06-20-2017, 11:27 AM | #726 |
Vendor Sales Rating: (7)
Member#: 228856
South East
It's Tuesday June 20th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
ACT Heavy Duty 6-Puck Disc Clutch Kit: The HDG6 kit features ACT's most popular Heavy Duty pressure plate. ACT Heavy Duty pressure plates use exclusive diaphragm design to increase clamp load, reduce deflection and maximize clutch life. All diaphragms endure a four-stage, heat-treating process for unparalleled performance. ACT pressure plates have precision cover stampings to provide rigidity and consistency. ACT's 6-pad spring-centered race disc features a spring-center construction to properly damp torsional vibrations and resist failure under harsh conditions. ACT spring retainers utilize wraparound spring windows and thicker retainer stampings to provide spring support, reduce stress concentrations, and increase strength and reliability. With the 6-pad spring-centered race disc engagement is harsher, but shifting is faster. The 6-pad spring-centered disc is recommended for larger clutch sizes to absorb more heat. Monoloc is a one-piece, direct replacement or upgrade to the standard, two-piece wedge collar and wire ring featured in pull-type clutches. The spring tension of the segmented retaining ring is carefully calculated and tested for optimal performance. It provides uniform loading on the bearing and pressure plate to assure proper alignment, regardless of driver influence or vehicle modifications. Monoloc's hardened Chrome-moly steel construction will provide years of service. COBB Tuning Stage 1+ Drivetrain Package: Are you looking to modify your transmission components? Why not buy the COBB Stage 1+ Drivetrain Package and get everything COBB offers for your transmission! We've grouped our revolutionary Double Adjustable Short Throw Shifter, Front and Rear Shifter Bushings and COBB Knob together to bring you the ultimate package. Set the shifter throw and knob height to your personal preference, tighten up slop in the shifter assembly caused by the soft factory bushings and add some COBB bling today! Features:
PM, call, or E-mail for most up to date pricing! Other parts available such as Stainless steel brake lines from StopTech performance and Goodridge. High temp brake fluid available from MOTUL, ATE, and StopTech. We are open Monday - Friday 9AM EST to 6PM EST and Saturdays 10AM to 1PM. You can contact us via forum messaging, E-mail, and telephone. As always if you don't see it, just ask! Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook Thanks for looking! Alex Goodwin [email protected] MotionLabTuning.com - Engineering Performance
__________________
[CENTER]Charlotte, NC Phone: 704-527-0100 Email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Facebook: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Instagram: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/CENTER] [center] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [/center] |
06-21-2017, 11:27 AM | #727 |
Member#: 228856
South East
It's Wednesday June 21st and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
06-22-2017, 03:24 PM | #728 |
Member#: 228856
South East
It's Thursday June 22nd and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
06-23-2017, 10:54 AM | #729 |
Member#: 228856
South East
It's Friday June 23rd and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
06-26-2017, 12:07 PM | #730 |
Member#: 228856
South East
It's Monday June 26th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
06-29-2017, 09:45 AM | #731 |
Member#: 228856
South East
It's Thursday June 29th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-11-2017, 10:00 AM | #732 |
Member#: 228856
South East
It's Tuesday July 11th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
Cusco Increased Capacity Rear Differential Cover Blue R180 Subaru STI: Increased capacity is ideal for use in competitive motorsports or overall aggressive driving to ensure LSD and final drive longevity. Protect your investment! The increased oil volume promotes heat build up and dissipation where the fluid keeps the moving components well lubricated at all times. Two types of billet aluminum anodized covers are available, blue and silver.
Perrin Pitch Stop Mount Black Subaru Models: Reduce drivetrain shudder under hard acceleration by installing a PERRIN Pitch Stop mount. The factory pitch stop mount is designed to control the pitching of the engine and transmission under light to normal acceleration. Subaru's with power and drivetrain upgrades will need PERRIN's more aggressive option. Under hard acceleration, the drivetrain is being twisted front to back from front axle torque twist. To control this front to back twisting, Subaru created a pitch stop mount. The factory pitch stop is made of plastic with soft rubber bushings, allowing for a significant amount of movement under hard driving conditions, creating drivetrain slop & shudder. The PERRIN Pitch Stop mount controls the movement of the drivetrain in both on and off throttle driving giving the driver a more positive feel and literally putting more power to the wheels by eliminating lost energy. The PERRIN Pitch Stop Mounts body is machined from 6061 billet aluminum and features a combination of 90a and 70a durometer. The bushings are as stiff as possible without introducing excessive NVH. (noise vibration harshness) PM, call, or E-mail for most up to date pricing! Other parts available such as Stainless steel brake lines from StopTech performance and Goodridge. High temp brake fluid available from MOTUL, ATE, and StopTech. We are open Monday - Friday 9AM EST to 6PM EST and Saturdays 10AM to 1PM. You can contact us via forum messaging, E-mail, and telephone. As always if you don't see it, just ask! Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook Thanks for looking! Alex Goodwin [email protected] MotionLabTuning.com - Engineering Performance
__________________
07-13-2017, 12:51 PM | #733 |
Member#: 228856
South East
It's Thursday July 13th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-14-2017, 10:05 AM | #734 |
Member#: 228856
South East
It's Friday July 14th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-17-2017, 05:38 PM | #735 |
Member#: 228856
South East
It's Monday July 17th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-18-2017, 03:13 PM | #736 |
Member#: 228856
South East
It's Tuesday July 18th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-19-2017, 03:29 PM | #737 |
Member#: 228856
South East
It's Wednesday July 19th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-20-2017, 02:41 PM | #738 |
Member#: 228856
South East
It's Thursday July 20th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-24-2017, 04:37 PM | #739 |
Member#: 228856
South East
It's Monday July 24th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-25-2017, 03:38 PM | #740 |
Member#: 228856
South East
It's Tuesday July 25th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-27-2017, 04:05 PM | #741 |
Member#: 228856
South East
It's Thursday July 27th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-28-2017, 10:44 AM | #742 |
Member#: 228856
South East
It's Friday July 28th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
07-31-2017, 04:41 PM | #743 |
Member#: 228856
South East
It's Monday July 31st and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
08-02-2017, 12:56 PM | #744 |
Member#: 228856
South East
It's Wednesday August 2nd and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
08-16-2017, 09:47 AM | #745 |
Member#: 228856
South East
It's Wednesday August 16th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
08-18-2017, 11:03 AM | #746 |
Member#: 228856
South East
It's Friday August 18th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
08-21-2017, 11:55 AM | #747 |
Member#: 228856
South East
It's Monday August 21st and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
08-23-2017, 10:45 AM | #748 |
Member#: 228856
South East
It's Monday August 23rd and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
08-29-2017, 03:03 PM | #749 |
Member#: 228856
South East
It's Tuesday August 29th and Motion Lab Tuning has the best deals on all the major engine modifications and components you need to transform your Subaru. Between the numerous offerings from Exedy, ACT, and The Driveshaft Shop you also have companies like OS Giken and Cusco bringing some noteworthy options to the market.
__________________
08-29-2017, 03:04 PM | #750 |
Member#: 228856
South East
__________________
