evaporation Thermo Switch B137/17 - B135/27
Addition Wiring on the 2006 STI harness:
2006 STI Fuel Pump Controller
2006 STI Cruise Control:
Pin 1: Antenna
Pin 14: Antenna
Old 07-01-2008, 01:15 AM   #6
Brydon
Member#: 107569
1998 Forester S
SRP
Conversion From 2007 STI to 1999/2000 RS Pinout
VSS B136/13 - B135/24
Backup power supply B135/5 – B136/9
Starter Switch B136/32 - B135/28
Ignition Switch B135/19 - B135/7
Neutral Position B136/31 - B135/26
Test mode connector B135/27 - B135/14
Line end check - nothing
Control Power B134/7 - B136/1
Control Power B135/2 - B136/2
Evaporation Thermo Switch B136/24 – B135/27
A/C relay B136/9 - B134/17
Fan1 Relay B136/18 - B134/3
Fan2 Relay B136/29 - B134/12 *Changed from actually wiring diagram one says pin2*
CEL light B136/11 - B134/11
Tach B136/22 - B134/30
fuel tank pressure sensor B135/32 - B136/12
Fuel tank pressure solenoid B136/28 - B134/1
Drain valve B136/17 - B134/10
Fuel level sensor B135/10 - B136/27
Fuel temp sensor B135/17 - B136/26
Small light B135/15 - B136/3 (Doesn’t exist on 99 RS only on 2000+)
Blower fan switch B135/16 - B136/30 (Doesn’t exist on 99 RS only on 2000+)
Rear defogger Switch B135/14 - B135/21 (Doesn’t exist on 99 RS only on 2000+)
SSM/GST Communication line B136/16 - B135/3
5Volt Power supply B135/22 - B136/15
Immobilizer B136/26 - Immobilizer/Pin10
Immobilizer B136/34 - Immobilizer/Pin23
Self Shutoff Control B136/23 - B135/19
AT/MT identification signal – T’ed to ground
CAN communication + B136/27 –
CAN communication – B136/35 –
Addition Wiring on the 1999/2000/2001 RS harness:
Fuel Pump Relay Control B134/16 – B135/19
^^^****The Opposite side of the fuel pump relay now needs to be ground instead of power. The Main Relay needs to be power instead of ground. This can be done by swapping the Main Power Relay and Fuel Pump Relays power and ground. These are the wires opposite the side that go back to the ecu****
2007 STI Fuel Pump Controller
2007 STI Cruise Control:
B135/3 - Set light on dash - B161/6 (B)
B135/6 - Cruise light on dash - B161/4 (V)
B135/12 - Cruise button on - B94/4 (Br/W)
B135/13 - Resume/accel - B94/7 (R/W)
B135/20 - Brake switch 12v switch - B94/8 (R/Y)
B135/24 - Set/coast - B94/6 (Lg/B)
B135/28 - Brake switch 12v switch - B94/19 (W/B)
B136/25 - Clutch switch - B94/9(L/Or)
Pin 1: Antenna
Pin 8: Door light switch (Yellow wire from doors, color is the same on 07STI and 99RS)
Pin 10: ECU wire (B136/26)
Pin 14: Antenna
Pin 15: Ground (B134/5)
Pin 23: ECU wire (B136/34)
Pin 24: Ignition fused 12v Power (Power into Main Relay)
Pin 26: Ignition Starter & Steering Lock assembly (B135/19)
Old 07-01-2008, 01:16 AM   #7
darksc00by
Member#: 102140
2016 Single Speed or
Death
sticky.
darksc00by is offline   Reply With Quote
Old 07-01-2008, 02:14 AM   #8
anjion24
Member#: 64882
bump hes my roomate so I'm cool by association!!!
anjion24 is offline   Reply With Quote
Old 07-01-2008, 02:59 AM   #9
silentt
Member#: 119995
2004 Outback XT
Peachy
Vote for sticky.
silentt is offline   Reply With Quote
Old 07-08-2008, 12:50 PM   #10
camaroz1985
Member#: 155906
1998 Impreza 2.5RS
Rally Blue
Please make this a sticky
camaroz1985 is offline   Reply With Quote
Old 07-08-2008, 01:41 PM   #11
SlickRick51586
Member#: 66735
2004 WRX
sticky!!!!
SlickRick51586 is offline   Reply With Quote
Old 07-09-2008, 02:17 AM   #12
lonewolf503
Member#: 184148
2001 2.5rs 2dr
51e
so is 06 wrx the same as 06 sti to 01 rs
lonewolf503 is offline   Reply With Quote
Old 07-09-2008, 02:45 AM   #13
ToastermonkeyPat
Member#: 159826
1995 Impreza L
Aegean Blue
definitely sticky this asap!
