Welcome to the North American Subaru Impreza Owners Club Tuesday September 25, 2018
Old 02-16-2018, 08:13 PM   #701
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Originally Posted by WRXROA View Post
Nice !! Send me a PM whenever you want to get rid of this set.
Haha will do
Originally Posted by M3lover1 View Post
I don't know how the other Michelins are compared to the MPSS that I have, but mine rubbed in the rear when I had the RCE Yellows installed. Same exact wheels as your previous setup, with MPSS 265/35/18. It rubbed right on the bumper tab where it meet the fender, so I went back to stock springs.
Anywho, I actually never realized you had Fortune Autos for your coilovers until I went over your thread from the beginning again! My 500s came in this week too...got the black color like you, along with swift upgrade and radial bearings. Only thing different was I added the spring locking perch and have 8k front and 9k rear.
For one who has never installed coilovers before, you have any tips for a noob?
Also, how long did you drive before getting an alignment?
Mich PSSís run very wide. Their 265 is basically a 275 on most other brands. I had 265 PSSís on my nt03ís on the Wrx. Rubbed a lot with those until I got a roll.
Haha yep been running the fortune autos for a while now. I went with the 7k springs front and rear due to daily driving. Iím happy I went with this setup as it is the perfect amount of performance and comfort.
Installing coils is pretty straight forward. My only advice is make sure to release the parking brake when you are doing the rears. It allows for the control arms to drop totally to get the stock suspension out. Youíll have a hard time if you donít.
I have always gone by the 2 week or 500 mike rule before I get alignments. It allows the suspension to settle fully. But make all the tweaks before and make sure itís at the height you want it before getting an alignment.
Originally Posted by kaeknows View Post
what about the firehawk indy 500? they are known as the baby re71r's, would be a good option as well
I am going for all seasons again. I prefer having 1 so it all set so I donít have to worry about changing during the different seasons.
ScoobyFreak86 is offline   Reply With Quote
Old 02-16-2018, 08:39 PM   #702
M3lover1
Member#: 440553
2017 WRX STI Base
Originally Posted by ScoobyFreak86 View Post
Haha will do
Yea that's what I worry about, in that I get it aligned and I end up having to adjust the height, and get it aligned a second time. The main worry I have at not getting the alignment right after is shredding my tires due to incorrect toe/camber/etc.
When you did the fronts, did you adjust the settings on camber plate or just installed as is? For he rears, did you remove the LCA completely? I am thinking of removing all bolts of the LCA except for the outermost that connects it to the wheel hub/outer subframe.
M3lover1 is offline   Reply With Quote
Old 02-16-2018, 08:43 PM   #703
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Toe is what kills tires quickly. Camber wonít right away. Just make sure you adjust to where you want it.
I installed as is and then made height, camber, and damping adjustments to where I wanted and needed it. Itís impossible to adjust everything before you put in since you donít know where the car is going to sit until you lower it for the first time.
Nope not needed. Only bolts I remove are the suspension bolt to the lca and the end link bolt. No need to remove the whole lca. Creating more work for yourself.
Old 02-17-2018, 01:12 PM   #704
M3lover1
Member#: 440553
2017 WRX STI Base
Thanks Chris for your help!
Old 02-18-2018, 01:13 AM   #705
M3lover1
Member#: 440553
2017 WRX STI Base
Hey Chris, sorry couple more questions. I know you have to set preload for the fronts, but did you have to do it in the rears as well? Also, did you apply and silicone lubricant or anti seize to the threads?
Thanks man!
Old 02-18-2018, 01:40 AM   #706
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Thanks man!
Yes you have to set preload to all 4 corners.
I personally did not, but it definitely recommended to do so. I have always been hesitant to add anti seize to coilovers threads since I am afraid it will do the opposite and wonít let me tighten the collars down appropriately which gives them a better opportunity to loosen and move from that setting. I am pretty sure that is just a theory in my own head though haha.
Old 02-18-2018, 02:03 AM   #707
M3lover1
Member#: 440553
2017 WRX STI Base
Got it. Mine are snug out of the box, and measures 6.5in. I thought it was supposed to be 7in springs. So should I loosen the locking spring perch then, and measure the uncompressed spring?
Sorry for the noob questions...
Old 02-18-2018, 02:07 AM   #708
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Default Scoobyfreak86 2017 Lapis Blue Pearl STI Journal
Sounds like they came preloaded. It should only be about 1/4Ē compressed. So a 7Ē spring should be 6 3/4Ē.
