08-16-2018, 10:08 PM | #76 | |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
OTOH, when I was working on these daily, it took me 100 minutes to pull the engine, 90 minutes to do the cam swap, and 120 minutes to put the engine back in the car. So about half the time to do it via pulling the engine and the final result was better done.
08-17-2018, 11:07 AM | #77 |
Member#: 437670
Vehicle:2005 2.5 SC OB |
2006 Subaru 2.5i Delta Cam Install
Ok thank you. You don’t pull the heads once the motor is out if not needed, right? I was hoping to avoid removing motor until I needed to do bottom end otherwise I’ll get into the old “while I have the motor out, might as well...” heh.
08-17-2018, 11:35 AM | #78 | ||
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Heavy blanket on the fender, maybe an antidepressant and start to work. Some of us have an engine hoist. While you "can" do some work engine in, why? No, no need to pull heads if doing cams. I would also highly think of a full valve cover set while the covers are off, maybe plugs, timing belt, etc. |
08-17-2018, 11:54 AM | #79 | |
Member#: 71092
As noted, you'll need to do valve cover gaskets, as well as the front and rear cam seals. The rear ones seem to confuse the hell out of most parts counter guys, sadly. You'll also need Fujibond or at least Ultra Grey to glue the cam caps back on. The cam caps require a small-ish hex bit as well as a Torx Plus bit. IIRC it's a Torx Plus 40, but it's been a long time so I'm not 100% sure of the size. I am 100% sure it's a Torx Plus, though, and you MUST have the right bit for it. May as well check the clutch, timing components, and the oil pan as well. |
08-18-2018, 06:54 AM | #80 |
Member#: 437670
Ok cool. Yeah we just did headgaskets,
Clutch, timing components and oil pan. Unfortunately at the time it was my only car and daily driver. It would have been the perfect time for cams but it wasn’t on my mind at that time!!! Wondering what the power potential is here on a 10psi supercharged 253. I am hoping cam will drop boost(less restriction) quite a couple psi. Hoping it’d pick up at lest 25whp on my setup but I think more is possible. Last edited by pcampbell; 08-18-2018 at 07:06 AM. |
08-18-2018, 11:46 AM | #81 | |
Member#: 71092
08-18-2018, 05:24 PM | #82 |
Member#: 437670
What kind of impact do you see on a turbo 253 if you’ve done that before?
08-18-2018, 05:47 PM | #83 |
Member#: 71092
08-18-2018, 06:17 PM | #84 |
Member#: 437670
Any forced induction with sohc heads?
08-18-2018, 06:20 PM | #85 |
Member#: 71092
Yeah, did a Ej253 with high compression pistons, a proper header, valve work, mild port, I don't remmeber what the guy was running for boost though. He tried several different cams, profile with the biggest gain was IIRC ~9% and that came at the expense of making it super peaky.
08-20-2018, 05:53 PM | #86 |
Member#: 437670
That is a lot less than I would have anticipated. I remember reading vicious fishes saying 25% gains with exhaust and cam with a Raptor SC (what I run). I am not sure how much of that was cam and how much was exhaust. I am going to reach out to him.
08-20-2018, 05:58 PM | #87 |
Member#: 71092
If he went from a stock header to a TWE header, he actually should have seen even bigger gains than that. I had one NA 2.5L gain ~40hp over stock with just the header change (dynoed before and after). More typical gains from a stock header to TWE are about 30hp.
08-21-2018, 05:24 PM | #88 |
Member#: 437670
Ahhhh nice.