ToastermonkeyPat is offline   Reply With Quote
Old 07-09-2008, 10:23 AM   #14
camaroz1985
Member#: 155906
1998 Impreza 2.5RS
Rally Blue
I've been comparing 07 WRX to 07 STI and have only found one difference so far, and it was only off by one pin number.
You should go through the wiring on your own to double check.
Old 07-09-2008, 12:52 PM   #15
lonewolf503
Member#: 184148
2001 2.5rs 2dr
51e
thanks
Old 07-21-2008, 06:41 AM   #16
Brydon
Member#: 107569
1998 Forester S
SRP
Nope, 06 WRX is actually a 07 STI.
Old 07-24-2008, 02:08 PM   #17
mjd85la
Member#: 35176
1998 2.5 RS Impreza
2000 gray OBX
Any future info the 98's?
mjd85la is offline   Reply With Quote
Old 07-28-2008, 08:49 PM   #18
RobK0000
Member#: 62230
I know the main harness's have to merged along with the fuel pump, but i wasnt sure about accessories. Do the subaru harness's throughout the years use the same window, lock and light plugs and adapters?
RobK0000 is offline   Reply With Quote
Old 07-30-2008, 12:00 AM   #19
Brydon
Member#: 107569
1998 Forester S
SRP
No they do not! You need to not touch those. just merge the engine stuff and dont worry about the accessories like AC/Windows/Locks/fuse box/lights/etc... This will just end up causing something to not work when you are done.
Old 10-10-2008, 06:14 PM   #20
powerneedy
Member#: 161242
awesome info but do you have any info for my setup? its a 95 impreza with a 04 sti motor 04 dash/havc and 04 sti wiring in the car... my problem is the fuel pump what do i need to do to run my fuel pump? what wires do i need to splice into? thanks
powerneedy is offline   Reply With Quote
Old 10-11-2008, 12:58 AM   #21
mannac
Member#: 161038
2014 FiST
Well done brydon. I think you gave me the wiring diagram for the fuel system over at rs25. Thanks
mannac is offline   Reply With Quote
Old 11-03-2008, 03:25 PM   #22
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
Are you sure this fuel pump controller wiring is correct? Im having a hard time trying to get my wrx fuel pump controller to work with my 02 wrx ecu. Actually i have a 04 jdm sti ecu (it uses the wrx 5 clip style). I have the pdf at home, it shows something totally different. See below.
1.B+ 12v
2.DI To ecu
3.ECU To ecu
4.FP+ 12v to fuel pump
5.FP- Ground to fuel pump
6.E. Ground
The weird thing is, when i follow the diagram from the 02 wrx. The pump seems to be running backwards (sucking fuel instead of pumping it). It i reverse the power and ground, car starts right up. My car runs fine, only issue i have is when i turn the key to the ON position, the pump runs 100% of the itme, it doesnt prime then shutoff like it should. My car is a 99 rs
ImprezaRSfan! is offline   Reply With Quote
Old 11-03-2008, 04:06 PM   #23
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
i have my fuel pump controller hooked up like in the diagram below and the pump doesnt shutoff when the key is in the ON position. It just runs continuously. Any ideas? Car runs great..
Old 11-04-2008, 12:01 PM   #24
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
The wiring for the fuel pump controller changed a couple times over the years. Your best bet is to look at the controller itself and the markings on it. It should be marked with what each pin does. Verify that each wire is going to the correct circuit and that should resolve your issue. The Black wire always goes to ground and the Black/Yellow to the FP relay. The other two I have seen them in either location so your best bet is to look at the FPC and confirm which wire goes to which on the FP.
Z
Zephyr is offline   Reply With Quote
Old 11-04-2008, 02:51 PM   #25
Sparky280
Member#: 69896
98 WRX Swapped "L"
VF39 294HP/277TQ @19psi
Default 98 wiring
So what's with the 98 hate? heh... I made this table to help me with my wiring of my 02 harness into my 98L
Any comments or additions could help others my swap runs fantasticly with AP protune
Sparky280 is offline   Reply With Quote
2.5i to WRX or STI swap SUBYAWD85 Normally Aspirated Powertrain 47 08-25-2009 07:39 AM
99 RS to WRX or STI dfyzfzx Subaru Conversions 5 07-08-2007 10:29 PM
2001 BRP RS Coupe; Bad Motor; WRX or STI swap cadidate; In PA Tattoo Collector Private Vehicle 'For Sale' Classifieds 27 11-14-2005 06:58 AM
06 WRX or STI??? Help Me srsaccount General Community 7 10-07-2005 01:54 AM
Subaru Nubaru - Considering WRX or STi - Help me decide Jeff Johnston Impreza Forum 15 09-30-2004 08:20 PM
