Welcome to the North American Subaru Impreza Owners Club Friday September 20, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 06-24-2019, 05:01 PM   #1951
fishfangs
Member#: 425438
2015 WRX
ISM
Originally Posted by druidtime View Post
i looked up the tester and haven't seen that one before. i thought the only testers available were the strips, but that thing seems like a major PITA imo.
you have to wait 5 minutes for the test to work and in turn piss off everyone waiting to get gas or ethanol. and how are you supposed to get the e85 in there? squirt it in directly from the nozzle?
seems messy and also, what will you do with the water and e85 mix once the test is complete?
dump it in the tank? pour it down the drain? 'yikes', and 'i hope not' goes to both of those options. flexfuel sensor, low pressure fuel pump (and hopefully a HPFP will come out soon) for me here as a next step after FBO.
His process is a huge pain but he's fine with it. He'll go when the station is empty, pump 91 and leaving some room for E85, push his car to the E85 pump, test, calculate, then fill. No idea what he does with the water/E85 mix though.
On the topic of the HPFP, it looks like Nostrum may have started selling units, but it looks like they're OOS for now:
https://www.nostrumshop.com/product/...ure-fuel-pump/
fishfangs is offline   Reply With Quote
Old 06-24-2019, 05:29 PM   #1952
druidtime
Member#: 480777
2016 WRX
Thanks for the link to the hpfp. I heard there was one in the works and i think it's this one.
I went FBO at 30k and plan to do E85 at 50K when i swap out plugs the next time. Currently at 35K which gives me about 1.5yrs before the 50K mark, so hopefully the guinea pigs here will show over that time if the hpfp is a winner or loser
some people are proud of going out of their way to pursue something they love. no knocks on that. i still change the oil on both of my cars even if it takes up my time and i enjoy doing it.
but imo if you are running high e contents and also driving like a dick, you'll be refuelling a lot more often compared to pump gas! personally, having to wait and the resulting calculations/math would kill me.
the stations by my house have ethanol-only pumps separate from the gas pumps, so having to drive up from the E pump to the gas pump would already be a hassle.
druidtime is offline   Reply With Quote
Old 06-24-2019, 05:33 PM   #1953
anarekist
Member#: 468117
2017 WRX
DMG
rumor has it that ibuildracecars has a hpfp in the works as well, would be prudent to wait for the results of both.
anarekist is offline   Reply With Quote
Old 06-24-2019, 06:12 PM   #1954
adam99
Member#: 480524
2015 WRX
Selling a solution for around $600-700 cheaper. Should be out soon
adam99 is online now   Reply With Quote
Old 06-24-2019, 08:38 PM   #1955
Ikibanchowda
Member#: 488173
2018 WRX
Black Silica
Originally Posted by dpetro1 View Post
Off topic but I would be interested in what you are referring to. In my experience there is no difference in the ebcs by year. Are you referring to the 2018 crankcase vent with the white connector on the turbo inlet?
That is the one. White connector with a wire harness attached to it. I noticed that too when installing my ECBS this weekend
Ikibanchowda is offline   Reply With Quote
Old 06-25-2019, 02:22 PM   #1956
CharlesPhoto
Member#: 188532
19 WRX
Originally Posted by blakestree View Post
Thanks for the reassurance! Would you call it a huge improvement in drivability?
Delayed response. Helped with the Rev hang which was driving me nuts. Pretty solid power pickup from stock.
CharlesPhoto is offline   Reply With Quote
Old 08-21-2019, 03:24 PM   #1957
bluewrx2018
Member#: 485226
~2018 WRX
~11,xxx Miles
Perrin Intake, Perrin Motor Mounts, Cobb AP, Perrin Header, Perrin Tranny Mount, MAP J Pipe with HFC, MAP Exhaust with Muffler Deletes
~93 Octane
~Motul 8100 X Clean 5/30
~Normal driving conditions. ~Commuting to work 55MPH
~Threw a rod cylinder 2
*Currently doing a engine build with a supporting platform of 500 HP.
bluewrx2018 is offline   Reply With Quote
Old 08-21-2019, 03:59 PM   #1958
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by bluewrx2018 View Post
~2018 WRX
~11,xxx Miles
~93 Octane
Assuming this had a protune of some sort, or OTS tune?
KillerBMotorsport is online now   Reply With Quote
Old 08-21-2019, 04:06 PM   #1959
bluewrx2018
Member#: 485226
OTS 🤢
Old 08-21-2019, 04:09 PM   #1960
GlarryHoodDIT
Member#: 460907
2016 WRX
What OTS map?
GlarryHoodDIT is online now   Reply With Quote
Old 08-21-2019, 04:11 PM   #1961
standardtranny
Member#: 450713
2017 WRX Stage 3ish
world rally blue
OTS 🤢
What kind of OTS tune supports headers and all that
standardtranny is offline   Reply With Quote
Old 08-21-2019, 04:12 PM   #1962
bluewrx2018
Member#: 485226
Originally Posted by GlarryHoodDIT View Post
What OTS map?
Cobb Stage 2+
Old 08-21-2019, 04:14 PM   #1963
bluewrx2018
Member#: 485226
None really, guess being lucky for so long made it ok. And it wasnít in the long run.
Old 08-21-2019, 04:17 PM   #1964
bluewrx2018
Member#: 485226
Started a build page with some build details:
LTís FA20 Engine Build
