Welcome to the North American Subaru Impreza Owners Club Monday June 25, 2018
Old 07-10-2007, 02:16 PM   #301
bjteel
Member#: 14442
2002 WRB WRX
Originally Posted by LyveWRX View Post
Hopefully when you hit it with the hammer you dont hit the inner race, and getting the hub into the bearing must be a pain.
You don't hit the inner race because they are sandwiched together. If you mean the machined portion of the hub assy, well you don't hit that either if you are using a big socket as a punch.
Getting the bearing in the hub isn't hard at all if you freeze the bearing and heat up the hub assy.
bjteel is offline   Reply With Quote
Old 07-12-2007, 02:18 PM   #302
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
But the hub fits into the bearing, the bearing fits into the knuckle, the axle spline fits into the hub.
Or do you mean to heat the knuckle and freeze the bearing, then how do you get the hub into the bearing?
I'm not picking on you I swear, I just dont quite get your description.
LyveWRX is offline   Reply With Quote
Old 07-12-2007, 02:32 PM   #303
kainam00
Member#: 100708
2002 2.5 WRSX
2005 STI
Heat up the knuckle/bearing and freeze the hub? I'd be careful heating up the knuckle/bearing though... that's a good way to destroy the seals.
kainam00 is offline   Reply With Quote
Old 08-04-2007, 03:01 PM   #304
WRC-STI
Member#: 39707
2004 STI
I have read all 13 pages and still have a question. I have seen a front cv shaft nut torque of 162 ft/lbs for an 04 STI. Then you stake the nut so it won't back off. It seems like this would load the bearings to this level which seems pretty high. I remember back in the day when we would snug the bearing then back the nut off to the first cotter pin hole. I realize the Subaru is a different set up but it seems like that puts a pretty high load on the bearings. I don't want to spend all the money on new hubs and bearings only to get this step wrong and ruin the whole job. Thanks for any info on this very important step. By the way the origional post was real good and much appreciated.
WRC-STI is offline   Reply With Quote
Old 08-04-2007, 04:05 PM   #305
BIGSKYWRX
Member#: 7958
09 GH B+
axle nut is 137 ft lbs (unless the STi has a different spec????)- still high, but that's right from the FSM- and there have been many cases where these have loosened- not ideal as you can imagine.
you stake the nut exactly where it lies when you hit 137- you don't have to go any further (or back it off) like you would w/ a castle nut
Old 10-02-2007, 01:01 AM   #306
thehunv6
Member#: 120666
'12 PDXTuned Wagon
What a great write up. Thank you!!
thehunv6 is offline   Reply With Quote
Old 11-08-2007, 04:10 AM   #307
z
Member#: 41762
04 STi
in ur Floriduh
Originally Posted by freakboy2 View Post
started replacing rear bearing on forester yesterday. used pvc pipe to pull bearing but a portion of the race natrally stayed with the hub. As it was Sat. and most machine shops were closed I had few options. I went to a shop I that advertised as specialitsts in axle/cv repairs- Big mistake. They cut the bearing race off with a wizzer cut off wheel and scored a spiraling gouge in the hub portion that presses into the bearing. This is why I use the dealer or myself for repairs.
My problem is- in my distress over the now damaged hub (which I'm sure now needs to be replaced) I did not ask him the orientation of the seal which came off with the race. The outer seal is shaped like a flat bottom U. Which direction should the open portion of the U face. either toward the car center or away?
also When I do the other side I think I will remove the entire rear knuckle since I need to go to a real machine shop anyway. Does the car need to be aligned if I remove the knuckle? That was my main reason for the PVC press tool which worked well.
Great writeup hotrod!
for anyone else dealing with getting the bearing off the hub...this is the special tool (pictured here in hotrods OP)
and here...
it's kind of wedged so the initial tip slips under the bearing and then as you tighten it, the wedge lifts the bearing up.
