Welcome to the North American Subaru Impreza Owners Club Tuesday December 11, 2018
Old 12-09-2009, 10:07 PM   #1
yellowsubi
Member#: 209161
ohhh four STi
mmm Forged!!
Default Suggestions for the build
So rather than taking on my misfire problems head on, im gonna fix it the fun way by doing a build.
I have a salvaged 03 bugeye with 34k on the car(but the motor reaks of much more mileage). I have about 2-3 grand i can throw into the block and wondering what i need to be able to run an 18g or 20g and not have it die on me.
Someone on here before talked about the 2.1L swap with the stock wrx crank, sti rods, and some custom pistons.. but im also interested to hear some other ideas.
As of right now i have a vf39, pinks, warbro 255, perrin FMIC, gm boost solenoid. Obviously the first two need to go but can i keep the last 3 with an 18g or 20g?
Any input is much appreciated guys!
yellowsubi is offline   Reply With Quote
Old 12-10-2009, 12:00 AM   #2
stamps31757
Member#: 189810
2002 WRX Sedan
it depends on what you want to do with the car. If you plan on any type of autox then go with the 18g. if you plan on running it down the strip then go with the 20g. Either should be great for normal driving. But my personal opinion is keep the turbo that you have and just re-enforce your internals and i think you will be plenty happy.
stamps31757 is offline   Reply With Quote
Old 12-10-2009, 12:11 AM   #3
yellowsubi
Member#: 209161
ohhh four STi
mmm Forged!!
Sorry i should have been more specific. I want to get over 300 at the wheels, and my buddy whose doing the rebuild with me said that i should get some forged pistons, eagle rods, new bearings, and a head job. The vf39 from what ive read rarely cracks 290whp.
So im just searching for people suggestions on a +300whp setup from someone other than my buddy helping me.
Old 12-10-2009, 12:23 AM   #4
xsnapshot
Member#: 170973
2004 WRX 4EAT
An 18G will spool almost identical to a VF39. And the 20G spool is not that far behind the 18G if they have both have TD05 hotsides.
Honestly if you want to keep it between 2-3 grand, then you'll need to keep it super simple.
Just get new rods/pistons/bearings, leave the heads alone (thats big $), pay for the machining/balancing/etc.
Then likely you'll already be out of $. There's tons of little things that add up. If not out of $ then you can look into getting your new turbo and get some modded stock injectors.
Oh and your transmission will hate you for all of that
xsnapshot is offline   Reply With Quote
Old 12-10-2009, 12:27 AM   #5
yellowsubi
Member#: 209161
ohhh four STi
mmm Forged!!
Lol the tranny will be taken care of, i found a full swap from an 06sti for 3k, which isnt that bad... my friend whose helping me with the build said that the rods and pistons i could grab for around 600-700 bucks. Are the bearings/machining+balancing that much?
Old 12-10-2009, 12:29 AM   #6
rjburner
Member#: 167014
2005 WRX
Crystal Grey Metallic
For what your looking to spend you could buy an OEM STI block and bolt your WRX heads on. I think the going rate for a new shortblock is $1700'ish. Add another $400 for forged pistons and you've got a reliable 500hp shortblock. You could sell your old shortblock also....
rjburner is offline   Reply With Quote
Old 12-10-2009, 01:23 AM   #7
yellowsubi
Member#: 209161
ohhh four STi
mmm Forged!!
thats what my buddy dave wants me to do, but i wanna keep the best gas mileage (23mpg for the 2.5 vs 28mpg for the 2.0L??) as i can because i take long drives up and down california (and sometimes cross country) i know its not a huge difference for the amount of power increase but i just wanna build this 2.0 then when i get tired of it a year or 2 down the road ill just sell everything and get an STi
Old 12-10-2009, 11:51 AM   #8
stamps31757
Member#: 189810
2002 WRX Sedan
what ever route you go your gas mileage will reflect. Thats all in how well the tuning is on the car.
Old 12-10-2009, 01:38 PM   #9
yellowsubi
Member#: 209161
ohhh four STi
mmm Forged!!
Oh i just figured in general that the 2.0 could save me a little more on that, plus i didnt want to give any evo that i destroy any excuse like having a bigger motor blah blah..
Old 12-10-2009, 03:08 PM   #10
Finishlinewrx
Member#: 175459
2002 18g'd Corn PWR
Midnight Black
IMO for the 2.0l
Rods,Pistons,good bearings,mild cam
td05-20g
93/meth inj or e85
350-400whp
My tuner on his car was shooting for 400whp on a stock block with a 20g and meth inj. @25-26psi
build block will support that reliable.
Finishlinewrx is offline   Reply With Quote
Old 12-10-2009, 04:49 PM   #11
stamps31757
Member#: 189810
2002 WRX Sedan
yeap then you can start worrying about which route to go as far as transmissions.
Old 12-10-2009, 05:33 PM   #12
Finishlinewrx
Member#: 175459
2002 18g'd Corn PWR
Midnight Black
Depends on the shop really.
200-500
Old 12-10-2009, 08:57 PM   #13
yellowsubi
Member#: 209161
ohhh four STi
mmm Forged!!
yeah i got my tranny search going
Thanks for the recommendation i didnt know the 2.0 could crack 400
Old 12-10-2009, 09:10 PM   #14
ADAS1223
Member#: 159853
2005 Impreza
wrb
I have a 2.0l with sti rods/JE pistons/rings/wrists pins, oem everything else. capable of 500whp and 8k. about the limit of the 2.0 open block.
ADAS1223 is offline   Reply With Quote
Old 12-11-2009, 06:25 AM   #15
stamps31757
Member#: 189810
2002 WRX Sedan
yeah i'd love to have your setup. i could get so much more out of my 18g without worrying about the engine.
Old 12-11-2009, 01:59 PM   #16
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
Get a hta68, pistons, rods and injectors and your good to go. the HTA68 will get you above 300whp no problem and it out preforms both the 18g and 20g, atleast from what i've seen. And its cheap as hell.
04wrxhart is offline   Reply With Quote
Old 12-12-2009, 02:59 PM   #17
yellowsubi
Member#: 209161
ohhh four STi
mmm Forged!!
cheap usually means unreliable...?
Old 12-12-2009, 09:19 PM   #18
stamps31757
Member#: 189810
2002 WRX Sedan
its actually a really good turbo.
Old 12-13-2009, 05:00 PM   #19
yellowsubi
Member#: 209161
ohhh four STi
mmm Forged!!
Whats the going rate for a used one? Only found a couple that were kind of pricey.
Suggestions for my build PHXSTI South West Impreza Club Forum -- SWIC 26 09-23-2009 02:49 PM
Suggestions for my build nySulli Car Audio, Video & Security 9 12-16-2008 04:57 PM
Annapolis-area folks: Looking for hotel suggestions for the meet! Siper2 Mid Atlantic Impreza Club -- MAIC 9 04-26-2007 06:20 PM
Suggestion for the "The Official For Sale Thread." Sports Wagon South East Region Forum 2 06-14-2005 10:14 AM
Suggestion For the Message Board... ASNG General Forum Archive 12 05-28-2000 01:02 AM
