04-26-2002, 04:36 PM | #1 |
Member#: 6331
Vehicle:2006 STI OBP |
Can't get car into 2nd gear
This problem doesn't happen all the time. It strange when it does happen. I can't get the shift lever to go into 2nd, but all other gears engage smoothly. So I end up having to drive going from 1st to 3rd. Then suddenly it will start shifting like normal. I only have to drive a few miles for it to correct itself. Does anyone know what the problem may be?
04-26-2002, 04:54 PM | #2 |
Member#: 11931
Vehicle:2001 2.5 RS Turbo 257/FMIC/T3-T04S |
Possibly a bad shifter fork.
Graham |
04-27-2002, 01:57 AM | #3 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
Do WRX's have that little spring that goes from the plate around the shifter linkage bushing to tranny? Cause on my car, I just discovered yesterday that by tweaking that spring I caused my shifting to pull in different directions (or by taking it off to be VERY loose and impossible to drive with), If it doesnt, then its probably a gear/tranny thing...
04-27-2002, 02:02 AM | #4 |
Member#: 16530
Vehicle:2004 WRX STI WR Blue |
I just made a seperate post for my WRX. It seems I have a simillar problem, only it's with 3rd!!!
04-27-2002, 02:35 AM | #5 | |
Member#: 6551
Vehicle:'01 GC8 Dinged STM '09 Concours 14 ABS Black |
Jeremy p.s.: Don't put that plate on backwards or it will do what you are having problems with...do you have a short shifter and bushing in? |
04-27-2002, 02:01 PM | #6 |
Member#: 13485
NESIC
Vehicle:OMG EJ22T FTW |
I actually have the same problem, but it doesn't sound the same severity as you. However, I have a couple possible solutions. If you have Kartboy shifter bushings, the washer plate may be in wrong, it goes H on the outside and hook pointing up.
But, my problem is a few minutes after I start driving when the tranny is cold, especially on colder days, its very hard to slide it into 2nd the first few times. I just patiently and delicately pull it into 2nd until it goes in, after a few miles driving and shifting into 2nd/downshifting to 2nd it loosens up nicely. I don't know what causes it, but just letting you know you're not alone. When I need my next oil change, I'm going to pick up some Red Line gear oil and see if that helps, it just might. |
04-28-2002, 12:28 AM | #7 |
Member#: 6331
I still have the stock shifter and bushings and I have never taken the shifter apart. So I'm not sure what the problem is. I'm dropping my car off at the dealership for a couple of other issues on Monday. I'll have them check this out too and update everyone later.
car won't shift into 2nd gear | burke25 | Transmission (AT/MT) & Driveline | 35 | 10-19-2007 02:13 PM |
Can't shift into 2nd gear?! | nicholam | Transmission (AT/MT) & Driveline | 12 | 08-05-2007 10:52 AM |
help can't get car in first gear | walta | Transmission (AT/MT) & Driveline | 13 | 02-28-2007 01:59 PM |
I need help!! I can't shift my car into 2nd | ej20_876 | Transmission (AT/MT) & Driveline | 10 | 07-31-2005 07:19 PM |
troblem going into 2nd gear!!!!! | ndwong49 | Mid West Subaru Owners Club Forum -- MWSOC | 23 | 05-09-2003 04:27 PM |
