Welcome to the North American Subaru Impreza Owners Club Sunday September 23, 2018
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 11-20-2006, 12:00 AM   #1
kingsubi
Member Sales Rating: (59)
Member#: 19239
2011 WRX
Default Version 2 STi RA motor bits, TD05-16g, oil cooler, 5th injector intake manifold
Parting out a couple projects that are being abandoned.
3 rods, crank from the RA - very deep dish :P. Never seen anylike them - good for paperweights
$75
Complete jdm wrx block fully rebuilt with version 2 forged internals and new bearings, crank reground etc. Only 4K miles old. One rod bearing failed. 8.5:1 compression with jdm heads
$400 - pending
picture - in the back
Extras - from jdm sti ej20g, also fit leggy turbo picture
Oil cooler (coolant) - comes with water pump, hoses etc. great addition for cars without one SOLD
Coolant crossover pipe w sensor $50
Coolant overflow tank $SOLD
Alternator 3-plug $50
Power steering pump and lines (JDM) $SOLD
4.44 rear diff with axles (axles need rebuild/boots, diff needs new axle seals) $SOLD
DOHC timing covers, complete, no cracks $80 picture
5 spd flywheel $200 picture
boost solenoid from ej20g $SOLD
bugeye blue ridge pearl fog covers $40
Inquire within or email: [email protected]
SOLD
Exhaust Manifold $75 SOLD
TD05-16g. stock turbo on version 2 sti - 90 deg inlet. Some play in the turbo - comes with catless up-pipe b/c I can't remove the nut... SOLD
version 2 RA heads - huge intake valves, non-mechanical, matches version 1-4 intake & N/A dohc SOLD
kingsubi is offline   Reply With Quote
Old 11-20-2006, 12:11 AM   #2
DashboardCon
Member Sales Rating: (11)
Member#: 109878
2001 Aprilia RSVR
Change that 15g to a 16g, I can already see the comments. Good luck!
DashboardCon is offline   Reply With Quote
Old 11-20-2006, 04:04 PM   #3
kingsubi
Member#: 19239
2011 WRX
Added some more pics
Old 11-20-2006, 06:10 PM   #4
kingsubi
Member#: 19239
2011 WRX
turbo is pending sale
Old 11-20-2006, 07:28 PM   #5
STi-JDM
Top Scoob 023
Member Sales Rating: (183)
Member#: 90373
05' STi. 89' GT-R
00' GT-R ; LCM x WFC
will the timing belt covers fit 05 STi?
STi-JDM is offline   Reply With Quote
Old 11-20-2006, 09:21 PM   #6
mistermike3
Member Sales Rating: (4)
Member#: 102640
02 RA+ewg18G+C16
= pure pleasure
Does the block still have a bad bearing?
mistermike3 is offline   Reply With Quote
Old 11-21-2006, 01:16 AM   #7
ROC pit-bull
Member Sales Rating: (2)
Member#: 67814
1995 legacy L
white
would these heads match up with a 257 ?
ROC pit-bull is offline   Reply With Quote
Old 11-21-2006, 01:38 AM   #8
kingsubi
Member#: 19239
2011 WRX
No idea if the covers fit a new sti. I would assume not as this car does not have AVCS.
The block has a bad rod bearing but the whole block was only run for 5K miles total and literally none once the bearing failed so I doubt anything needs to be done other than replace the rod bearing.
The heads will match up with any subaru block.
Old 11-21-2006, 01:56 PM   #9
kingsubi
Member#: 19239
2011 WRX
Added more pics and items.
Old 11-22-2006, 01:48 AM   #10
ROC pit-bull
Member#: 67814
1995 legacy L
white
avcs is irrelavant. I just wanted to know if the heads will bolt on to the block, like the 02+ heads would?
Thank you
Old 11-22-2006, 02:49 AM   #11
kingsubi
Member#: 19239
2011 WRX
AVCS comment was for the timing covers. Yes - the heads will bolt up.
I have ej20g heads on a version 8 short block
Old 11-25-2006, 03:51 AM   #12
kingsubi
Member#: 19239
2011 WRX
added bits
Old 11-26-2006, 12:30 AM   #13
kingsubi
Member#: 19239
2011 WRX
Taking offers on the "bits"
Old 11-26-2006, 09:06 PM   #14
kingsubi
Member#: 19239
2011 WRX
Sold some
Old 11-29-2006, 11:35 AM   #15
kingsubi
Member#: 19239
2011 WRX
oil cooler pending
Old 01-06-2007, 11:44 PM   #16
kingsubi
Member#: 19239
2011 WRX
updated list
FS:DC: (ALL SOLD) TD05 16G, Perrin EBCS, Mod'd Injectors, WalbroFuelPump, Catch Can Sikk Boy Engine/Power/Exhaust 5 02-15-2010 09:44 AM
Version 2 Type RA intake manifold wopdeeze 1993 - 2001 Impreza Specific Parts 3 10-30-2009 03:48 AM
TD05 16G Big with stock injectors wrx_worx_04 Newbies & FAQs 14 03-31-2009 09:13 AM
Version 2 STi RA motor bits, TD05-16g, oil cooler, 5th injector intake manifold kingsubi SWIC Private Classifieds 3 01-10-2007 01:15 AM
Feeler: Real Deal JDM Impreza STi Version 2 Type RA [email protected] Private Vehicle 'For Sale' Classifieds 10 06-20-2005 02:09 PM