Not sure if this tool is available, but many tools (including axle puller, ball joint pickle fork etc) are available at autozone in their "loan a tool" program.
http://www.autozone.com/in_our_store...oan_a_tool.htm
z is offline   Reply With Quote
Old 12-06-2007, 05:15 PM   #308
kainam00
Member#: 100708
2002 2.5 WRSX
2005 STI
I just did this another time and updated my FAQ/How-To on the PVC method.
http://rs.pmgz.net/?page_id=17
Old 12-06-2007, 05:28 PM   #309
blahhblahh
Member#: 86659
2005 WRX Sedan
WR Blue
^^wow bookmark
blahhblahh is offline   Reply With Quote
Old 12-06-2007, 05:42 PM   #310
Hotrodguru
Member#: 37210
2016 Subaru WRX
Very cool, nice updates! We need to edit and refine this thread.
Hotrodguru is offline   Reply With Quote
Old 12-06-2007, 10:49 PM   #311
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Not sure if anyone catch this yet. On page one of this thread. In the pics you have. You got the seals on wrong. The one you put on as the outter, is the inner and viseversa.
The inner seal has that extra lip too the seal too seal against the axle housing too keep dirt from getting to the main seal.
Patrick L is offline   Reply With Quote
Old 12-06-2007, 11:07 PM   #312
Hotrodguru
Member#: 37210
2016 Subaru WRX
Patrick, could you please try to explain that with proper grammar so that I may make any corrections if needed, thanks.
Old 12-06-2007, 11:17 PM   #313
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You sure about that? From the tech diagrams I've seen the extra lip is to bump up against the back of the hub thus it goes on the outside.
Old 12-07-2007, 06:38 PM   #314
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
NO, I just got off the phone with a Subaru master tech in OKC that is a good friend of mine to varify. The one with the extra lip in the inner seal. The lip in used as a dust seal. I can't count how many bearing and hub swaps I have done and when I saw those pics. That was the first thing that jumped out at me.
You can also tell by the old one. It does not have the extra lip.
http://www.revo1.com/subbiebearing/images/IMG_8316.jpg
Old 12-07-2007, 11:19 PM   #315
Carnot
Member#: 34596
'05 WRX Wagon PSM
'03 WRX Sedan PSM (Hers)
I've got to agree with Patrick L on this one. The seal that I've got in my hand (part number 28015AA080) is labelled "OIL SEAL IN FT" which likely means oil seal inner front. That part number is also listed as the inner seal according to subaruparts.com.
-Bryce
Carnot is offline   Reply With Quote
Old 12-07-2007, 11:55 PM   #316
Hotrodguru
Member#: 37210
2016 Subaru WRX
Originally Posted by Hotrodguru View Post
Assembly of Hub
Press the following items in this order.
1. Bearing (inside out)
2. Seal (outer seal, before inserting hub)
3. Hub (outside in)
4. Seal (inner), the seal with the lip is the outer seal, lip goes pointing towards the wheel and acts as a dust shield
Hell it's been so long I really don't remember even though I've done this a few times. I do know I put it together just the way it came off. Actually if you look at my writing I think I had it right. Because I have "Seal (inner), but then state outer (I highlighted in red). I just need to correct the above grammer error in red right? Think I just mixed it up when writing the instructions.
Can we confirm so I can make the change in the post?
Thanks
Old 12-10-2007, 11:22 AM   #317
Carnot
Member#: 34596
'05 WRX Wagon PSM
Thanks
It should read:
4. Seal (inner), the seal with the lip is the inner seal, lip goes pointing towards the axle and acts as a dust shield
-Bryce
Old 12-10-2007, 11:58 AM   #318
kainam00
Member#: 100708
2002 2.5 WRSX
2005 STI
Thanks
You probably meant that it's the outer of the two inner seals, meaning it's loser to the outside of the knuckle eventhough it's more inner relative to the car. Does that make sense? It does to me...
I'm 100% not sure how it is in the front, since I haven't taken that apart, but I believe the OP was correct saying that the dust boot part of that seal should go in facing the wheel. My question re- the rear http://forums.nasioc.com/forums/show....php?t=1399054
Old 12-10-2007, 11:05 PM   #319
Carnot
Member#: 34596
'05 WRX Wagon PSM
I'm not sure what you're talking about, but I've only ever seen one inner seal on a front wheel bearing. Maybe the rears have two inner seals(?).
I'll try hotlinking a picture, it may not work.
