12-11-2006, 01:01 PM | #1 |
Member#: 43495
NWIC
Vehicle:2014 FFR 818R STI Silver |
Questions about replacing the rear hub and bearing?
I'm upgrading the hubs on my 2004 STI to 5x114. I have the package from 6gunracing. It includes new 5x114 hubs and new bearings for the rear. On the rears, they say take the whole housing to a mechanic to replace the hub and bearing. I'd like to do it myself. There seems to be a lot of DIY info for working on the fronts, but I can't find anything on the rears. Questions:
Can I replace the hub and bearing without removing the housing? Can I use a slide hammer to pull the hub from the housing? Will I need to use a bearing separator and press?
12-11-2006, 01:04 PM | #2 |
Member#: 49148
South East
Vehicle:Dogs are forever in the pushup position... |
My understanding is that you need to use the entire housing, as there is a difference in hub size and design.
12-11-2006, 01:21 PM | #3 |
Member#: 43495
NWIC
Thanks. I edited my post to be more clear. I have the hub conversion kit from 6gunracing. They say take the rear housing to mechanic to have them pull replace the hub and bearing. But I'd like to do this myself.
12-11-2006, 01:59 PM | #4 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
You need a press or something like the bearing shark.
12-11-2006, 02:42 PM | #5 |
Member#: 43495
NWIC
Thanks. I think this is what you're talking about:
http://www.mytoolstore.com/oldforge/olf06.html |
12-11-2006, 02:59 PM | #6 |
Member#: 14311
Vehicle:2010 GTI White |
I think you *could* do it without a press. It would take some creativity with a threaded rod though. But I've seen it done.
I have absolutely no idea how you could possibly do it without pulling the knuckle off of the car though. While it is easier if you have a nearby shop that you trust with the press work, and it would save you several hours worth of work, I think you can get a pretty cheap hydraulic press from Harbor Freight that will do the job nicely. |
Question About Replacing The Carpet In My '02 WRX | MaddSubieLove | New England Impreza Club Forum -- NESIC | 3 | 05-17-2010 08:29 AM |
Few questions about 2004 STI rear diff and a few other related concerns | sonic03rex | Transmission (AT/MT) & Driveline | 9 | 01-31-2008 01:54 PM |
Does taking out the rear hub damage the wheel bearing? | MasterKwan | Brakes, Steering & Suspension | 4 | 09-02-2007 11:45 PM |
MY02-05 WRX hubs and bearing the same? | TubeDriver | Transmission (AT/MT) & Driveline | 4 | 05-04-2005 11:00 AM |
question about replacing the stock wastegate | Fyxtion | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 08-31-2002 12:52 PM |