Old 02-18-2018, 02:12 AM   #709
M3lover1
Member#: 440553
2017 WRX STI Base
That's what I thought. And Geoff told me that Fortune doesn't preload them, even with him asking Fortune to do so for years. I'll measure the other side and see if the length is the same tomorrow. But i think i'll still uncompress it and get it to 6 3/4". You have radial bearings on yours too right?
Old 02-18-2018, 02:19 AM   #710
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Yes I have the radial bearings as well
Old 02-18-2018, 11:39 PM   #711
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Installed the ijdmtoy led f1 light tonight. Unfortunately, it looks like I got a bad light and 2 of the 4 rows are out. Wiring seemed pretty straight forward, so I donít think that is the issue. I guess thatís why itís only 70 bucks and all the other ones are 100+. Sent them an email of my issue. Hopefully they can help me out or refund me so I can get one that is going to work properly.
Old 02-19-2018, 12:11 AM   #712
M3lover1
Member#: 440553
2017 WRX STI Base
Good luck with it! The F1 led light makes the rear end so much nicer!
Old 02-19-2018, 09:17 AM   #713
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Hopefully their customer service takes care of me. I don't see why they wouldn't, but I'm not holding my breath.
Yeah, I love the look of the F1 light. Hoping to get it situated so I can have it working and move to doing the speakers.
Old 02-19-2018, 09:22 AM   #714
Obviously Tyler
Member#: 395955
2016 WRX
2018 Crosstrek
Regarding the tires, I believe even that A/S Pilot tires run pretty wide compared to others. Just seems to be a trait of Michelin's.
Obviously Tyler is offline   Reply With Quote
Old 02-19-2018, 09:32 AM   #715
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
I ran them on my SBC nt03's and gramlight 57xtremes in 265 and they were slightly stretched compared to anything else I ran.
Most likely going to get another set of DWS06's since I've been so happy with them. Good in all weather.
Old 02-19-2018, 03:43 PM   #716
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Decided to go with the Michelin AS3's this time around. With the added 3mm offset, some slight stretch to the tire will work to my advantage. A bit more expensive, but decided to go with a tire that has a bit better performance in the dry. It won't have the DWS06 snow performance, but considering the amount of snow driving I did this winter, I will be able to get by just fine with the Michelin's. Not to much we now have the outback that I can take on days I want to keep the STI garaged.
Snapped some final pics of the Gramlights on the car. I always find it funny how whatever it is you end up selling looks better than ever. These snaps makes me want to hang onto them haha.
Old 02-19-2018, 03:45 PM   #717
Obviously Tyler
Member#: 395955
2016 WRX
2018 Crosstrek
Just wait til the Enkeis go on.
Old 02-19-2018, 03:49 PM   #718
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Haha yeah I know. It happens to me all the time. I sell something then whatever it is looks, sounds, or feels better than it has ever been. Then usually I put whatever new on the car and all those thoughts go away. Hoping the Enkei's are what I am after though. I am definitely looking forward to the color change the most.
Old 02-19-2018, 03:54 PM   #719
Shipman
Member#: 312847
2006 WRX STi
2008 Legacy/2003 Forester
The new wheels will definitely have a nicer contrast to them. I like that color better than the super dark black.
Shipman is offline   Reply With Quote
Old 02-19-2018, 03:58 PM   #720
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Yeah the car is in desperate need of contrast. When I get the windows done, the black wheels would wash the car out. Something a bit lighter on the wheels ties it together better with tint. Without tint, I prefer the look of black or very dark wheels.
I tend to do the same progression with wheels on all my cars. Go right to black and then eventually start to make my way to lighter and gunmetal wheels. Not sure why, but I always do that haha.
Old 02-19-2018, 04:01 PM   #721
Shipman
Member#: 312847
2006 WRX STi
I've never been a fan of dark wheels at all but you always do it well so I wind up liking it. If I had it my way they would be alloy or light gunmetal but these new wheels are going to look awesome.
Old 02-19-2018, 04:10 PM   #722
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
I appreciate that. Hopefully these turn out just as or nicer than my current setup.
Old 02-19-2018, 04:48 PM   #723
M3lover1
Member#: 440553
2017 WRX STI Base
What percentage tint you going to do? And both front and rear windows?
Old 02-19-2018, 04:49 PM   #724
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
I do 35% on my cars. Good mix between dark and light. Depending on what brand I go with, I may even go a tad lighter. Yes front and rear (no windshield).
Old 02-23-2018, 12:22 AM   #725
ScoobyFreak86
Member#: 338329
2017 STI
Lapis Blue
Iím giddy.