-Bryce
Old 12-13-2007, 01:17 PM   #320
eleven22
Member#: 131766
Originally Posted by DanKorte View Post
Hi there. I've got an '01 Forester with 119k miles and at least one shot wheel bearing. I think it's on the rear drivers side, i'm going to get that confirmed by my mechanic.
I've read on this and other sites that I want to get a Legacy replacement for it, but does it matter what model year Legacy the bearings are from? or are they all the same?
Also, would any of you happen to know the part numbers and rough costs for ALL parts needed for this servicing? (include any appropriate seals, etc). Thanks very much for your help!
Dan
PS- I read that step by step (with photo) wheel bearing repair post from a couple years ago. Would that apply to my Forester as well? I can print it off and give it to my mechanic. Thanks!
Hey I have a 01' Forrester that has 118K and the left rear driver's side bearing went out and my name is Dan. LOL too funny.
On another note I used this techique.
It cost me less then 20 bucks for the parts. On his site he says to use good wood to use as a brace. I just used the handle from the slide hammer on the rod and it worked like a charm. The PVC press is really cool. a couple things I found out was that :
A. The slide hammer bearing removal slide hammer attachment does not work!
B. Do not use a torque wrench to screw in the nuts on the 2 FT shaft use a wrench , it turns pretty easy.
C. It took me 6 hrs to do , I can prolly do it in 4 now that I got over my fear of doing something wrong. (However, My bearing was not attached to the spindle when it came out so I think I may have been lucky there.)
eleven22 is offline   Reply With Quote
Old 12-13-2007, 01:58 PM   #321
eleven22
Member#: 131766
-Bryce
The rear has two on the inside and one on the outside.
Old 12-13-2007, 04:28 PM   #322
kainam00
Member#: 100708
2002 2.5 WRSX
2005 STI
Some good feedback there! Thanks!
A - Ageed! The slide hammer is pretty useless for anything but removing the hub. The second time I did it, it even came with a hub adapted, but it was too big for my 5x100 bolt pattern, and even for the 5x114 STI hub I had laying around... crazy.
B - Yes! 21mm or so wrench will do the trick. I used a 1" one since I didn't have metrics that big.
Using something metal as a brace is a good idea as well, I used my aluminum block the second time around. Anything sturdier than a 2x4 will work.
Glad to heard that my page is helping people out
Old 12-13-2007, 07:40 PM   #323
z
Member#: 41762
04 STi
in ur Floriduh
yep...
#14 and 15...
Old 12-14-2007, 03:10 AM   #324
1991fc3s
Member#: 166703
I'm about to replace the front wheel bearings on my 2.5 rs. So to clarify does the front have 1 or 2 inner seals. So far I have 1 hub, 1 bearing, 1 outer seal, and 1 inner seal.
Thanks
1991fc3s is offline   Reply With Quote
Old 12-14-2007, 10:38 AM   #325
hopeprevails
Member#: 128827
That 14mm horizontal hub bolt that is listed as being "a tad bit easier..." (above the lower ball joint) seems to be problematic for a lot of preza's. A buddy of mine has been a local Subaru dealer mechanic for years now and he warned me about how delicate it is. None the less, I managed to break the darn thing. Just hoping that no one else out there makes the same mistake! Use vise grips on the bottom of the ball joint, and a SMALL chisel to go through that gap in the top. Use penetrating oil. Go slow, or get ready to buy a new hub.
Rock on, gear heads.
hopeprevails is offline   Reply With Quote
Rear Wheel Bearing Replacement Walkthrough, with pics motohippy Brakes, Steering & Suspension 163 04-06-2018 01:26 PM
To those who've had wheel bearings replaced SubEd New England Impreza Club Forum -- NESIC 9 01-01-2002 02:37 PM
Wheel bearing replacement? rhdude Mid Atlantic Impreza Club -- MAIC 2 10-10-2001 04:27 PM
DIY Wheel Bearing Replacement? mav1c Brakes, Steering & Suspension 1 10-02-2001 10:13 PM
Wheel Bearing Replacement? LUME Brakes, Steering & Suspension 2 09-18-2001 04:57 PM
