06-23-2020, 08:46 PM | #1 |
Member#: 454737
AKIC
Vehicle:2005 STI PSM 2013BRZSWP2022ForesterCGS |
2005 STI transmission whine
Hi, I have my 05 sti in the shop for a transmission whine, it has 70k miles the shop claims they have reduced the whine quite a bit by replacing all bearings in the rear, suposedly the only bearing left is in a center differential that is destroyed once opened and subaru does not stock this part? Apparently the sound is coming from the transfer case, sorry if I'm all over the place here but the shop has taken out my transmission like two times and in those two times they did not fully disassemble the transmission only replacing bearings. Is there something they might have possibly missed or something I could bring up or suggest? I have a third party warranty that will cover the work but if nothing is broken or clearly worn then they won't cover the labor to teardown again but there has to be something causing that sound. Just throwing some guesses out there what could it be, and what could go wrong if just ignored. Thanks
06-25-2020, 12:46 PM | #2 |
Member#: 183970
Vehicle:2008 Legacy GT DGM |
I don't know much as to be able to help you but what does it sound like and when do you hear it? I've had a 05 legacy gt and now I have 08 spec b and both had a whine in first and second gear and nowhere else.
Since you mentioned a warranty, I'm assuming you recently bought the car, was the noise already there when you bought it? |
06-25-2020, 04:09 PM | #3 | |
Member#: 454737
AKIC
