Welcome to the North American Subaru Impreza Owners Club Thursday March 30, 2017
Old 02-16-2017, 09:35 PM   #26
bmxhotsauce
Member Sales Rating: (7)
Member#: 127099
02 IMPERZA WRX
BLACK
Originally Posted by [email protected] View Post
Just like anything urethane, rubber or the like. it has a service life. We highly recommend NOT using anything petroleum based to help slide them on as it will shorten the life span. It's also not uncommon for the trans bushings to fail if you are running the car without the factory heat shields.
Normal life is around 5 years +-.
If they do fail and you nicely contact. I'll more than likely take care of you no problem. If you are a dick about it. Then not so much.
Tom
Love the honest truth .. still good **** kartboy!! I hate when people are dicks about small issues .
bmxhotsauce is offline   Reply With Quote
Old 02-17-2017, 12:14 AM   #27
Fierysun
Member Sales Rating: (108)
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Originally Posted by Crawlerado View Post
You use Kartboy exhaust hangers on your truck as bushings? Do you have a build thread? In for results.
I have a baggy of the crumbled Kartboy bushings. I replaced all the bushings on my truck about 20 years ago with Energy Suspension polyurethane replacements. This includes shocks, endlinks, swaybar, control arms, spring eye, etc. Not one of them crumbled into little pieces. Not one. All of them are fine and I still have the truck. So I don't buy the 5 year life excuse.
Gotta love people that don't understand when a product is poorly made.
Fierysun is offline   Reply With Quote
Old 02-17-2017, 10:58 AM   #28
Crawlerado
Member Sales Rating: (5)
Member#: 305948
2015 818R
Black and Yellow
So none of those are attached an exhaust that's at several hundred degrees then.
Comparing exhaust hangers to suspension bushings
Crawlerado is offline   Reply With Quote
Old 02-17-2017, 11:14 AM   #29
Fierysun
Member#: 82745
2005 Subaru STI
Sorry you can't read, but his x-member bushing also crumbled to little pieces. Especially when other manufacturers like Cobb and TIC (the non KB ones they sell) as well as OEM doesn't. Yeah, Kartboys bushings are poorly made/designed.
Old 02-17-2017, 11:29 AM   #30
PARANOID56
Member Sales Rating: (44)
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i have replaced a bunch of energy suspension poly parts, they have all crumbled. mainly where there is a lot of movement, say sway bar endlinks.
+1 for a vendor not afraid to speak the truth
PARANOID56 is offline   Reply With Quote
Old 02-17-2017, 12:27 PM   #31
Fierysun
Member#: 82745
2005 Subaru STI
Funny, Tom said his bushings are petroleum sensitive. Meaning if they come into contact with gas, oil, grease, etc, they break down. Which isn't a problem with other manufacturers.
My energy bushings are still fine after 20 years. Maybe they were properly installed.
Also, it helps no one (including the manufacturer) to cover up and/or stick up for a poorly made/designed product.
Old 02-21-2017, 08:47 AM   #32
cmiovino
Member Sales Rating: (22)
Member#: 134005
2004 WRX Premium
For what it's worth, I've had the Cobb hangers installed over 6-7 years, up to 110 degrees, down to -10 degrees, and about 50k miles including autocross and they're holding up just fine.
I didn't install them, previous owner did, so no idea if any lube was used installing them.
