04-24-2012, 09:21 AM | #1 |
Vendor Sales Rating: (43)
Member#: 198281
MAIC
Vehicle:2005 WRX/STi WRB of course |
Killer B Ultimate OIL PICKUP Now for EJ20 Oil pans! PLUS Temperature Sensor Adapter!
Two new products from Killer B Motorsport!
1/2NPT to 1/8PT Oil Temperature Sensor Adapter will allow the use of aftermarket oil temperature sensors with the 1/2NPT port on our oil pan instead of having to use an OEM plug adapter. Made in the USA from solid 304 Stainless Steel. LINK HERE We now have EJ20 OEM "flat bottom" oil pan, Ultimate Oil Pickups in stock. The OEM oil pan no longer needs to be changed to the newer 'STi' style oil pan as in the past. We've always recommended those that do any 'performance' type driving to upgrade to an STi oil pan to protect against oil starvation under severe cornering, but for those EJ20 owners that don't drive like a lunatic, there's no point in changing the OEM oil pan. Now the faulty OEM oil pickups can be replaced without replacing the OEM oil pan, baffle, dipstick, dipstick tube, on EJ20 engines! If you own a Lagacy, Forester, or Outback and are considering this upgrade please visually verify your oil pan before ordering, since part number changes do not always follow model year changes. LINK HERE Same robust design, now made for the EJ20 Also available through you local retailer/shop
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. vs. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
04-30-2012, 10:39 AM | #2 |
Member#: 198281
MAIC
Adapters going out at a pretty good pace. Thanks for the orders!!
__________________
05-14-2012, 10:28 AM | #3 |
Member#: 198281
MAIC
NPT to BP senders in stock!
__________________
05-21-2012, 09:35 AM | #4 |
Member#: 198281
MAIC
In stock and we're almost ready to release the OEM plug tapped for 1/8PT
__________________
05-31-2012, 08:49 AM | #5 |
Member#: 198281
MAIC
We're out of stock on these already! Should have more set to go early next week...
And the OEM to 1/8PT sender adapters should be ready then too. Pricing should be ~$16
__________________
06-04-2012, 08:03 AM | #6 |
Member#: 198281
MAIC
OEM to 1/8PT Sender Adapters added to website. You can get them with an EOM crush washer for use with an OEM oil pan, OR, a copper washer for use with our high performance oil pan.
LINK HERE
__________________
07-02-2012, 08:43 AM | #7 |
Member#: 198281
MAIC
Guys thanks for the orders on these!!
__________________
07-17-2012, 11:22 AM | #8 |
Member#: 198281
MAIC
Thanks again guys! We've got plenty in stock and will do our best to keep it that way!
__________________
11-29-2012, 09:33 AM | #9 |
Member#: 198281
MAIC
OEM to 1/8BP adapters are made using OEM oil plugs.
__________________
Similar Threads | ||||
Killer B Ultimate OIL PICKUP Now for EJ20 Oil pans! PLUS Temperature Sensor Adapter! | KillerBMotorsport | Vendor Announcements | 10 | 11-29-2012 09:33 AM |
Mishimoto Water Temperature Sensor Adapters Released! | Mishimoto | Vendor Announcements | 1 | 01-07-2011 11:04 AM |
Oil Pickup Needed for 02 WRX Build? | rexblake | Built Motor Discussion | 4 | 10-02-2009 07:14 PM |
360 pickup now for sale in Hood River Oregon | Eurowrx | North West Impreza Club Forum -- NWIC | 3 | 04-08-2006 03:35 PM |
need to know oil filter threads for remote oil filter | Gravel-Fun | Normally Aspirated Powertrain | 2 | 07-22-2002 05:23 PM |