Unfortunately I can't use those headers. My heads are 2004-2005 single port exhaust. They are EL from the factory but lots of catalytic converters in there heh. The solution would probably be to cut out some of those cats out for high flow units . |
08-21-2018, 11:06 PM | #89 | |
Member#: 71092
Unless you're working with heads from some odd part of the world that used a different head design than the "normal" design for that timeframe. |
08-22-2018, 07:31 AM | #90 | |
Member#: 437670
Hah. Yeah odd part of the world being California. They’re 2 year only one off heads, intake and exhaust. |
08-22-2018, 11:55 AM | #91 |
Member#: 71092
08-23-2018, 07:48 PM | #92 |
Member#: 485429
Vehicle:2013 Forester XT Deep Cherry Pearl |
Williaty the twe headers added 30whp? I have a 2006 2.5i and have begun researching what "bolt ons" I can do to gain some power. I know that cams and headers offer the best gains other than forced induction but I didn't realize it was that much. Would you recommend going for headers first then? I did see your posts about hybrid intakes versus CAI and SRI and that was a good write up!
08-23-2018, 08:05 PM | #93 |
Member#: 71092
Your 2006 is completely different in the heads, valves, and exhaust. No idea what you'll see as gains, though I have heard some of the newer guys still speak favorably of Tom's headers for their cars.
Yes, headers are the ONLY thing I'd recommend to make power on a non-turbo EJ25 unless you're prepared to spend $20-$30k to properly do a full engine build and custom tune on a load holding dyno. Nothing else provides enough HP per Dollar to justify bothering with. |
08-24-2018, 12:33 PM | #94 |
Member#: 485429
No point in spending that much money on it when you can just do an engine swap for cheaper or just buy a faster car lol. I've seen a few people have done the raptor or m62 on the ej253. Just debating what I want to do and how much I want to spend. Would header and cams be a good N/A option for the 2006?
08-24-2018, 12:48 PM | #95 | |
Member#: 71092
That being said, my personal engine has (well, had. I don't own a Subaru anymore) the TWE headers and that made it more than sprightly enough for normal use. |
08-25-2018, 03:09 AM | #96 | |
Member#: 411867
E. Canada
Vehicle:2011 Impreza 2.5i WRB |
hi there hybrid intake
Im thinking of swapping ej257 soon. Im gonna need your help. |
08-25-2018, 05:52 AM | #97 |
Member#: 437670
SC is good if you are fine with 200whp but it’s hard to stop there. That’s a stock XT. I’m trying to squeeze 250 out of the SC setup without going too crazy (stock motor). It also drives differently. And I can change my plugs in 20 minutes but I can’t see getting much more power even if you built the motor. I am running the smallest pulley you can run on this model due to SC rev limit (50kish rpm)
I am still surprised the headers would be such a restriction so I’m going to try that. Another option is a total budget eBay turbo setup. I feel like you could get it running for like $1k ish. Last edited by pcampbell; 08-25-2018 at 01:40 PM. |
08-27-2018, 10:48 AM | #98 |
Member#: 485429
@Williaty Yea I've wanted to do things to it but haven't pulled the trigger yet on anything just because of the vast amounts of misinformation out there and trying to find real proof of power gains and for the $ to HP ratio you get from the EJ253 its just not worth it IMO.
Also as far as the header being a big restriction I believe they have catalytic converters in the headers iirc. |
07-14-2019, 04:08 PM | #99 |
Member#: 504244
Lost variable valve springs and pins
07-14-2019, 08:37 PM | #100 |
Member#: 437670
I can post them tomorrow.
FS NH: 2006-2009 2.5i AVLS cams | shtbxr22 | Engine/Power/Exhaust | 1 | 03-15-2010 11:09 PM |
2006 Subaru 2.5i and STI ABS Pump the same? | gilbert_0004 | Brakes, Steering & Suspension | 2 | 02-17-2009 05:00 PM |
2006 Impreza 2.5i Wagon -- can I install a subwoofer? | listentofresh | Newbies & FAQs | 8 | 08-21-2008 08:42 AM |
07 2.5i delta cams | watchunglava | Normally Aspirated Powertrain | 6 | 08-14-2008 10:48 PM |
WTB: Subaru 2006 Outback 2.5i Wheels (rims and tires) | hiskdcome | NWIC Private Classifieds | 0 | 01-24-2006 03:04 PM |
