04-23-2001, 05:14 PM | #1 |
Member#: 1744
VIC
Vehicle:'11 Trolley Bus Translink |
Wrapping exhaust?
Anyhow, a pretty stupid question.... I've seen a lot of people wrap their headers w/fibreglass - i'm thinking that this is to keep exhaust gasses up, hence speeding up their flow backwards. Therfore, i'm thinking of maybe wrapping my exhaust to see if there is a diff. I'm currently running a 2.5" catback on an na engine - would wrapping the exhaust alleviate "some" of the backpressure problems due to the large diam. of the exhaust piping? Just a thought, please don't flame me. Also, if i did decide to wrap the exhaust, would there be problems w/ rust due to moisture and debris sandwiched up between the fibre and exhaust? Thanks.
TMR
04-23-2001, 05:59 PM | #2 |
Member#: 5385
Vehicle:2012 WRX Base Ice Silver |
I don't know about the WRX, but the 2.5RS is pretty much wrapped already down to the cats.
The metal "housing" around the exhaust appears to have insulation inside it between it and the exhaust pipe. As far as whether or not wrapping the exhaust is helpful, I would say yes. Keeping the gasses at a higher temperature will keep velocity up. How much it helps is a question that only a dyno would answer. Nothing compares to real world testing. |
04-23-2001, 07:24 PM | #3 |
Member#: 3198
Vehicle:2005 GT LTD Wagon Garnet Red |
Wrapping will rot your exhaust. If you're really going to do it, spring for ceramic coating, it's cheaper than a new exhaust.
04-23-2001, 07:36 PM | #4 |
Member#: 5385
The only reason the pipe would "rot" would be rusting through. That usually requires moisture. Exhaust tends to get kind of warm and generally evaporates most of the moisture on it. True the wrap will tend to hold the moisture more than without the wrap, but I have wrapped exhaust in the past without any excessive rust problems.
04-23-2001, 08:14 PM | #5 |
Member#: 4063
MWSOC
I have seen regular mild-steel headers rust through over the period of 6 month. These were mild steel and were brand new... not the stainless alloy a new car exhaust is made of. I don't know what it would do to any other material. Personally, I wouldn't go near the stuff based on experience. The benifits don't outweigh the potentional losses.
04-26-2001, 04:58 PM | #6 |
Member#: 6110
Vehicle:98 Impreza L Red |
I have GSXR that had wrapped headers on it, they rusted like crazy. I could tell no discernable difference in the power output. I know I'm comparing apples to oranges, but to me it seems the hassle of wrapping them doesn't make up for the slight advantage that would be gained. Just my humble opinion
Similar Threads | ||||
NJ: Wrapped Exhaust Manifold | underpowerd | Engine/Power/Exhaust | 12 | 03-15-2008 09:29 PM |
Help wrapping exhaust | Lexington | Mid West Subaru Owners Club Forum -- MWSOC | 32 | 01-29-2007 09:33 PM |
Heat wrapping exhaust... | txl146 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 03-28-2005 11:47 AM |
What to wrap exhaust with(temporary fix)? | joubtt | Southern California Impreza Club Forum -- SCIC | 2 | 12-24-2003 05:00 PM |
thermo-wrap exhaust manifold or no? | ride5000 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 07-09-2003 11:05 AM |
