07-02-2018, 08:17 PM | #1 |
Member#: 462200
Help with 2013 Crosstrek xv
While I was driving my abs,traction control, and hill assist lights came on. So I pulled over and looked it up and came across people saying it may be the brake light switch but my break lights still come on and when I turned it back on the lights are no longer on. Can someone tell me what this might be ?
07-03-2018, 09:49 AM | #2 |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
Check the fuses in the little panel under the traction control button. One of those controls most of what went out on yours can't remember which one.
07-09-2018, 09:18 PM | #3 |
Member#: 488150
I recall it was the third fuse from the bottom in the fuse box below the steering wheel.
07-11-2018, 05:42 PM | #4 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
Pull the codes. Is it a CVT? Sounds like the lights that came on in ours before we replaced the bad tranny.
07-13-2018, 02:44 PM | #5 |
Member#: 462200
It is a cvt, the lights come on and off. Haven't been on a few days now
07-13-2018, 02:45 PM | #6 |
Member#: 462200
No check engine lights, just abs, hill assist, and traction control
07-13-2018, 03:04 PM | #7 |
Member#: 462200
07-13-2018, 10:37 PM | #8 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
If it was a CVT code/issue you would have a check engine light. ANY fault the TCM sees will automatically set a P0700 in the ECM to get your attention.
It could still be your brake light switch - they fail intermittently at first. Find out what the codes are - you will have some. You will need a scan tool that can read VDC codes, a basic scanner won't do it. |
08-07-2018, 01:32 PM | #9 |
Member#: 318753
South East
Vehicle:2012 Impreza Dark Grey |
sounds like a brake light issue, that's what my codes were minus the hill assist.
